callmanager
Can someone tell me why the, you have reached an invalid extension would stop playing??
callmanager 6.0
  • IP Telephony
Re: callmanager
The ANN can be stopped, having problems or the MRGLs from devices do not have it
Try restarting the IPVMS
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: callmanager
Jaime, is that a service?
Re: callmanager
Re: callmanager
Yes, IPVM Service
java
java
Re: callmanager
Please check the following doc for supported pre-recorded announcements too:
--> Supported Tones and Announcements
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmsys/a05ann.html#wp1042436
--> Annunciator Configuration Checklist
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmsys/a05ann.html#wp1028950
Teresa.
If this helps, please rate :)
Regards, Tere. If you find this post helpful, please rate! :)
Re: callmanager
Thanks all,
still looking for ipvm service to restart. in a nutshell, we had a power outage over w/e all seems ok accept the invalid extension annoucement..
Re: callmanager
found ipvms, do not see option to restart service?
thoughts?
Re: callmanager
Hi!
If you are on the Serviceavility page--> Control Center Feature Services, you'll see the "Cisco IP Voice Media Streaming App" service, select
the checkbox next to it and look for the Restart icon at the top of the page, it has a teal colored arrow and a little green square. Otherwise, scroll down and you'll see the Stop & Restart buttons.
Teresa.
If it helps, please rate! :)
Re: callmanager
Tere,
hero of the day award, sorry no monetary value. but extra thanks for staying with the thread. a newbie to this world so when some one says start this/that we sometimes are clueless as to where the service is.
restart fixed the issue. thank you Jaime also!!
174
