Calls are not routed to H323 Gateway
Hi guys
I have a CUCM Cluster in my HQ, and a H323 Gateway in a remote location ( Branch office), The ip phones are registered, we can make calls among ip phones,I receive calls from the PSTN using that remote gateway but, i can not make calls using that H323 gateway, The gateway is a 3925 using IOS version c3900-universalk9-mz.SPA.151-4.M1.bin
When i try to make a call from ip phone i do not see any calls in the gateway
GMXReforma#sh voice call status
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dia
l-peers
No active calls found
The callmanager version is 7.1.5
I made a debug, and attach the file.
any aid will be appreciate.
Take debug voip dialpeer, debug voip ccapi inout and debug isdn q931 (if applicable).
Kind regards,
- Adrian.
Hall of Fame Super Silver
Also, in the addition to the debugs post your GW configuration.
Chris
Re: Calls are not routed to H323 Gateway
Hi.
I send you the Gateway configuration, additional the Debug Voip Dialpeer and the Debug voip ccapi inout
De: cderen
Enviado el: martes, 15 de noviembre de 2011 05:42 p.m.
Para: Carlos Gonzalez
Asunto: - Re: Calls are not routed to H323 Gateway
Home<>
created by Chris Deren<> in IP Telephony - View the full discussion<>
Do you mean to send the first 0 out to the carrier?
If so, you need to adjust the following dial-peer
dial-peer voice 15 pots
destination-pattern 0T
to
prefix 0
Chris
Thanks a lot the problem was solved, it was an issue with the “Toll fraud” I configured:
voice service voip
ip address trusted list
ipv4 ]
Carlos
De: cderen
Enviado el: martes, 15 de noviembre de 2011 05:59 p.m.
Home<>
Hi.
I attach the debug you request
De: adrsaagom
Enviado el: martes, 15 de noviembre de 2011 05:22 p.m.
Home<>
created by Adrian Saavedra<> in IP Telephony - View the full discussion<>
Please paste your gateway config.
- Adrian.
voice service voip
ipv4 ]
Carlos
De: adrsaagom
Enviado el: martes, 15 de noviembre de 2011 05:53 p.m.
Home<>
475
