Calls coming into a number are forwarded to a fax machine
I was not the first tech to work on this issue.  I had another tech look at it and they ran the dialed number analyzer and apparently looked at traces from RTMT as well.
They did not run a debug on the gateway.  Below are the logs from the debugs I ran.  The debugs I ran are debug voip ccapi inout and debug isdn q931.  Are there other debugs I should possibly run to assist?
The number I am calling is 304-720-0974 from number 304-757-6542.
Log is below:
CTS-2811#sh logg
Syslog logging: enabled (0 messages dropped, 135 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging:  level debugging, 670 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
    Trap logging: level informational, 516848 message lines logged
--More--
Log Buffer (10000000 bytes):
1197247: Nov 19 15:42:21: %ISDN-6-DISCONNECT: Interface Serial0/0/0:19  disconnected from 13045453404 , call lasted 53 seconds
1197248: Nov 19 15:42:21.874: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x4458
Cause i = 0x8090 - Normal call clearing
1197249: Nov 19 15:42:21.902: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0xC458
1197250: Nov 19 15:42:21.906: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x4458
1197251: Nov 19 15:42:24.718: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 1253
1197252: Nov 19 15:42:24.718: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x4459 callID = 0xB811 switch = primary-ni interface = User
1197253: Nov 19 15:42:24.722: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x4459
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Facility i = 0x9F8B0100A11D02010F0201008015416E647265612048656E646572736F6E2031323533
Protocol Profile =  Networking Extensions
0xA11D02010F0201008015416E647265612048656E646572736F6E2031323533
Component = Invoke component
Invoke Id = 15
Operation = CallingName
Name Presentation Allowed Extended
Name = Andrea Henderson 1253
Calling Party Number i = 0x0081, '1253'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '13045453642'
Plan:ISDN, Type:National
1197254: Nov 19 15:42:25.018: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xC459
1197255: Nov 19 15:42:27.306: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0xC459
Progress Ind i = 0x8488 - In-band info or appropriate now available
1197256: Nov 19 15:42:27.706: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8  callref = 0xC459
1197257: Nov 19 15:42:49.087: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0xC459
Progress Ind i = 0x8482 - Destination address is non-ISDN
1197258: Nov 19 15:42:49: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 13045453642 N/A
1197259: Nov 19 15:42:49: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 13045453642 N/A
1197260: Nov 19 15:42:49: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 13045453642 N/A
1197261: Nov 19 15:42:49.091: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x4459
1197262: Nov 19 15:42:55: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 13045453642 N/A
1197263: Nov 19 15:43:05: %ISDN-6-DISCONNECT: Interface Serial0/0/0:22  disconnected from 13045453642 , call lasted 15 seconds
1197264: Nov 19 15:43:05.015: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x4459
1197265: Nov 19 15:43:05.047: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0xC459
1197266: Nov 19 15:43:05.051: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x4459
1197267: Nov 19 15:43:07.835: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0135
Standard = CCITT
--More--                                               Transfer Mode = Circuit
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
0xA10F02010106072A8648CE1500040A0100
Invoke Id = 1
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Calling Party Number i = 0x2183, '3045618701'
Called Party Number i = 0xA1, '3043460549'
1197268: Nov 19 15:43:07.839: ISDN Se0/0/0:23 Q931: Received SETUP  callref = 0x8135 callID = 0x4389 switch = primary-ni interface = User
1197269: Nov 19 15:43:07.859: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8135
1197270: Nov 19 15:43:07.887: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x8135
1197271: Nov 19 15:43:08.339: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x0135
Facility i = 0x9F8B0100A117020101020100800F4D41534F4E20424152525920494E43
0xA117020101020100800F4D41534F4E20424152525920494E43
Invoke Id = 1
Name = MASON BARRY INC
1197272: Nov 19 15:43:08.375: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 1253
1197273: Nov 19 15:43:08.379: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x445A callID = 0xB812 switch = primary-ni interface = User
1197274: Nov 19 15:43:08.379: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x445A
Standard = CCITT
Facility i = 0x9F8B0100A11D0201100201008015416E647265612048656E646572736F6E2031323533
0xA11D0201100201008015416E647265612048656E646572736F6E2031323533
Invoke Id = 16
Called Party Number i = 0xA1, '13045453404'
1197275: Nov 19 15:43:08.671: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xC45A
--More--                                     Channel ID i = 0xA98397
1197276: Nov 19 15:43:10.659: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0xC45A
1197277: Nov 19 15:43:11: %SYS-5-CONFIG_I: Configured from console by ats on vty0 (192.168.200.79)
1197278: Nov 19 15:43:12.003: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x8135
1197279: Nov 19 15:43:12.027: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0135
1197280: Nov 19 15:43:12: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3045618701 N/A
1197281: Nov 19 15:43:12: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3045618701 N/A
1197282: Nov 19 15:43:12: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3045618701 N/A
1197283: Nov 19 15:43:13.079: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8  callref = 0xC45A
1197284: Nov 19 15:43:17.887: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0xC45A
1197285: Nov 19 15:43:17: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3045618701 N/A
1197286: Nov 19 15:43:17: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 13045453404 N/A
1197287: Nov 19 15:43:17: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 13045453404 N/A
1197288: Nov 19 15:43:17: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 13045453404 N/A
1197289: Nov 19 15:43:17.891: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x445A
1197290: Nov 19 15:43:19.551: //-1/0053B2377332/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=1244
   ----- ccCallInfo IE subfields -----
   cisco-ani=1244
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=718663625350
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
1197291: Nov 19 15:43:19.551: //-1/0053B2377332/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x477101A4, Call Info(
   Calling Number=1244,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=718663625350(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=281154
1197292: Nov 19 15:43:19.555: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1197293: Nov 19 15:43:19.555: :cc_get_feature_vsa malloc success
1197294: Nov 19 15:43:19.555: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1197295: Nov 19 15:43:19.555:  cc_get_feature_vsa count is 9
--More--                           1197296: Nov 19 15:43:19.555: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1197297: Nov 19 15:43:19.555: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203045632,feature_id:278478
1197298: Nov 19 15:43:19.555: //281154/0053B2377332/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1244(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=718663625350(TON=National, NPI=ISDN))
1197299: Nov 19 15:43:19.555: //281154/0053B2377332/CCAPI/cc_process_call_setup_ind:
   Event=0x4758C288
1197300: Nov 19 15:43:19.555: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 718663625350
1197301: Nov 19 15:43:19.555: //281154/0053B2377332/CCAPI/ccCallSetContext:
   Context=0x46670378
1197302: Nov 19 15:43:19.559: //281154/0053B2377332/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 281154 with tag 0 to app "_ManagedAppProcess_Default"
1197303: Nov 19 15:43:19.559: //281154/0053B2377332/CCAPI/ccCallProceeding:
1197304: Nov 19 15:43:19.563: //281154/0053B2377332/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=70, Params=0x46668DC8, Progress Indication=NULL(0)
1197305: Nov 19 15:43:19.563: //281154/0053B2377332/CCAPI/ccCheckClipClir:
   In: Calling Number=1244(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
1197306: Nov 19 15:43:19.563: //281154/0053B2377332/CCAPI/ccCheckClipClir:
   Out: Calling Number=1244(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
1197307: Nov 19 15:43:19.563: //281154/0053B2377332/CCAPI/ccCallSetupRequest:
   Destination Pattern=7T, Called Number=718663625350, Digit Strip=TRUE
1197308: Nov 19 15:43:19.563: //281154/0053B2377332/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=
   Account Number=1244, Final Destination Flag=TRUE,
   Guid=0053B237-67CD-B128-7332-7301C0A8C93E, Outgoing Dial-peer=70
1197309: Nov 19 15:43:19.563: //281154/0053B2377332/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=1244
   cisco-ani=1244
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=718663625350
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
--More--                              hunt_group_timeout =0
1197310: Nov 19 15:43:19.563: //281154/0053B2377332/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x48488FC8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=1244,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=718663625350(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=70, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
1197311: Nov 19 15:43:19.567: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1197312: Nov 19 15:43:19.567: :cc_get_feature_vsa malloc success
1197313: Nov 19 15:43:19.567: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1197314: Nov 19 15:43:19.567:  cc_get_feature_vsa count is 10
1197315: Nov 19 15:43:19.567: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1197316: Nov 19 15:43:19.567: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203045408,feature_id:278479
1197317: Nov 19 15:43:19.567: //281155/0053B2377332/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
1197318: Nov 19 15:43:19.567: //281155/0053B2377332/CCAPI/ccCallSetContext:
   Context=0x46668D78
1197319: Nov 19 15:43:19.567: //281154/0053B2377332/CCAPI/ccSaveDialpeerTag:
1197320: Nov 19 15:43:19.571: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 1244
1197321: Nov 19 15:43:19.575: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x445B callID = 0xB813 switch = primary-ni interface = User
1197322: Nov 19 15:43:19.575: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x445B
Standard = CCITT
Channel ID i = 0xA98394
Exclusive, Channel 20
Calling Party Number i = 0x0081, '1244'
Called Party Number i = 0xA1, '18663625350'
1197323: Nov 19 15:43:19.947: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0xC45B
1197324: Nov 19 15:43:19.951: //281155/0053B2377332/CCAPI/cc_api_call_proceeding:
   Interface=0x48488FC8, Progress Indication=NULL(0)
1197325: Nov 19 15:43:20.591: //281151/07DA36D181B0/CCAPI/cc_api_call_media_reset_ind:
   Interface=0x0, Call Id=281151
1197326: Nov 19 15:43:20.611: //281151/07DA36D181B0/CCAPI/cc_api_call_userinfo:
   Interface=0x477101A4, Signal Indication=TONES OFF(63)
1197327: Nov 19 15:43:20.611: //281150/07DA36D181B0/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=281150
1197328: Nov 19 15:43:20.615: //281151/07DA36D181B0/CCAPI/cc_api_call_userinfo:
   Interface=0x477101A4, Signal Indication=SIGNAL RINGBACK(1)
1197329: Nov 19 15:43:20.615: //281150/07DA36D181B0/CCAPI/ccGenerateToneInfo:
--More--                              Stop Tone On Digit=FALSE, Tone=Ring Back,
1197330: Nov 19 15:43:20.619: //281151/07DA36D181B0/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
1197331: Nov 19 15:43:20.619: //281151/07DA36D181B0/CCAPI/cc_api_call_notify:
   Data Bitmask=0x7, Interface=0x477101A4, Call Id=281151
1197332: Nov 19 15:43:20.619: //281151/07DA36D181B0/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
1197333: Nov 19 15:43:20.623: //281151/07DA36D181B0/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
1197334: Nov 19 15:43:20.623: //281150/07DA36D181B0/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=281150
1197335: Nov 19 15:43:21.899: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0xC45B
1197336: Nov 19 15:43:21.903: //281155/0053B2377332/CCAPI/cc_api_call_cut_progress:
   Interface=0x48488FC8, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
1197337: Nov 19 15:43:21.903: //281155/0053B2377332/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
1197338: Nov 19 15:43:21.903: //281154/0053B2377332/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
1197339: Nov 19 15:43:21.903: //281154/0053B2377332/CCAPI/ccCallCutProgress:
1197340: Nov 19 15:43:21.907: //281155/0053B2377332/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
1197341: Nov 19 15:43:21.907: //281154/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x488EC0A4, callID1=0x44A42, callID2=0x44A43, tag=0x0)
1197342: Nov 19 15:43:21.907: //281154/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x488EC0A4, callID1=0x44A42, gcid=0-0-0-0, tag=0x0)
1197343: Nov 19 15:43:21.907: //281155/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x488EC0A4, callID2=0x44A43, gcid=0-0-0-0, tag=0x0)
1197344: Nov 19 15:43:21.907: //281154/0053B2377332/CCAPI/ccConferenceCreate:
   Conference Id=0x488EC0A4, Call Id1=281154, Call Id2=281155, Tag=0x0
1197345: Nov 19 15:43:21.907: //281154/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1197346: Nov 19 15:43:21.907: cc_api_get_xcode_stream : 4452
1197347: Nov 19 15:43:21.907: //281154/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2388D, Source Interface=0x477101A4, Source Call Id=281154,
   Destination Call Id=281155, Disposition=0x0, Tag=0x0
1197348: Nov 19 15:43:21.907: //281155/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2388D, Source Interface=0x48488FC8, Source Call Id=281155,
   Destination Call Id=281154, Disposition=0x0, Tag=0xFFFFFFFF
1197349: Nov 19 15:43:21.907: //281154/0053B2377332/CCAPI/cc_generic_bridge_done:
1197350: Nov 19 15:43:21.907: //281154/0053B2377332/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2388D, Destination Call Id=281155)
1197351: Nov 19 15:43:21.907: //281155/0053B2377332/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2388D, Destination Call Id=281154)
1197352: Nov 19 15:43:21.907: //281155/0053B2377332/CCAPI/cc_api_caps_ind:
   Destination Interface=0x477101A4, Destination Call Id=281154, Source Call Id=281155,
--More--                              Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
1197353: Nov 19 15:43:21.907: //281155/0053B2377332/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
1197354: Nov 19 15:43:21.911: //281154/0053B2377332/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2388D, Call Id1=281154, Call Id2=281155
1197355: Nov 19 15:43:21.947: //281154/0053B2377332/CCAPI/cc_api_caps_ind:
   Destination Interface=0x48488FC8, Destination Call Id=281155, Source Call Id=281154,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
1197356: Nov 19 15:43:21.947: //281154/0053B2377332/CCAPI/cc_api_caps_ind:
1197357: Nov 19 15:43:21.947: //281154/0053B2377332/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6326)
1197358: Nov 19 15:43:21.947: //281154/0053B2377332/CCAPI/cc_api_caps_ind:
1197359: Nov 19 15:43:21.947: //281154/0053B2377332/CCAPI/cc_api_caps_ind:
1197360: Nov 19 15:43:21.947: //281154/0053B2377332/CCAPI/cc_api_caps_ack:
1197361: Nov 19 15:43:21.951: //281155/0053B2377332/CCAPI/cc_api_caps_ack:
1197362: Nov 19 15:43:21.951: //281155/0053B2377332/CCAPI/cc_api_caps_ack:
1197363: Nov 19 15:43:21.955: //281155/0053B2377332/CCAPI/cc_api_voice_mode_event:
   Call Id=281155
1197364: Nov 19 15:43:21.955: //281155/0053B2377332/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x46668D78)
1197365: Nov 19 15:43:21.955: //281155/0053B2377332/CCAPI/cc_api_voice_mode_event:
   Call Id=281155
1197366: Nov 19 15:43:21.955: //281155/0053B2377332/CCAPI/cc_api_voice_mode_event:
1197367: Nov 19 15:43:22.119: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0xC45B
1197368: Nov 19 15:43:22: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 13045453404 N/A
1197369: Nov 19 15:43:22: %ISDN-6-CONNECT: Interface Serial0/0/0:19 is now connected to 18663625350 N/A
1197370: Nov 19 15:43:22: %ISDN-6-CONNECT: Interface Serial0/0/0:19 is now connected to 18663625350 N/A
1197371: Nov 19 15:43:22: %ISDN-6-CONNECT: Interface Serial0/0/0:19 is now connected to 18663625350 N/A
1197372: Nov 19 15:43:22.127: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x445B
--More--                           1197373: Nov 19 15:43:22.127: //281155/0053B2377332/CCAPI/cc_api_call_connected:
   Interface=0x48488FC8, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
1197374: Nov 19 15:43:22.127: //281155/0053B2377332/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
1197375: Nov 19 15:43:22.131: //281154/0053B2377332/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
1197376: Nov 19 15:43:22.131: //281155/0053B2377332/CCAPI/cc_api_get_called_ccm_detected:
1197377: Nov 19 15:43:22.131: //281154/0053B2377332/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
1197378: Nov 19 15:43:28: %ISDN-6-CONNECT: Interface Serial0/0/0:19 is now connected to 18663625350 N/A
1197379: Nov 19 15:43:29.647: //281151/07DA36D181B0/CCAPI/cc_api_call_userinfo:
1197380: Nov 19 15:43:29.647: //281151/07DA36D181B0/CCAPI/cc_api_call_userinfo:
   Interface=0x477101A4, Signal Indication=NOT PRESENT(255)
1197381: Nov 19 15:43:29.651: //281151/07DA36D181B0/CCAPI/cc_api_call_userinfo:
1197382: Nov 19 15:43:29.651: //281150/07DA36D181B0/CCAPI/ccGenerateToneInfo:
1197383: Nov 19 15:43:29.651: //281150/07DA36D181B0/CCAPI/ccCallUserInfo:
   Call Id=281150
1197384: Nov 19 15:43:29.655: //281150/07DA36D181B0/CCAPI/ccGenerateToneInfo:
1197385: Nov 19 15:43:29.791: //281151/07DA36D181B0/CCAPI/cc_api_caps_ind:
   Destination Interface=0x48488FC8, Destination Call Id=281150, Source Call Id=281151,
1197386: Nov 19 15:43:29.791: //281151/07DA36D181B0/CCAPI/cc_api_caps_ind:
1197387: Nov 19 15:43:29.791: //281151/07DA36D181B0/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5487)
1197388: Nov 19 15:43:29.791: //281150/07DA36D181B0/CCAPI/cc_api_caps_ack:
   Destination Interface=0x477101A4, Destination Call Id=281151, Source Call Id=281150,
1197389: Nov 19 15:43:29.795: //281150/07DA36D181B0/CCAPI/cc_api_voice_mode_event:
   Call Id=281150
1197390: Nov 19 15:43:29.795: //281150/07DA36D181B0/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x4898C918)
1197391: Nov 19 15:43:29.847: //281151/07DA36D181B0/CCAPI/cc_api_set_called_ccm_detected:
1197392: Nov 19 15:43:29.847: //281151/07DA36D181B0/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x477101A4, Call Id=281151
1197393: Nov 19 15:43:29.847: //281151/07DA36D181B0/CCAPI/cc_api_call_userinfo:
1197394: Nov 19 15:43:29.851: //281151/07DA36D181B0/CCAPI/cc_api_set_called_ccm_detected:
--More--                              CallInfo(called ccm detected=TRUE ccmVersion 3)
1197395: Nov 19 15:43:29.851: //281151/07DA36D181B0/CCAPI/cc_api_call_notify:
1197396: Nov 19 15:43:29.851: //281151/07DA36D181B0/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
1197397: Nov 19 15:43:29.851: //281151/07DA36D181B0/CCAPI/cc_api_get_ccm_detected:
1197398: Nov 19 15:43:29.851: //281150/07DA36D181B0/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=281150
1197399: Nov 19 15:43:29.851: //281150/07DA36D181B0/CCAPI/ccGenerateToneInfo:
1197400: Nov 19 15:43:29.855: //281151/07DA36D181B0/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
1197401: Nov 19 15:43:29.855: //281151/07DA36D181B0/CCAPI/cc_api_get_ccm_detected:
1197402: Nov 19 15:43:29.855: //281150/07DA36D181B0/CCAPI/ccCallNotify:
1197403: Nov 19 15:43:34.256: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0136
Standard = CCITT
Channel ID i = 0xA98382
Invoke Id = 1
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '3047576542'
Called Party Number i = 0xA1, '3047200974'
1197404: Nov 19 15:43:34.260: ISDN Se0/0/0:23 Q931: Received SETUP  callref = 0x8136 callID = 0x438A switch = primary-ni interface = User
1197405: Nov 19 15:43:34.264: //-1/17990C4C81B1/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=3047576542
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=3047200974
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
--More--                              cisco-rdn=
--More--                              cisco-rdntype=-1
--More--                              cisco-rdnplan=-1
--More--                              cisco-rdnpi=-1
--More--                              cisco-rdnsi=-1
--More--                              cisco-redirectreason=-1   fwd_final_type =0
--More--                              final_redirectNumber =
--More--
--More--                           1197406: Nov 19 15:43:34.268: //-1/17990C4C81B1/CCAPI/cc_api_call_setup_ind_common:
--More--                              Interface=0x48488FC8, Call Info(
--More--                              Calling Number=3047576542,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
--More--                              Called Number=3047200974(TON=National, NPI=ISDN),
--More--                              Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
--More--                              Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
--More--                              Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
--More--                           1197407: Nov 19 15:43:34.268: //-1/17990C4C81B1/CCAPI/ccCheckClipClir:
--More--                              In: Calling Number=3047576542(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
--More--                           1197408: Nov 19 15:43:34.268: //-1/17990C4C81B1/CCAPI/ccCheckClipClir:
--More--                              Out: Calling Number=3047576542(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
--More--                           1197409: Nov 19 15:43:34.268: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
--More--
--More--                           1197410: Nov 19 15:43:34.268: :cc_get_feature_vsa malloc success
--More--                           1197411: Nov 19 15:43:34.268: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
--More--
--More--                           1197412: Nov 19 15:43:34.268:  cc_get_feature_vsa count is 11
--More--                           1197413: Nov 19 15:43:34.268: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
--More--
--More--                           1197414: Nov 19 15:43:34.268: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203045184,feature_id:278480
--More--                           1197415: Nov 19 15:43:34.268: //281156/17990C4C81B1/CCAPI/cc_api_call_setup_ind_common:
--More--                              Set Up Event Sent;
--More--                              Call Info(Calling Number=3047576542(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
--More--                              Called Number=3047200974(TON=National, NPI=ISDN))
--More--                           1197416: Nov 19 15:43:34.272: //281156/17990C4C81B1/CCAPI/cc_process_call_setup_ind:
--More--                              Event=0x4758E8E8
--More--                           1197417: Nov 19 15:43:34.272: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
--More--                              Try with the demoted called number 3047200974
--More--                           1197418: Nov 19 15:43:34.272: //281156/17990C4C81B1/CCAPI/ccCallSetContext:
--More--                              Context=0x48983598
--More--                           1197419: Nov 19 15:43:34.272: //281156/17990C4C81B1/CCAPI/cc_process_call_setup_ind:
--More--                              >>>>CCAPI handed cid 281156 with tag 1 to app "_ManagedAppProcess_Default"
--More--                           1197420: Nov 19 15:43:34.272: //281156/17990C4C81B1/CCAPI/ccCallProceeding:
--More--                              Progress Indication=NULL(0)
--More--                           1197421: Nov 19 15:43:34.276: //281156/17990C4C81B1/CCAPI/ccCallSetupRequest:
--More--                              Destination=, Calling IE Present=TRUE, Mode=0,
--More--                              Outgoing Dial-peer=17, Params=0x46667F08, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
--More--                           1197422: Nov 19 15:43:34.276: //281156/17990C4C81B1/CCAPI/ccCheckClipClir:
--More--                           1197423: Nov 19 15:43:34.276: //281156/17990C4C81B1/CCAPI/ccCheckClipClir:
--More--                           1197424: Nov 19 15:43:34.280: //281156/17990C4C81B1/CCAPI/ccCallSetupRequest:
--More--                              Destination Pattern=3047200974, Called Number=3047200974, Digit Strip=FALSE
--More--                           1197425: Nov 19 15:43:34.280: //281156/17990C4C81B1/CCAPI/ccCallSetupRequest:
--More--                              Calling Number=3047576542(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
--More--                              Redirect Number=, Display Info=
--More--                              Account Number=, Final Destination Flag=TRUE,
--More--                              Guid=17990C4C-5092-11E3-81B1-0024C44C9758, Outgoing Dial-peer=17
--More--                           1197426: Nov 19 15:43:34.280: //281156/17990C4C81B1/CCAPI/cc_api_display_ie_subfields:
--More--                              ccCallSetupRequest:
--More--                              cisco-username=
--More--                              ----- ccCallInfo IE subfields -----
--More--                              cisco-ani=3047576542
--More--                              cisco-anitype=2
--More--                              cisco-aniplan=1
--More--                              cisco-anipi=0
--More--                              cisco-anisi=3
--More--                              dest=3047200974
--More--                              cisco-desttype=2
--More--                              cisco-destplan=1
--More--                              cisco-rdie=FFFFFFFF
--More--                              cisco-rdn=
--More--
--More--                           1197427: Nov 19 15:43:34.280: //281156/17990C4C81B1/CCAPI/ccIFCallSetupRequestPrivate:
--More--                              Interface=0x477101A4, Interface Type=1, Destination=, Mode=0x0,
--More--                              Call Params(Calling Number=3047576542,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
--More--                              Called Number=3047200974(TON=National, NPI=ISDN), Calling Translated=FALSE,
--More--                              Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=17, Call Count On=FALSE,
--More--                              Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
--More--                           1197428: Nov 19 15:43:34.280: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
--More--
--More--                           1197429: Nov 19 15:43:34.280: :cc_get_feature_vsa malloc success
--More--                           1197430: Nov 19 15:43:34.280: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
--More--
--More--                           1197431: Nov 19 15:43:34.280:  cc_get_feature_vsa count is 12
--More--                           1197432: Nov 19 15:43:34.280: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
--More--
--More--                           1197433: Nov 19 15:43:34.280: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203044960,feature_id:278481
--More--                           1197434: Nov 19 15:43:34.280: //281157/17990C4C81B1/CCAPI/ccIFCallSetupRequestPrivate:
--More--                              SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
--More--                           1197435: Nov 19 15:43:34.280: //281157/17990C4C81B1/CCAPI/ccCallSetContext:
--More--                              Context=0x46667EB8
--More--                           1197436: Nov 19 15:43:34.280: //281156/17990C4C81B1/CCAPI/ccSaveDialpeerTag:
--More--                           1197437: Nov 19 15:43:34.288: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8136
--More--                                     Channel ID i = 0xA98382
--More--                                               Exclusive, Channel 2
--More--                           1197438: Nov 19 15:43:34.304: //281157/17990C4C81B1/CCAPI/cc_api_set_called_ccm_detected:
--More--                           1197439: Nov 19 15:43:34.304: //281157/17990C4C81B1/CCAPI/cc_api_call_proceeding:
--More--                              Interface=0x477101A4, Progress Indication=NULL(0)
--More--                           1197440: Nov 19 15:43:34.308: //281157/17990C4C81B1/CCAPI/cc_api_set_called_ccm_detected:
--More--                           1197441: Nov 19 15:43:34.312: //281157/17990C4C81B1/CCAPI/cc_api_set_delay_xport:
--More--                              CallInfo(delay xport=TRUE)
--More--                           1197442: Nov 19 15:43:34.312: //281157/17990C4C81B1/CCAPI/cc_api_call_alert:
--More--                              Interface=0x477101A4, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
--More--                           1197443: Nov 19 15:43:34.312: //281157/17990C4C81B1/CCAPI/cc_api_call_alert:
--More--                              Call Entry(Retry Count=0, Responsed=TRUE)
--More--                           1197444: Nov 19 15:43:34.312: //281156/17990C4C81B1/CCAPI/ccCallAlert:
--More--                              Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
--More--                           1197445: Nov 19 15:43:34.312: //281156/17990C4C81B1/CCAPI/ccCallAlert:
--More--                              Call Entry(Responsed=TRUE, Alert Sent=TRUE)
--More--                           1197446: Nov 19 15:43:34.316: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x8136
--More--                           1197447: Nov 19 15:43:34.504: //281157/17990C4C81B1/CCAPI/cc_api_set_called_ccm_detected:
--More--                           1197448: Nov 19 15:43:34.504: //281157/17990C4C81B1/CCAPI/cc_api_call_notify:
--More--                              Data Bitmask=0x7, Interface=0x477101A4, Call Id=281157
--More--                           1197449: Nov 19 15:43:34.504: //281157/17990C4C81B1/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
--More--                              CallInfo(ssCTreRoutingNotSupported=FALSE)
--More--                           1197450: Nov 19 15:43:34.504: //281157/17990C4C81B1/CCAPI/cc_api_get_ccm_detected:
--More--                              CallInfo(ccm detected=TRUE)
--More--                           1197451: Nov 19 15:43:34.504: //281156/17990C4C81B1/CCAPI/ccCallNotify:
--More--                              Data Bitmask=0x7, Call Id=281156
--More--                           1197452: Nov 19 15:43:35.108: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x0136
--More--                                     Facility i = 0x9F8B0100A117020101020100800F415453202020202020202020202020
--More--                                               Protocol Profile =  Networking Extensions
--More--                                               0xA117020101020100800F415453202020202020202020202020
--More--                                               Component = Invoke component
--More--                                                         Invoke Id = 1
--More--                                                         Operation = CallingName
--More--        Name Presentation Allowed Extended
--More--        Name = ATS
--More--                           1197453: Nov 19 15:43:35.112: //281156/17990C4C81B1/CCAPI/cc_api_call_facility:
--More--                              Interface=0x48488FC8, Call Id=281156
--More--                           1197454: Nov 19 15:43:35.112: //281157/17990C4C81B1/CCAPI/ccCallFacility:
--More--                              Call Id=281157
--More--                           1197455: Nov 19 15:43:35.112: //281156/17990C4C81B1/CCAPI/cc_api_get_called_ccm_detected:
--More--                              CallInfo(ccm detected=0)
--More--                           1197456: Nov 19 15:43:36.260: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x0135
--More--                                     Cause i = 0x8090 - Normal call clearing
--More--                           1197457: Nov 19 15:43:36: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 3045618701 , call lasted 24 seconds
--More--                           1197458: Nov 19 15:43:36.264: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x8135
--More--                           1197459: Nov 19 15:43:36.264: //281150/07DA36D181B0/CCAPI/cc_api_call_disconnected:
--More--                              Cause Value=16, Interface=0x48488FC8, Call Id=281150
--More--                           1197460: Nov 19 15:43:36.264: //281150/07DA36D181B0/CCAPI/cc_api_call_disconnected:
--More--                              Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
--More--                           1197461: Nov 19 15:43:36.268: //281150/07DA36D181B0/CCAPI/ccConferenceDestroy:
--More--                              Conference Id=0x2388C, Tag=0x0
--More--                           1197462: Nov 19 15:43:36.268: //281150/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
--More--                              Conference Id=0x2388C, Source Interface=0x48488FC8, Source Call Id=281150,
--More--                              Destination Call Id=281151, Disposition=0x0, Tag=0x0
--More--                           1197463: Nov 19 15:43:36.268: //281151/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
--More--                              Conference Id=0x2388C, Source Interface=0x477101A4, Source Call Id=281151,
--More--                              Destination Call Id=281150, Disposition=0x0, Tag=0x0
--More--                           1197464: Nov 19 15:43:36.268: //281150/07DA36D181B0/CCAPI/cc_generic_bridge_done:
--More--                           1197465: Nov 19 15:43:36.268: //281150/07DA36D181B0/CCAPI/ccCallDisconnect:
--More--                              Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
--More--                           1197466: Nov 19 15:43:36.268: //281150/07DA36D181B0/CCAPI/ccCallDisconnect:
--More--                              Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
--More--                           1197467: Nov 19 15:43:36.268: //281150/07DA36D181B0/CCAPI/cc_api_get_transfer_info:
--More--                              Transfer Number Is Null
--More--                           1197468: Nov 19 15:43:36.272: //281151/07DA36D181B0/CCAPI/ccCallDisconnect:
--More--                              Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
--More--                           1197469: Nov 19 15:43:36.272: //281151/07DA36D181B0/CCAPI/ccCallDisconnect:
--More--                           1197470: Nov 19 15:43:36.272: //281151/07DA36D181B0/CCAPI/cc_api_get_transfer_info:
--More--                           1197471: Nov 19 15:43:36.284: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0135
--More--                           1197472: Nov 19 15:43:36.288: //281151/07DA36D181B0/CCAPI/cc_api_get_transfer_info:
--More--                           1197473: Nov 19 15:43:36.292: //281151/07DA36D181B0/CCAPI/cc_api_call_disconnect_done:
--More--                              Disposition=0, Interface=0x477101A4, Tag=0x0, Call Id=281151,
--More--                              Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
--More--                           1197474: Nov 19 15:43:36.292: //281151/07DA36D181B0/CCAPI/cc_api_call_disconnect_done:
--More--                              Call Disconnect Event Sent
--More--                           1197475: Nov 19 15:43:36.292: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
--More--
--More--                           1197476: Nov 19 15:43:36.296: :cc_free_feature_vsa freeing 47B505D8
--More--                           1197477: Nov 19 15:43:36.296: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
--More--
--More--                           1197478: Nov 19 15:43:36.296:  vsacount in free is 11
--More--                           1197479: Nov 19 15:43:36.312: //281150/07DA36D181B0/CCAPI/cc_api_call_disconnect_done:
--More--                              Disposition=0, Interface=0x48488FC8, Tag=0x0, Call Id=281150,
--More--                           1197480: Nov 19 15:43:36.312: //281150/07DA36D181B0/CCAPI/cc_api_call_disconnect_done:
--More--                           1197481: Nov 19 15:43:36.312: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
--More--
--More--                           1197482: Nov 19 15:43:36.312: :cc_free_feature_vsa freeing 47B506B8
--More--                           1197483: Nov 19 15:43:36.312: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
--More--
--More--                           1197484: Nov 19 15:43:36.312:  vsacount in free is 10
--More--                           1197485: Nov 19 15:43:40.920: //281154/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
--More--                              Consume mask is not set. Relaying Digit 2 to dstCallId 0x44A43
--More--                           1197486: Nov 19 15:43:40.920: //281154/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
--More--                              Check DTMF relay digit begin for 3way conf
--More--                           1197487: Nov 19 15:43:41.020: //281154/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
--More--                           1197488: Nov 19 15:43:41.020: //281154/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
--More--                              Check DTMF relay digit end for 3way conf
1197489: Nov 19 15:43:44.344: //281157/17990C4C81B1/CCAPI/cc_api_set_called_ccm_detected:
1197490: Nov 19 15:43:44.344: //281157/17990C4C81B1/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x477101A4, Call Id=281157
1197491: Nov 19 15:43:44.344: //281157/17990C4C81B1/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
1197492: Nov 19 15:43:44.344: //281157/17990C4C81B1/CCAPI/cc_api_get_ccm_detected:
1197493: Nov 19 15:43:44.344: //281156/17990C4C81B1/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=281156
1197494: Nov 19 15:43:44.460: //281157/17990C4C81B1/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
1197495: Nov 19 15:43:44.540: //281157/17990C4C81B1/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x477101A4, Call Id=281157
1197496: Nov 19 15:43:44.540: //281157/17990C4C81B1/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
1197497: Nov 19 15:43:44.540: //281156/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
1197498: Nov 19 15:43:44.540: //281157/17990C4C81B1/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=281157
1197499: Nov 19 15:43:44.540: //281157/17990C4C81B1/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
1197500: Nov 19 15:43:44.544: //281157/17990C4C81B1/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
1197501: Nov 19 15:43:44.544: //281157/17990C4C81B1/CCAPI/cc_api_get_transfer_info:
1197502: Nov 19 15:43:44.544: //281156/17990C4C81B1/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=281156
1197503: Nov 19 15:43:44.548: //281157/17990C4C81B1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x477101A4, Tag=0x0, Call Id=281157,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
1197504: Nov 19 15:43:44.548: //281157/17990C4C81B1/CCAPI/cc_api_call_disconnect_done:
1197505: Nov 19 15:43:44.548: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1197506: Nov 19 15:43:44.548: :cc_free_feature_vsa freeing 47B50258
1197507: Nov 19 15:43:44.548: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1197508: Nov 19 15:43:44.548:  vsacount in free is 9
1197509: Nov 19 15:43:44.552: //281156/17990C4C81B1/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=11, Params=0x4665FA48, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
1197510: Nov 19 15:43:44.552: //281156/17990C4C81B1/CCAPI/ccCheckClipClir:
1197511: Nov 19 15:43:44.552: //281156/17990C4C81B1/CCAPI/ccCheckClipClir:
   Out: Calling Number=3043468920(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
1197512: Nov 19 15:43:44.552: //281156/17990C4C81B1/CCAPI/ccCallSetupRequest:
   Destination Pattern=30472009[01678]., Called Number=3047200974, Digit Strip=FALSE
1197513: Nov 19 15:43:44.552: //281156/17990C4C81B1/CCAPI/ccCallSetupRequest:
   Calling Number=3043468920(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Guid=17990C4C-5092-11E3-81B1-0024C44C9758, Outgoing Dial-peer=11
1197514: Nov 19 15:43:44.552: //281156/17990C4C81B1/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=3043468920
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=3047200974
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
1197515: Nov 19 15:43:44.552: //281156/17990C4C81B1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x479DA4B0, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=3043468920,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=11, Call Count On=FALSE,
1197516: Nov 19 15:43:44.552: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1197517: Nov 19 15:43:44.556: :cc_get_feature_vsa malloc success
1197518: Nov 19 15:43:44.556: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1197519: Nov 19 15:43:44.556:  cc_get_feature_vsa count is 10
1197520: Nov 19 15:43:44.556: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1197521: Nov 19 15:43:44.556: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203044960,feature_id:278482
1197522: Nov 19 15:43:44.556: //281158/17990C4C81B1/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
1197523: Nov 19 15:43:44.556: //281158/17990C4C81B1/CCAPI/ccCallSetContext:
   Context=0x4665F9F8
1197524: Nov 19 15:43:44.556: //281156/17990C4C81B1/CCAPI/ccSaveDialpeerTag:
1197525: Nov 19 15:43:44.560: //281158/17990C4C81B1/CCAPI/cc_api_call_proceeding:
   Interface=0x479DA4B0, Progress Indication=NULL(0)
1197526: Nov 19 15:43:44.576: //281158/17990C4C81B1/CCAPI/cc_api_call_alert:
   Interface=0x479DA4B0, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
1197527: Nov 19 15:43:44.576: //281158/17990C4C81B1/CCAPI/cc_api_call_alert:
1197528: Nov 19 15:43:44.576: //281156/17990C4C81B1/CCAPI/ccCallAlert:
1197529: Nov 19 15:43:44.576: //281156/17990C4C81B1/CCAPI/ccCallAlert:
1197530: Nov 19 15:43:44.576: //281156/17990C4C81B1/CCAPI/ccGenerateToneInfo:
1197531: Nov 19 15:43:44.604: //281158/17990C4C81B1/CCAPI/cc_api_call_connected:
   Interface=0x479DA4B0, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
1197532: Nov 19 15:43:44.604: //281158/17990C4C81B1/CCAPI/cc_api_call_connected:
1197533: Nov 19 15:43:44.604: //281156/17990C4C81B1/CCAPI/ccGenerateToneInfo:
1197534: Nov 19 15:43:44.604: //281156/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x488EC20C, callID1=0x44A44, callID2=0x44A46, tag=0x0)
1197535: Nov 19 15:43:44.604: //281156/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x488EC20C, callID1=0x44A44, gcid=17990C4C-509211E3-81B10024-C44C9758, tag=0x0)
1197536: Nov 19 15:43:44.604: //281158/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x488EC20C, callID2=0x44A46, gcid=17990C4C-509211E3-81B10024-C44C9758, tag=0x0)
1197537: Nov 19 15:43:44.608: //281156/17990C4C81B1/CCAPI/ccConferenceCreate:
   Conference Id=0x488EC20C, Call Id1=281156, Call Id2=281158, Tag=0x0
1197538: Nov 19 15:43:44.608: //281156/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2388E, Source Interface=0x48488FC8, Source Call Id=281156,
   Destination Call Id=281158, Disposition=0x0, Tag=0xFFFFFFFF
1197539: Nov 19 15:43:44.608: //281158/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1197540: Nov 19 15:43:44.608: cc_api_get_xcode_stream : 4452
1197541: Nov 19 15:43:44.608: //281158/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2388E, Source Interface=0x479DA4B0, Source Call Id=281158,
   Destination Call Id=281156, Disposition=0x0, Tag=0x0
1197542: Nov 19 15:43:44.608: //281156/17990C4C81B1/CCAPI/cc_generic_bridge_done:
1197543: Nov 19 15:43:44.608: //281156/17990C4C81B1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2388E, Destination Call Id=281158)
1197544: Nov 19 15:43:44.608: //281158/17990C4C81B1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2388E, Destination Call Id=281156)
1197545: Nov 19 15:43:44.608: //281156/17990C4C81B1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x479DA4B0, Destination Call Id=281158, Source Call Id=281156,
1197546: Nov 19 15:43:44.608: //281156/17990C4C81B1/CCAPI/cc_api_caps_ind:
1197547: Nov 19 15:43:44.608: //281158/17990C4C81B1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x48488FC8, Destination Call Id=281156, Source Call Id=281158,
   Caps(Codec=0x1, Fax Rate=0x80, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
1197548: Nov 19 15:43:44.612: //281158/17990C4C81B1/CCAPI/cc_api_caps_ind:
--More--                              Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
1197549: Nov 19 15:43:44.612: //281158/17990C4C81B1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_14400(0x80), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=274)
1197550: Nov 19 15:43:44.612: //281156/17990C4C81B1/CCAPI/cc_api_caps_ack:
1197551: Nov 19 15:43:44.612: //281156/17990C4C81B1/CCAPI/cc_api_voice_mode_event:
   Call Id=281156
1197552: Nov 19 15:43:44.616: //281156/17990C4C81B1/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x48983598)
1197553: Nov 19 15:43:44.616: //281156/17990C4C81B1/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2388E, Call Id1=281156, Call Id2=281158
1197554: Nov 19 15:43:44.616: //281156/17990C4C81B1/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
1197555: Nov 19 15:43:44.616: //281156/17990C4C81B1/CCAPI/ccCallConnect:
1197556: Nov 19 15:43:44.620: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x8136
1197557: Nov 19 15:43:44.644: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0136
1197558: Nov 19 15:43:44: %ISDN-6-CONNECT: Interface Serial0/0/0:1 is now connected to 3047576542 N/A
1197559: Nov 19 15:43:44: %ISDN-6-CONNECT: Interface Serial0/0/0:1 is now connected to 3047576542 N/A
1197560: Nov 19 15:43:44: %ISDN-6-CONNECT: Interface Serial0/0/0:1 is now connected to 3047576542 N/A
1197561: Nov 19 15:43:47.484: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x0136
Cause i = 0x8A90 - Normal call clearing
1197562: Nov 19 15:43:47: %ISDN-6-CONNECT: Interface Serial0/0/0:1 is now connected to 3047576542 N/A
1197563: Nov 19 15:43:47: %ISDN-6-DISCONNECT: Interface Serial0/0/0:1  disconnected from 3047576542 , call lasted 2 seconds
1197564: Nov 19 15:43:47.492: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x8136
1197565: Nov 19 15:43:47.492: //281156/17990C4C81B1/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x48488FC8, Call Id=281156
1197566: Nov 19 15:43:47.492: //281156/17990C4C81B1/CCAPI/cc_api_call_disconnected:
1197567: Nov 19 15:43:47.492: //281156/17990C4C81B1/CCAPI/ccConferenceDestroy:
   Conference Id=0x2388E, Tag=0x0
1197568: Nov 19 15:43:47.492: //281156/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=281158, Disposition=0x0, Tag=0x0
1197569: Nov 19 15:43:47.496: //281158/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
1197570: Nov 19 15:43:47.496: //281156/17990C4C81B1/CCAPI/cc_generic_bridge_done:
1197571: Nov 19 15:43:47.496: //281156/17990C4C81B1/CCAPI/ccCallDisconnect:
1197572: Nov 19 15:43:47.496: //281156/17990C4C81B1/CCAPI/ccCallDisconnect:
1197573: Nov 19 15:43:47.496: //281156/17990C4C81B1/CCAPI/cc_api_get_transfer_info:
1197574: Nov 19 15:43:47.500: //281158/17990C4C81B1/CCAPI/ccCallDisconnect:
1197575: Nov 19 15:43:47.500: //281158/17990C4C81B1/CCAPI/ccCallDisconnect:
1197576: Nov 19 15:43:47.508: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0136
1197577: Nov 19 15:43:47.520: //281158/17990C4C81B1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x479DA4B0, Tag=0x0, Call Id=281158,
1197578: Nov 19 15:43:47.520: //281158/17990C4C81B1/CCAPI/cc_api_call_disconnect_done:
1197579: Nov 19 15:43:47.520: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1197580: Nov 19 15:43:47.520: :cc_free_feature_vsa freeing 47B50258
1197581: Nov 19 15:43:47.520: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1197582: Nov 19 15:43:47.520:  vsacount in free is 9
1197583: Nov 19 15:43:47.532: //281156/17990C4C81B1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48488FC8, Tag=0x0, Call Id=281156,
1197584: Nov 19 15:43:47.532: //281156/17990C4C81B1/CCAPI/cc_api_call_disconnect_done:
1197585: Nov 19 15:43:47.532: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1197586: Nov 19 15:43:47.532: :cc_free_feature_vsa freeing 47B50338
1197587: Nov 19 15:43:47.532: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1197588: Nov 19 15:43:47.532:  vsacount in free is 8
CTS-2811#      undebug all
All possible debugging has been turned off
CTS-2811#exit
1 ACCEPTED SOLUTION
Re:Calls coming into a number are forwarded to a fax machine
Greg,
The call is initially routed via dial peer 17. However, it fails with a reason code 47 (Resource Unavailable). Then, the gateway routes the call via dial peer 11 as the next best match.
So, we need to address the issue where the call is failing with cause code 47.
Please try to configure a voice class codec containing g711 and g729.
Then remove the codec (g711) from dial peer and add the voice class codec to it.
Jagpreet Singh Barmi
Sent from Cisco Technical Support Android App for Nexus 7
Hi Gregory,
I had a quick look at the logs.
Recieved SETUP message from PRI.
Standard = CCITT
Invoke Id = 1
Dial peer 1 Selected as the Incoming dial peer.
Dial peer 17 selected as the Outgoing dial peer.
cc_api_call_disconnected with cause value of 47.
Then the outgoing dial peer changed to 11.
The call for connected.
We need to check the running config of the gateway to check the dial peers 17 and 11.
Also, the Route Plan report with corresponding CUCM traces would be helpful.
HTH,
Below are the dial-peers as you can see dial peer 11 is their fax machine:
Dial Peers:
dial-peer voice 11 voip
answer-address 3043468920
destination-pattern 30472009[01678].
no modem passthrough
session protocol sipv2
session target ipv4:192.168.200.7
dtmf-relay h245-signal
codec g711ulaw
fax rate 14400
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback none
clid network-number 3043468920
no vad
dial-peer voice 17 voip
destination-pattern 3047200974
modem passthrough nse codec g711ulaw
session target ipv4:192.168.201.20
dtmf-relay h245-alphanumeric
fax rate disable
no vad
I am going to work on the route plan report and the traces as well but figured I would give you this information first.
Greg
Greg,
Both the dial peers point to different IP addresses. Are they both CUCM servers?
If not, please let us know what these devices are?
-Jagpreet Singh Barmi
the. 7 is a fax server that we do not take care of, the customer had it setup by another vendor.  The .20 is the cucm and it is business edition with unity connection integrated.
I noticed if I change the destination pattern in dial peer 11 from [01678]. to [01235689] then the call to the number 3047200974 goes through as normal and reaches his voice mail
Does it seem to you that these dial-peers as setup are conflicting somehow?
Greg,
You want me to do this for dial peer 17 correct?
Yes...
183
