Community Member
calls are forwarding to MVA DN !!!
Hi all,
I configured Mobile voice access @ cucm 7.0 .. i can listen the prompt from system, after get login, system prompt asks for make a call press 1 ... after press 1 if i dial any mobile or PSTN number the call is forwarding to the Mobile Voicess Acces DN which i configured Under Media Resource Group ---> Mobile Voice Access !!!!!!
After get login i want to make calls @ PSTN  &mobile numbers !!!
can any one help me out what mistake im doing ??
Re: calls are forwarding to MVA DN !!!
Hi, how did you sure that it's forwarding to MVA DN again? Do you get the MVA system prompt again? or it's dialing out through any of your gateway?
Community Member
Because if i dial any mobile number after press 1 (in prompt) the phone having same DN which i configured in MVA under Media Resource Group, is ringing ...
207
作成コンテンツを作成するには してください
