CallManager v4.1(3) - PSTN (Outside Line) Access
Is it possible to use the asterisk (*) key for outside line access instead of using 9. Its my understanding that the asterisk key can be used as a normal digit inside call manager.
1 REPLY
Re: CallManager v4.1(3) - PSTN (Outside Line) Access
that's correct. most usually it's used for things like internal services or transfer directly to VM but you can use it instead of 9 as outside code.
java
if this helps, please rate
java
www.cisco.com/go/pdi
103
