Callmanager V7 will it support an all call?
rbill1967
I have recently upgraded our callmanager from v5 to v7, easy upgrade.  I was given a question on whether V7 could support an all page (all call).  This means programming the system to page all phones at once by dialing one number or sending out a broadcast message.
Jaime Valencia
No, that's not possible with CUCM no matter what version you're running.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Adrian Saavedra
Level 7
Level 7
That feature is not supported in CallManager. You need a 3rd party application. You can browser CSC or Google and you'll find a lot of vendors that develop such products.
Hope it helps, please rate if it does.
- Adrian.
Rob Huffman
