CallManager Upgrade
Do I run the upgrade utility first before running bars? I am asking this because if the upgrade utility fails, the backup would be bad anyway and I would need to fix whatever is wrong first then do a backup.
  • IP Telephony
1 REPLY
Re: CallManager Upgrade
Patrick,
Its always recommended to run the upgrade utility before an upgrade attempt on the CM server and not before running BARS.
The first step you need to do before running upgrade utility is to backup the servers. Once you run the upgrade utility, the first thing it checks is validate the integrity of the backup tar file.
You are supposed to fix any errors in the outpu tof the upgrade utility before moving forward.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guide09186a00806de878.html
Sankar.
193
