callmanager version 4.1 database
I have a callmanager in my lab that has loads of previous config in it, does anybody know a quick way to return the database back to day 1, ie no user config. Without re installation.
Re: callmanager version 4.1 database
I dun think it is possible.
Re-installation is the only way... It is a cleaner method i feel.
Yes, you will need to reinstall because there are a lot of crossreference between the tables in SQL. Unless you have a backup from the beginning of the system (from day 1) you will need to reinstall.
//Jorge
Reinstall is probably the best way, but you could also use BAT to nuke as much as possible...depending on the situation.
86
