calls disconnect
Hi Guys,
I have a problem with some calls. When we try to call (PSTN to IPTel) the calls are direclty disconnect (not all some works, and some don't work)
In the SDI traces I have the following:
|3,100,152,1.894691^10.187.38.8^*
17:26:37.065 |<MN::MGCPEndPoint><MV::*@BEGWAYZE.MTSINTRA.NETWORK>|3,100,152,1.894691^*^*
17:26:37.065 |MGCPHandler send msg SUCCESSFULLY to: 10.187.38.8
200 659355451
17:26:37.093 |MGCPManager remove recent Incoming transId 659355449|3,100,152,1.894689^10.187.38.8^*
17:26:47.764 | |*^*^*
17:26:47.764 |In  Message -- BriSetupMsg -- Protocol= BriProtocol|*^*^*
17:26:47.764 |Ie - BriBearerCapabilityIe -- IEData= 04 03 80 90 A3 |*^*^*
17:26:47.764 |MGCPBhHandler 10.187.38.8 - TCP msg available from Device|3,100,153,1.63740^10.187.38.8^*
17:26:47.764 |MGCPBhHandler - Receiving BhHdr: 0004 0000 0011 8001 0001 0029
17:26:47.764 |Ie - BriChannelIdIe -- IEData= 18 01 89 |*^*^*
17:26:47.765 |Ie - Q931CallingPartyIe -- IEData= 6C 0B 21 83 34 37 30 38 35 30 33 33 36 |*^*^*
17:26:47.765 |Ie - Q931CalledPartyIe -- IEData= 70 09 A1 32 34 38 31 35 30 35 30 |*^*^*
17:26:47.765 |Ie - Q931HighLayerCompatibilityIe -- IEData= 7D 02 91 81 |*^*^*
17:26:47.765 |MMan_Id= 0. (iep=  0 dsl= 8001 sapi=  0 ces= 0 IpAddr=826bb0a IpPort=2427)|*^*^*
17:26:47.765 |IsdnMsgData1= 08 01 0A 05 A1 04 03 80 90 A3 18 01 89 6C 0B 21 83 34 37 30 38 35 30 33 33 36 70 09 A1 32 34 38 31 35 30 35 30 7D 02 91 81 |*^*^*
17:26:47.765 | |*^*^*
17:26:47.765 |Out Message -- BriReleaseCompleteMsg -- Protocol= BriProtocol|*^*^*
17:26:47.765 |IsdnMsgData2= 08 01 8A 5A |*^*^*
17:26:47.765 |MGCPBrid - briSetupSlotReq failed for channel 1|3,100,153,1.63740^10.187.38.8^*
17:26:47.765 |MGCPBhHandler - Sending BhHdr: 0004 0000 0010 8001 0001 0004
17:26:52.065 |MGCPHandler received msg from: 10.187.38.8
NTFY 659355452 *@BEGWAYZE.MTSINTRA.NETWORK MGCP 0.1
X: 0
O:
One of you can give me some explaination about that line ?
Hervé Jacquemin
Everyone's tags (2)
1 REPLY
Hall of Fame Super Gold
Re: calls disconnect
Take "debug isdn 931" with "term mon" for a failed call on the GW. Do not take other debugs.
Not however thatMGCP for BRI is not a good choice, you would have safe results with H.323 or SIP instead.
279
