Calls being disconected
On remote site has been installed new router with VWIC-BRI. All works under CCM3.3.5
I found only some messages in logs that looks unfamiliar to me.
Mar 19 10:42:02: ISDN BR0/2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x73
Mar 19 10:42:04: ISDN BR0/3/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Mar 19 10:42:24: ISDN BR0/3/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
Cause i = 0x8090 - Normal call clearing
Mar 19 10:42:24: ISDN BR0/3/0 **ERROR**: L3_BadPeerMsg: event 0x4D cr 0x81 callid 0x0
Mar 19 10:42:24: ISDN BR0/3/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
Cause i = 0x80D1 - Invalid call reference value
Mar 19 10:42:43: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 18977
Mar 19 10:42:43: ISDN BR0/2/0 Q931: Sending SETUP callref = 0x0074 callID = 0x8082 switch = basic-net3 interface = User
Mar 19 10:42:43: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8 callref = 0x74
I am tryiing to find out where is the issue. On hardware or on provider site. Anybode faced syuch issue?
Silver
Re: Calls being disconected
The call disconnect may be caused by the lines being misconfigured. To resolve
Remove session-timeout nn from the line configuration
An "Invalid call reference value" means; remote equipment received a call with a call reference that is not currently in use on the user-network interface.
What line configuration do you mean?
My problem is BRI for Voice.
556
