Callmanager users (corporate directory) database
Can someone tell me which table in the callmangaer database stores the user directory? I need to export the users, ext, etc. I tried to export using bat, but this export doesn't contain the extension of the user. I am running 4.1(3)
Re: Callmanager users (corporate directory) database
they're not in any DB or table; they're in the directory. either DCD or AD
java
if this helps, please rate
java
www.cisco.com/go/pdi
Well, I figured out that every night at 12:00AM a text file is created that contains the user information from the directory. I found it while looking for the database. It is exeactly what I needed, but thanks for the reply.
227
