Silver
Calls dropping H323
I`v set up a connection between a CUCM6 and a GWA using H323 connection - IP only no physical cable. This GW in turn connects to two other GW`s and finally to a CUCM using MGCP. When I call from CUCM 6 to the other CUCM the call is set up and connected but drops after 60 secs or so. The debug shows resource unavailable using G711 on both devices. If I repeat the test but now connect to GWA from CUCM6 using a physical H323 connection then everything is fine and the call stays up - any ideas , what debugs to run etc
thanks
Green
Re: Calls dropping H323
Mmm can you let us know mor einformation about those 2 other GWs, are they VGW? or regular routers?
which exact cucm version and ios.
Run for the h.323
debug h225 asn1
debug h245 asn1
debug voice ccapi ino
fro mgcp
debug mgcp packet
for both detail cucm traces sdi and sdl traces
Make sure G711 is used all the way (or xcoder in place)
any firewall?
Silver
The GW`s are Voice GW`s using 12.4 IOS
Two different call flow
Call Flow1
CUCM Cluster 1 views GW1 as a H323 GW without any physical connection. VOIP Dial-Peers between GW1 and GW2 and a physical connection betwene GW2 and CUCM, Cluster2
Call FLow 2 same as above but Cluster 1 CUCM now conectes to the same GW1 as before but using RJ 45 MGCP, H323
All GW use the same IOS, if I change the configuraion so that the CUCM CLuster 1 now uses MGCP to GW1 the calls stay up ok
287
