Calls between different partitions
I have a environment "site A and site B" with SRST working.. .
But, the site B with SRST router can to do calls for CUCM site A... but Site A - CUCM can not to do calls for site B (busy signal).
The ip phones are in differents partitions...
Could you help me please?
Super Bronze
If you want both sites to be able to dial each other, you need to ensure that the CSS (calling search space) assigned to Site A includes the partition of the phones from Site B, and vice versa.
Typically if you want full reachability between all internal extensions, you would have a single partition for all those internal devices to simplify the config.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
But all CSS that are on site A partition also on site B partition...
Thanks.
Super Bronze
I think I misread your post.. do you mean that when you are in SRST mode:
  • The SRST site can dial the head office extensions
  • The 'main' site which has CUCM cannot dial the SRST site
Yes, correct. At moment all phones are registered on the main site - CUCM.
Sorry, my problem is when all phones are registered on CUCM.
hi aaronharrison,  thanks!
I solved the problem.. The cucm had DN duplicated.
228
