********************Calls disconnected Cause*******************
Hi Pros,
My voice gw displays this :
Successful Calls = 0, Failed Calls = 6, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "39 "
That is 39 means.
Looked on cisco web site,I could not find a doc that explains the cause. Can one of you point that explains all the cause of a call failing.
Thanks in advance,
Crazy
Re: ********************Calls disconnected Cause****************
Table 1 Disconnect Cause Code Values
http://www.cisco.com/iam/unified/ipt611/Using_Call_Flows_to_Resolve_Call_Processing_Problems.htm#wp1142841
java
if this helps, please rate
java
www.cisco.com/go/pdi
doc says: 39 means Permanent frame mode connection is out of service.
What does that means?
Sorry bor my silly question.
Crazy
Hall of Fame Super Gold
Do the actual call with the appropriate debugs.
That will be more informative that the output above.
104
