Community Member
Callmanger 6.1 ringtones
I have a client that wants to set all ringtones back to default in the cluster and then restrict the selection to just the default. Can i modify the ringlist.xml like on previous versions and how to set all back to default, any ideas would be greatly accepted.
Silver
Community Member
Re: Callmanger 6.1 ringtones
thanks for this but can anybody think of a way to default all phones back to default ringtone
there is no bulk process to do that, any way i can think of involves going to every phone.
factory reset or manual change are the ways, even using the phone designer is per phone process
java
if this helps, please rate
java
www.cisco.com/go/pdi
110
