02-14-2012 11:17 AM - edited 03-16-2019 09:35 AM
I have a environment "site A and site B" with SRST working.. .
But, the site B with SRST router can to do calls for CUCM site A... but Site A - CUCM can not to do calls for site B (busy signal).
The ip phones are in differents partitions...
Could you help me please?
02-14-2012 11:21 AM
If you want both sites to be able to dial each other, you need to ensure that the CSS (calling search space) assigned to Site A includes the partition of the phones from Site B, and vice versa.
Typically if you want full reachability between all internal extensions, you would have a single partition for all those internal devices to simplify the config.
Principal Engineer at Logicalis UK
Please rate helpful posts...
02-14-2012 11:34 AM
But all CSS that are on site A partition also on site B partition...
Thanks.
02-14-2012 11:39 AM
I think I misread your post.. do you mean that when you are in SRST mode:
02-14-2012 11:42 AM
Yes, correct. At moment all phones are registered on the main site - CUCM.
02-14-2012 11:48 AM
Sorry, my problem is when all phones are registered on CUCM.
02-14-2012 12:03 PM
hi aaronharrison, thanks!
I solved the problem.. The cucm had DN duplicated.
