Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Callmanager V7 will it support an all call?
I have recently upgraded our callmanager from v5 to v7, easy upgrade.  I was given a question on whether V7 could support an all page (all call).  This means programming the system to page all phones at once by dialing one number or sending out a broadcast message.
No, that's not possible with CUCM no matter what version you're running.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
That feature is not supported in CallManager. You need a 3rd party application. You can browser CSC or Google and you'll find a lot of vendors that develop such products.
Hope it helps, please rate if it does.
- Adrian.
Hall of Fame Super Red
195
