02-19-2014 11:11 AM - edited 03-16-2019 09:49 PM
Hello. I am wondering if anybody can assist with a problem I am having. I have a client with a UC560, using a SIP trunk. Calls are able to make it to the UC from the outside, and are answered by the Auto attendant. When you dial a persons extension and they do not answer you never hear their VM greeting. You just get silence.
Internal calls do not have an issue
I have worked with Cisco on this but they have yet to come up with a resolution, and have suggested that I downgrade my Uc560 to 8.6, from 8.6.1. I am not completely thrilled with that prospect.
The way we have the system configured is as follows:
The ISP (Windstream) has a modem installed at our location. They have their modem configured with an IP address on our internal networks subnet. In their modem they have configured an address with a 10.250.0.5 address. This is the address they gave me to point our UC560 to for the SIP trunk.
I plugged one of the expansion ports on the UC560 into a modem port Windstream provided. I had to program a static route on the UC500 telling it to get to 10.250.0.5 via the interface Windstream programmed in their modem (the one that is on our subnet).
This worked without Issue up until a couple of weeks ago, when voicemaill stopped working.
Attached is a debug log. (debug ccsip messages, and debug voice ccapi inout)
Thank you for any help.
Syslog logging: enabled (0 messages dropped, 890 messages rate-limited, 22181 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 1537 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 8977 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (5000000 bytes):
1427471: Feb 19 13:26:16.381: %SYS-5-CONFIG_I: Configured from http by phoneadmin on 192.168.6.200
1427472: Feb 19 13:26:16.425: %SYS-5-CONFIG_I: Configured from http by phoneadmin on 192.168.6.200
1427473: Feb 19 13:26:16.465: %SYS-5-CONFIG_I: Configured from http by phoneadmin on 192.168.6.200
1427474: Feb 19 13:26:16.505: %SYS-5-CONFIG_I: Configured from http by phoneadmin on 192.168.6.200
1427475: Feb 19 13:26:25.633: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:<affected Uc's number>@192.168.6.30:5060 SIP/2.0
Via: SIP/2.0/UDP 10.250.0.5:5060;branch=z9hG4bKnucppj203ongko0td360.1
From: "ATNETPLUS INC."<sip:<Outside_Caller>@10.250.0.5;user=phone;insideBWWEST=BWWESTSIG-4g59l1460sifa>;tag=1539219440-1392834385608-
To: "MAGNUS INTL ."<sip:<affected Uc's number>@192.168.6.30;49358-001-0is=49358-001-0is-rqjp5mmr04nd9>
Call-ID: BW182625608190214-1652694384@64.199.51.210
CSeq: 632490853 INVITE
Contact: <sip:<Outside_Caller>@10.250.0.5:5060;insideBWWEST=BWWESTSIG-rf3n4t35ac6b7;transport=udp>
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY
Accept: application/media_control+xml,application/sdp,multipart/mixed
Supported: timer
Min-SE: 60
Max-Forwards: 47
Content-Type: application/sdp
Content-Length: 272
v=0
o=- 3105894791 1 IN IP4 10.250.0.5
s=-
c=IN IP4 10.250.0.5
t=0 0
m=audio 20070 RTP/AVP 18 0 8 101
a=sendrecv
a=ptime:20
a=rtpmap:18 G729/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=fmtp:18 annexb=no
1427476: Feb 19 13:26:25.633: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=<affected Uc's number>, Called Number=<affected Uc's number>, Peer Info Type=DIALPEER_INFO_SPEECH
1427477: Feb 19 13:26:25.633: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=<affected Uc's number>
1427478: Feb 19 13:26:25.633: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
1427479: Feb 19 13:26:25.633: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=<affected Uc's number>, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
1427480: Feb 19 13:26:25.633: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
1427481: Feb 19 13:26:25.633: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=<Outside_Caller>, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
1427482: Feb 19 13:26:25.633: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
1427483: Feb 19 13:26:25.633: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
1427484: Feb 19 13:26:25.637: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427485: Feb 19 13:26:25.637: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427486: Feb 19 13:26:25.637: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427487: Feb 19 13:26:25.637: //-1/2CF543B48525/DPM/dpAssociateIncomingPeerCore:
Calling Number=<Outside_Caller>, Called Number=<affected Uc's number>, Voice-Interface=0x0,
1427488: Feb 19 13:26:25.637: //-1/2CF543B48525/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=3001
1427489: Feb 19 13:26:25.637: //-1/2CF543B48525/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
1427490: Feb 19 13:26:25.637: //-1/2CF543B48525/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
1427491: Feb 19 13:26:25.637: //64825/2CF543B48525/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.6.30
1427492: Feb 19 13:26:25.637: //64825/2CF543B48525/SIP/Media/sipSPISelectCodecVersion: g729r8 flavor of g729 codec will be used
1427493: Feb 19 13:26:25.637: //64825/2CF543B48525/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 20 for codec g729r8
1427494: Feb 19 13:26:25.637: //64825/2CF543B48525/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g711alaw, bytes :160
Preferred DTMF relay : rtp-nte
Preferred NTE payload : 101
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
1427495: Feb 19 13:26:25.637: //64825/2CF543B48525/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.6.30
1427496: Feb 19 13:26:25.637: //64825/2CF543B48525/SIP/Media/sipSPISelectCodecVersion: g729r8 flavor of g729 codec will be used
1427497: Feb 19 13:26:25.637: //64825/2CF543B48525/SIP/Media/sipSPIDisplayStreamInfo:
Stream type : voice+dtmf
Media line : 1
State : STREAM_ADDING (2)
Stream address type : 1
Callid : 64825
Peer Callid : -1
RTP/SRTP Negotiated : 8
Negotiated Codec : g729r8, bytes :20
Nego. Codec payload : 18 (tx), 18 (rx)
Negotiated DTMF relay : rtp-nte
Negotiated NTE payload : 101 (tx), 101 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [192.168.6.30]:0
Media Dest Addr/Port : [10.250.0.5]:20070
1427498: Feb 19 13:26:25.637: //64825/2CF543B48525/SIP/Media/sipSPIUpdCallWithSdpInfo:
Media line : 1
Callid : 64825
1427499: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16708 for stream 1
1427500: Feb 19 13:26:25.641: //64825/2CF543B48525/SIP/Media/sipSPIDisplayStreamInfo:
Media line : 1
Callid : 64825
Peer Callid : -1
Media Srce Addr/Port : [192.168.6.30]:16708
1427501: Feb 19 13:26:25.641: //-1/2CF543B48525/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=<Outside_Caller>
----- ccCallInfo IE subfields -----
cisco-ani=<Outside_Caller>
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=<affected Uc's number>
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
1427502: Feb 19 13:26:25.641: //-1/2CF543B48525/CCAPI/cc_api_call_setup_ind_common:
Interface=0x87ACA068, Call Info(
Calling Number=<Outside_Caller>,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=<affected Uc's number>(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=3001, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=64825
1427503: Feb 19 13:26:25.641: //-1/2CF543B48525/CCAPI/ccCheckClipClir:
In: Calling Number=<Outside_Caller>(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
1427504: Feb 19 13:26:25.641: //-1/2CF543B48525/CCAPI/ccCheckClipClir:
Out: Calling Number=<Outside_Caller>(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
1427505: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427506: Feb 19 13:26:25.641: :cc_get_feature_vsa malloc success
1427507: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427508: Feb 19 13:26:25.641: cc_get_feature_vsa count is 3
1427509: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427510: Feb 19 13:26:25.641: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330073888,feature_id:42075
1427511: Feb 19 13:26:25.641: //64825/2CF543B48525/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=<Outside_Caller>(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=<affected Uc's number>(TON=Unknown, NPI=Unknown))
1427512: Feb 19 13:26:25.641: //64825/2CF543B48525/CCAPI/cc_process_call_setup_ind:
Event=0x885E7650
1427513: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=<affected Uc's number>, Peer Info Type=DIALPEER_INFO_SPEECH
1427514: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427515: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427516: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=<affected Uc's number>, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
1427517: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
1427518: Feb 19 13:26:25.641: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number <affected Uc's number>
1427519: Feb 19 13:26:25.641: //64825/2CF543B48525/CCAPI/ccCallSetContext:
Context=0x8AE47E68
1427520: Feb 19 13:26:25.641: //64825/2CF543B48525/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 64825 with tag 3001 to app "_ManagedAppProcess_Default"
1427521: Feb 19 13:26:25.645: //64825/2CF543B48525/CCAPI/ccCallProceeding:
1427522: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersCore:
Calling Number=, Called Number=398, Peer Info Type=DIALPEER_INFO_SPEECH
1427523: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=398
1427524: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
1427525: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchSafModulePlugin:
dialstring=398, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
1427526: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=2001
1427527: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427528: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427529: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427530: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchSafModulePlugin:
1427531: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427532: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=398, Called Number=398, Peer Info Type=DIALPEER_INFO_SPEECH
1427533: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427534: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427535: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427536: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427537: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=398, Called Number=, Voice-Interface=0x0,
1427538: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2001
1427539: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427540: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427541: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427542: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427543: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427544: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427545: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427546: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427547: Feb 19 13:26:25.645: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427548: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427549: Feb 19 13:26:25.645: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427550: Feb 19 13:26:25.649: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427551: Feb 19 13:26:25.649: //-1/2CF543B48525/DPM/dpMatchSafModulePlugin:
dialstring=398, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
1427552: Feb 19 13:26:25.649: //-1/2CF543B48525/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427553: Feb 19 13:26:25.649: //64825/2CF543B48525/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=2001, Params=0x8AE45538, Progress Indication=NULL(0)
1427554: Feb 19 13:26:25.649: //64825/2CF543B48525/CCAPI/ccCheckClipClir:
1427555: Feb 19 13:26:25.649: //64825/2CF543B48525/CCAPI/ccCheckClipClir:
1427556: Feb 19 13:26:25.649: //64825/2CF543B48525/CCAPI/ccCallSetupRequest:
Destination Pattern=398, Called Number=398, Digit Strip=FALSE
1427557: Feb 19 13:26:25.649: //64825/2CF543B48525/CCAPI/ccCallSetupRequest:
Called Number=398(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=ATNETPLUS INC.
Account Number=<Outside_Caller>, Final Destination Flag=TRUE,
Guid=2CF543B4-98CA-11E3-8525-9BFECDC51DB1, Outgoing Dial-peer=2001
1427558: Feb 19 13:26:25.649: //64825/2CF543B48525/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=398
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
1427559: Feb 19 13:26:25.649: //64825/2CF543B48525/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x87ACA068, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=<Outside_Caller>,(Calling Name=ATNETPLUS INC.)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=398(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2001, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
1427560: Feb 19 13:26:25.649: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427561: Feb 19 13:26:25.649: :cc_get_feature_vsa malloc success
1427562: Feb 19 13:26:25.649: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427563: Feb 19 13:26:25.649: cc_get_feature_vsa count is 4
1427564: Feb 19 13:26:25.649: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427565: Feb 19 13:26:25.649: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330078368,feature_id:42076
1427566: Feb 19 13:26:25.649: //64826/2CF543B48525/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
1427567: Feb 19 13:26:25.649: //64826/2CF543B48525/CCAPI/ccCallSetContext:
Context=0x8AE454E8
1427568: Feb 19 13:26:25.649: //64825/2CF543B48525/CCAPI/ccSaveDialpeerTag:
1427569: Feb 19 13:26:25.649: //64826/2CF543B48525/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
1427570: Feb 19 13:26:25.649: //64826/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_codec:
1427571: Feb 19 13:26:25.649: cc_api_set_xcode_codec Line: 4775
1427572: Feb 19 13:26:25.649: //64825/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_codec:
1427573: Feb 19 13:26:25.649: cc_api_set_xcode_codec Line: 4775
1427574: Feb 19 13:26:25.649: //64826/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_stream:
1427575: Feb 19 13:26:25.649: cc_api_set_xcode_stream Line: 4728
1427576: Feb 19 13:26:25.649: //64826/2CF543B48525/CCAPI/cc_api_event_indication:
Event=180, Call Id=64826
1427577: Feb 19 13:26:25.649: //64826/2CF543B48525/CCAPI/cc_api_event_indication:
Event Is Sent To Conferenced SPI(s) Directly
1427578: Feb 19 13:26:25.649: //64825/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_stream:
1427579: Feb 19 13:26:25.649: cc_api_set_xcode_stream Line: 4728
1427580: Feb 19 13:26:25.649: //64825/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_stream:
1427581: Feb 19 13:26:25.649: cc_api_set_xcode_stream Line: 4728
1427582: Feb 19 13:26:25.649: //64826/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_codec:
1427583: Feb 19 13:26:25.649: cc_api_set_xcode_codec Line: 4775
1427584: Feb 19 13:26:25.649: //64826/2CF543B48525/CCAPI/cc_api_event_indication:
Event=182, Call Id=64826
1427585: Feb 19 13:26:25.649: //64826/2CF543B48525/CCAPI/cc_api_event_indication:
1427586: Feb 19 13:26:25.649: //64825/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_codec:
1427587: Feb 19 13:26:25.649: cc_api_set_xcode_codec Line: 4775
1427588: Feb 19 13:26:25.649: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427589: Feb 19 13:26:25.649: cc_api_get_xcode_stream : 4702
1427590: Feb 19 13:26:25.649: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427591: Feb 19 13:26:25.649: cc_api_get_xcode_stream : 4702 VCC, mtp1 index, mtp2 index, stream1, stream2 = 1 1 1 2
1427592: Feb 19 13:26:25.649: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427593: Feb 19 13:26:25.653: cc_api_get_xcode_stream : 4702
1427594: Feb 19 13:26:25.653: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427595: Feb 19 13:26:25.653: cc_api_get_xcode_stream : 4702
1427596: Feb 19 13:26:25.653: //64826/2CF543B48525/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.10.2
1427597: Feb 19 13:26:25.653: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16780 for stream 1
1427598: Feb 19 13:26:25.653: //64826/2CF543B48525/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
1427599: Feb 19 13:26:25.653: //64826/2CF543B48525/SIP/Media/sipSPIProcessRtpSessions: No active streams.
1427600: Feb 19 13:26:25.653: //64826/2CF543B48525/CCAPI/cc_api_call_proceeding:
Interface=0x87ACA068, Progress Indication=NULL(0)
1427601: Feb 19 13:26:25.653: //64826/2CF543B48525/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 64826) to the VOIP RTP library
1427602: Feb 19 13:26:25.653: //64826/2CF543B48525/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.10.2
1427603: Feb 19 13:26:25.653: //64826/2CF543B48525/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1427604: Feb 19 13:26:25.653: //64826/2CF543B48525/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.1.10.2, lport = 16780, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 64826, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
media_ip_addr = - , vrf tableid = 0 media_addr_type = 1
1427605: Feb 19 13:26:25.653: //64826/2CF543B48525/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
1427606: Feb 19 13:26:25.653: //64826/2CF543B48525/SIP/Media/sipSPICreateRtpSession: stun is disabled
1427607: Feb 19 13:26:25.653: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427608: Feb 19 13:26:25.653: cc_api_get_xcode_stream : 4702
1427609: Feb 19 13:26:25.653: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427610: Feb 19 13:26:25.653: cc_api_get_xcode_stream : 4702
1427611: Feb 19 13:26:25.653: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427612: Feb 19 13:26:25.653: cc_api_get_xcode_stream : 4702
1427613: Feb 19 13:26:25.653: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427614: Feb 19 13:26:25.653: cc_api_get_xcode_stream : 4702
1427615: Feb 19 13:26:25.653: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427616: Feb 19 13:26:25.653: cc_api_get_xcode_stream : 4702 VCC, mtp1 index, mtp2 index, stream1, stream2 = 1 1 2 1
1427617: Feb 19 13:26:25.657: //64825/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 19 Feb 2014 18:26:25 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
1427618: Feb 19 13:26:25.657: //64826/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:398@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC6CA980
From: "ATNETPLUS INC." <sip:<Outside_Caller>@10.250.0.5>;tag=D74BFD18-12D4
To: <sip:398@10.1.10.1>
Call-ID: 2CF85114-98CA11E3-852B9BFE-CDC51DB1@10.1.10.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0754271156-2563379683-2233834494-3452247473
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1392834385
Contact: <sip:<Outside_Caller>@10.1.10.2:5060>
Expires: 180
Max-Forwards: 46
Content-Disposition: session;handling=required
Content-Length: 217
v=0
o=CiscoSystemsSIP-GW-UserAgent 274 7304 IN IP4 10.1.10.2
s=SIP Call
t=0 0
m=audio 16780 RTP/AVP 0 101
c=IN IP4 10.1.10.2
a=fmtp:101 0-15
a=ptime:20
1427619: Feb 19 13:26:26.153: //64826/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 19 Feb 2014 18:26:26 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1392834386
Expires: 180
Max-Forwards: 46
Content-Length: 217
v=0
s=SIP Call
t=0 0
c=IN IP4 10.1.10.2
a=fmtp:101 0-15
a=ptime:20
1427620: Feb 19 13:26:26.157: //64826/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
1427621: Feb 19 13:26:26.169: //64826/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:398@10.1.10.1>;tag=ds763c65a1
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:398@10.1.10.1:5060;transport=udp>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 2CF85114-98CA11E3-852B9BFE-CDC51DB1@10.1.10.2
1427622: Feb 19 13:26:26.169: //64826/2CF543B48525/CCAPI/cc_api_call_alert:
Interface=0x87ACA068, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
1427623: Feb 19 13:26:26.169: //64826/2CF543B48525/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
1427624: Feb 19 13:26:26.169: //64825/2CF543B48525/CCAPI/ccCallAlert:
1427625: Feb 19 13:26:26.169: //64825/2CF543B48525/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
1427626: Feb 19 13:26:26.169: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=<Outside_Caller>, Peer Info Type=DIALPEER_INFO_SPEECH
1427627: Feb 19 13:26:26.169: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=<Outside_Caller>
1427628: Feb 19 13:26:26.169: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427629: Feb 19 13:26:26.169: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427630: Feb 19 13:26:26.169: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
1427631: Feb 19 13:26:26.169: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427632: Feb 19 13:26:26.169: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427633: Feb 19 13:26:26.169: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427634: Feb 19 13:26:26.173: //64825/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "MAGNUS INTL ."<sip:<affected Uc's number>@192.168.6.30;49358-001-0is=49358-001-0is-rqjp5mmr04nd9>;tag=D74BFF20-1692
Contact: <sip:398@192.168.6.30:5060>
Content-Length: 0
1427635: Feb 19 13:26:26.181: //64826/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 183
v=0
o=CUE 6691052 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 20992 RTP/AVP 0 101
a=fmtp:101 0-15
1427636: Feb 19 13:26:26.181: //64826/2CF543B48525/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.10.2
1427637: Feb 19 13:26:26.185: //64826/2CF543B48525/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
1427638: Feb 19 13:26:26.185: //64826/2CF543B48525/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g711ulaw, bytes :160
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
1427639: Feb 19 13:26:26.185: //64826/2CF543B48525/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.10.2
1427640: Feb 19 13:26:26.185: //64826/2CF543B48525/SIP/Media/sipSPIDisplayStreamInfo:
Media line : 1
Callid : 64826
Peer Callid : -1
Negotiated Codec : g711ulaw, bytes :160
Nego. Codec payload : 0 (tx), 0 (rx)
Media Srce Addr/Port : [10.1.10.2]:16780
Media Dest Addr/Port : [10.1.10.1]:20992
1427641: Feb 19 13:26:26.185: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_codec:
1427642: Feb 19 13:26:26.185: cc_api_get_xcode_codec : 4755
1427643: Feb 19 13:26:26.185: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_codec:
1427644: Feb 19 13:26:26.185: cc_api_get_xcode_codec : 4755
1427645: Feb 19 13:26:26.185: //64826/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_codec:
1427646: Feb 19 13:26:26.185: cc_api_set_xcode_codec Line: 4775
1427647: Feb 19 13:26:26.185: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427648: Feb 19 13:26:26.185: cc_api_get_xcode_stream : 4702
1427649: Feb 19 13:26:26.185: //64826/2CF543B48525/CCAPI/cc_api_event_indication:
1427650: Feb 19 13:26:26.185: //64826/2CF543B48525/CCAPI/cc_api_event_indication:
1427651: Feb 19 13:26:26.185: //64825/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_codec:
1427652: Feb 19 13:26:26.185: cc_api_set_xcode_codec Line: 4775
1427653: Feb 19 13:26:26.185: //64826/2CF543B48525/CCAPI/cc_api_caps_ind:
Destination Interface=0x0, Destination Call Id=-1, Source Call Id=64826,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Modem=0x0, Codec Bytes=20, Signal Type=2)
1427654: Feb 19 13:26:26.185: //64826/2CF543B48525/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
1427655: Feb 19 13:26:26.185: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_codec:
1427656: Feb 19 13:26:26.185: cc_api_get_xcode_codec : 4755
1427657: Feb 19 13:26:26.185: //64825/2CF543B48525/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
1427658: Feb 19 13:26:26.185: //64825/2CF543B48525/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
1427659: Feb 19 13:26:26.185: //64825/2CF543B48525/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
1427660: Feb 19 13:26:26.185: //64825/2CF543B48525/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
1427661: Feb 19 13:26:26.185: //64825/2CF543B48525/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
1427662: Feb 19 13:26:26.185: //64825/2CF543B48525/CCAPI/cc_api_caps_ack:
Destination Interface=0x0, Destination Call Id=64826, Source Call Id=64825,
Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=1)
1427663: Feb 19 13:26:26.185: //64825/2CF543B48525/CCAPI/cc_api_caps_ack:
1427664: Feb 19 13:26:26.185: //64826/2CF543B48525/CCAPI/cc_api_event_indication:
Event=171, Call Id=64826
1427665: Feb 19 13:26:26.185: //64826/2CF543B48525/CCAPI/cc_api_event_indication:
1427666: Feb 19 13:26:26.185: //64826/2CF543B48525/SIP/Media/sipSPIUpdCallWithSdpInfo:
Media line : 1
Callid : 64826
1427667: Feb 19 13:26:26.185: //64826/2CF543B48525/CCAPI/cc_api_call_connected:
Interface=0x87ACA068, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
1427668: Feb 19 13:26:26.185: //64826/2CF543B48525/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
1427669: Feb 19 13:26:26.189: //64826/2CF543B48525/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8BEB1FF8
1427670: Feb 19 13:26:26.189: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_codec:
1427671: Feb 19 13:26:26.189: cc_api_get_xcode_codec : 4755
1427672: Feb 19 13:26:26.189: //64825/2CF543B48525/CCAPI/ccConferenceCreate:
(confID=0x8AD9C6B4, callID1=0xFD39, gcid=2CF5DFDC-98CA11E3-85289BFE-CDC51DB1, tag=0x0)
1427673: Feb 19 13:26:26.189: //64826/2CF543B48525/CCAPI/ccConferenceCreate:
(confID=0x8AD9C6B4, callID2=0xFD3A, gcid=2CF5DFDC-98CA11E3-85289BFE-CDC51DB1, tag=0x0)
1427674: Feb 19 13:26:26.189: //64825/2CF543B48525/CCAPI/ccConferenceCreate:
Conference Id=0x8AD9C6B4, Call Id1=64825, Call Id2=64826, Tag=0x0
1427675: Feb 19 13:26:26.189: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427676: Feb 19 13:26:26.189: cc_api_get_xcode_stream : 4702
1427677: Feb 19 13:26:26.189: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427678: Feb 19 13:26:26.189: cc_api_get_xcode_stream : 4702
1427679: Feb 19 13:26:26.189: //64825/2CF543B48525/CCAPI/ccConferenceCreate:
1427680: Feb 19 13:26:26.189: ccConferenceCreate: ret1=0, codecMask1=4, bytes1=20, negot1=1, dtmf1=6
ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
tx_dynamic_pt1=18, rx_dynamic_pt1=18, codec_mode1=0, params_bitmap1 =0
tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
1427681: Feb 19 13:26:26.189: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427682: Feb 19 13:26:26.189: cc_api_get_xcode_stream : 4702
1427683: Feb 19 13:26:26.189: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427684: Feb 19 13:26:26.189: cc_api_get_xcode_stream : 4702
1427685: Feb 19 13:26:26.189: //64825/2CF543B48525/CCAPI/ccConferenceCreate:
Total Gain: Originating Party Direction=0dB, Terminating Party Direction=0dB
1427686: Feb 19 13:26:26.189: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427687: Feb 19 13:26:26.189: cc_api_get_xcode_stream : 4702
1427688: Feb 19 13:26:26.189: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427689: Feb 19 13:26:26.189: cc_api_get_xcode_stream : 4702
1427690: Feb 19 13:26:26.189: //64825/2CF543B48525/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 64825) to the VOIP RTP library
1427691: Feb 19 13:26:26.189: //64825/2CF543B48525/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.6.30
1427692: Feb 19 13:26:26.189: //64825/2CF543B48525/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1427693: Feb 19 13:26:26.189: //64825/2CF543B48525/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 192.168.6.30, lport = 16708, raddr = 10.250.0.5, rport=20070, do_rtcp=TRUE
src_callid = 64825, dest_callid = 64826, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 10.250.0.5, vrf tableid = 0 media_addr_type = 1
1427694: Feb 19 13:26:26.189: //64825/2CF543B48525/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
1427695: Feb 19 13:26:26.189: //64825/2CF543B48525/SIP/Media/sipSPICreateRtpSession: stun is disabled
1427696: Feb 19 13:26:26.189: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427697: Feb 19 13:26:26.189: cc_api_get_xcode_stream : 4702
1427698: Feb 19 13:26:26.189: //64825/2CF543B48525/SIP/Media/sipSPIGetNewLocalMediaDirection:
New Remote Media Direction = SENDRECV
Present Local Media Direction = SENDRECV
New Local Media Direction = SENDRECV
retVal = 0
1427699: Feb 19 13:26:26.189: //64825/2CF543B48525/CCAPI/cc_api_bridge_done:
Conference Id=0x2C70, Source Interface=0x87ACA068, Source Call Id=64825,
Destination Call Id=64826, Disposition=0x0, Tag=0x0
1427700: Feb 19 13:26:26.189: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427701: Feb 19 13:26:26.189: cc_api_get_xcode_stream : 4702
1427702: Feb 19 13:26:26.189: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427703: Feb 19 13:26:26.189: cc_api_get_xcode_stream : 4702
1427704: Feb 19 13:26:26.189: //64826/2CF543B48525/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 64826) to the VOIP RTP library
1427705: Feb 19 13:26:26.189: //64826/2CF543B48525/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.1.10.2
1427706: Feb 19 13:26:26.189: //64826/2CF543B48525/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
1427707: Feb 19 13:26:26.189: //64826/2CF543B48525/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.1.10.2, lport = 16780, raddr = 10.1.10.1, rport=20992, do_rtcp=TRUE
src_callid = 64826, dest_callid = 64825, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 10.1.10.1, vrf tableid = 0 media_addr_type = 1
1427708: Feb 19 13:26:26.193: //64826/2CF543B48525/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
1427709: Feb 19 13:26:26.193: //64826/2CF543B48525/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8BEB1FF8
1427710: Feb 19 13:26:26.193: //64826/2CF543B48525/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
1427711: Feb 19 13:26:26.193: //64826/2CF543B48525/CCAPI/cc_api_bridge_done:
Conference Id=0x2C70, Source Interface=0x87ACA068, Source Call Id=64826,
Destination Call Id=64825, Disposition=0x0, Tag=0x0
1427712: Feb 19 13:26:26.193: //64825/2CF543B48525/CCAPI/cc_generic_bridge_done:
1427713: Feb 19 13:26:26.193: //64825/2CF543B48525/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2C70, Destination Call Id=64826)
1427714: Feb 19 13:26:26.193: //64826/2CF543B48525/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2C70, Destination Call Id=64825)
1427715: Feb 19 13:26:26.193: //64825/2CF543B48525/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x2C70, Call Id1=64825, Call Id2=64826
1427716: Feb 19 13:26:26.193: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x876F815C, Interface Type=9, Destination=0.0.0.0, Mode=0x0,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
1427717: Feb 19 13:26:26.193: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427718: Feb 19 13:26:26.193: :cc_get_feature_vsa malloc success
1427719: Feb 19 13:26:26.193: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427720: Feb 19 13:26:26.193: cc_get_feature_vsa count is 5
1427721: Feb 19 13:26:26.193: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427722: Feb 19 13:26:26.193: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330077696,feature_id:42077
1427723: Feb 19 13:26:26.193: //64827/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
1427724: Feb 19 13:26:26.193: //64827/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
Context=0x8663BD24
1427725: Feb 19 13:26:26.193: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x8758CA38, Interface Type=25, Destination=, Mode=0x0,
1427726: Feb 19 13:26:26.193: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427727: Feb 19 13:26:26.193: :cc_get_feature_vsa malloc success
1427728: Feb 19 13:26:26.193: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427729: Feb 19 13:26:26.197: cc_get_feature_vsa count is 6
1427730: Feb 19 13:26:26.197: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427731: Feb 19 13:26:26.197: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330077024,feature_id:42078
1427732: Feb 19 13:26:26.197: //64828/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Interface=0x8758CA38, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
1427733: Feb 19 13:26:26.197: //64828/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
1427734: Feb 19 13:26:26.197: //64828/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=25, FlowMode=1
1427735: Feb 19 13:26:26.197: //64828/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
Context=0x8663B864
1427736: Feb 19 13:26:26.197: //64827/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Interface=0x876F815C, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
1427737: Feb 19 13:26:26.197: //64827/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
1427738: Feb 19 13:26:26.197: //64826/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:398@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC6CBA64
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
1427739: Feb 19 13:26:26.197: //64825/2CF543B48525/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
1427740: Feb 19 13:26:26.197: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427741: Feb 19 13:26:26.197: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427742: Feb 19 13:26:26.197: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427743: Feb 19 13:26:26.197: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427744: Feb 19 13:26:26.197: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
1427745: Feb 19 13:26:26.197: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427746: Feb 19 13:26:26.197: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427747: Feb 19 13:26:26.197: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427748: Feb 19 13:26:26.197: //64825/2CF543B48525/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
1427749: Feb 19 13:26:26.201: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
1427750: Feb 19 13:26:26.201: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427751: Feb 19 13:26:26.201: :cc_get_feature_vsa malloc success
1427752: Feb 19 13:26:26.201: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427753: Feb 19 13:26:26.201: cc_get_feature_vsa count is 7
1427754: Feb 19 13:26:26.201: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427755: Feb 19 13:26:26.201: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330074112,feature_id:42079
1427756: Feb 19 13:26:26.201: //64829/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
1427757: Feb 19 13:26:26.201: //64829/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
Context=0x8663A684
1427758: Feb 19 13:26:26.201: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427759: Feb 19 13:26:26.201: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427760: Feb 19 13:26:26.201: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427761: Feb 19 13:26:26.201: //64829/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
Connection Handle=0
1427762: Feb 19 13:26:26.201: //64829/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
1427763: Feb 19 13:26:26.201: //64825/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Contact: <sip:<affected Uc's number>@192.168.6.30:5060>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 6388 8487 IN IP4 192.168.6.30
s=SIP Call
t=0 0
m=audio 16708 RTP/AVP 18 101
c=IN IP4 192.168.6.30
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
1427764: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x894D08F8, callID1=0xFD3C, gcid=0-0-0-0, tag=0x0)
1427765: Feb 19 13:26:26.205: //64827/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x894D08F8, callID2=0xFD3B, gcid=0-0-0-0, tag=0x0)
1427766: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Conference Id=0x894D08F8, Call Id1=64828, Call Id2=64827, Tag=0x0
1427767: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x2C71, Source Interface=0x8758CA38, Source Call Id=64828,
Destination Call Id=64827, Disposition=0x0, Tag=0x0
1427768: Feb 19 13:26:26.205: //64827/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x2C71, Source Interface=0x876F815C, Source Call Id=64827,
Destination Call Id=64828, Disposition=0x0, Tag=0x0
1427769: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
1427770: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2C71, Destination Call Id=64827)
1427771: Feb 19 13:26:26.205: //64827/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2C71, Destination Call Id=64828)
1427772: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
1427773: Feb 19 13:26:26.205: //64829/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x894D08F8, callID2=0xFD3D, gcid=0-0-0-0, tag=0x0)
1427774: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Conference Id=0x894D08F8, Call Id1=64828, Call Id2=64829, Tag=0x0
1427775: Feb 19 13:26:26.205: //64829/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x2C72, Source Interface=0x876F815C, Source Call Id=64829,
1427776: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2C72, Destination Call Id=64829)
1427777: Feb 19 13:26:26.205: //64829/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x2C72, Destination Call Id=64828)
1427778: Feb 19 13:26:26.205: //64827/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x0, Params=0x894D05F0, Call Id=64827
1427779: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x2C71, Call Id1=64828, Call Id2=64827
1427780: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x2C72, Source Interface=0x8758CA38, Source Call Id=64828,
Destination Call Id=64829, Disposition=0x0, Tag=0x0
1427781: Feb 19 13:26:26.205: //64828/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
1427782: Feb 19 13:26:26.209: //64827/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x876F815C, Call Id=64827
1427783: Feb 19 13:26:26.209: //64828/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x2C72, Call Id1=64828, Call Id2=64829
1427784: Feb 19 13:26:26.209: //64829/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x0, Params=0x894D05F0, Call Id=64829
1427785: Feb 19 13:26:26.209: //64827/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Nominator=0x894D0BE8, Params=0x894D0BB8, Call Id=64827
1427786: Feb 19 13:26:26.209: //64827/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x18E00, Params=0x894D0F80, Call Id=64827
1427787: Feb 19 13:26:26.209: //64829/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x876F815C, Call Id=64829
1427788: Feb 19 13:26:26.209: //64827/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
1427789: Feb 19 13:26:26.213: //64829/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Nominator=0x894D0BE8, Params=0x894D0BB8, Call Id=64829
1427790: Feb 19 13:26:26.213: //64827/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
1427791: Feb 19 13:26:26.217: //64829/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x18E00, Params=0x894D0F80, Call Id=64829
1427792: Feb 19 13:26:26.217: //64829/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
1427793: Feb 19 13:26:26.217: //64829/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
1427794: Feb 19 13:26:26.281: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:<affected Uc's number>@192.168.6.30:5060 SIP/2.0
Via: SIP/2.0/UDP 10.250.0.5:5060;branch=z9hG4bKcnh5ie00dgl01o4nj330.1
CSeq: 632490853 ACK
Max-Forwards: 47
Content-Length: 0
1427795: Feb 19 13:26:35.441: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:<Outside_Caller>@10.1.10.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.1:5060;branch=z9hG4bKFZSAJ7togMoAzGDcEqX7vA~~1281
Max-Forwards: 70
To: <sip:<Outside_Caller>@10.250.0.5>;tag=D74BFD18-12D4
CSeq: 1 BYE
Content-Length: 0
Also: <sip:666@10.1.10.2:5060;user=phone>
1427796: Feb 19 13:26:35.441: //64825/2CF543B48525/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Sum Network, Params=0x0, Call Id=64825
1427797: Feb 19 13:26:35.441: //64826/2CF543B48525/CCAPI/cc_api_call_facility:
Interface=0x87ACA068, Call Id=64826
1427798: Feb 19 13:26:35.441: //64826/2CF543B48525/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
CallInfo(ssCTreRoutingNotSupported=FALSE)
1427799: Feb 19 13:26:35.441: //64825/2CF543B48525/CCAPI/ccConferenceDestroy:
Conference Id=0x2C70, Tag=0x0
1427800: Feb 19 13:26:35.441: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427801: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427802: Feb 19 13:26:35.441: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427803: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427804: Feb 19 13:26:35.441: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427805: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427806: Feb 19 13:26:35.441: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427807: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427808: Feb 19 13:26:35.441: //64825/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_stream:
1427809: Feb 19 13:26:35.441: cc_api_set_xcode_stream Line: 4728
1427810: Feb 19 13:26:35.441: //64825/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_codec:
1427811: Feb 19 13:26:35.441: cc_api_set_xcode_codec Line: 4775
1427812: Feb 19 13:26:35.441: //64826/2CF543B48525/CCAPI/cc_api_remote_codec_dnld_done:
Destination Interface=0x87ACA068, Destination Call Id=64826, Source Call Id=64825, Xmit Function=0x832087B0
1427813: Feb 19 13:26:35.441: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427814: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427815: Feb 19 13:26:35.441: //64825/2CF543B48525/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8B6D50DC
1427816: Feb 19 13:26:35.441: //64825/2CF543B48525/CCAPI/cc_api_bridge_drop_done:
1427817: Feb 19 13:26:35.441: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427818: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427819: Feb 19 13:26:35.441: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427820: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427821: Feb 19 13:26:35.441: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427822: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427823: Feb 19 13:26:35.441: //64826/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427824: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427825: Feb 19 13:26:35.441: //64826/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_stream:
1427826: Feb 19 13:26:35.441: cc_api_set_xcode_stream Line: 4728
1427827: Feb 19 13:26:35.441: //64826/xxxxxxxxxxxx/CCAPI/cc_api_set_xcode_codec:
1427828: Feb 19 13:26:35.441: cc_api_set_xcode_codec Line: 4775
1427829: Feb 19 13:26:35.441: //64825/2CF543B48525/CCAPI/cc_api_remote_codec_dnld_done:
Destination Interface=0x87ACA068, Destination Call Id=64825, Source Call Id=64826, Xmit Function=0x832087B0
1427830: Feb 19 13:26:35.441: //64825/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
1427831: Feb 19 13:26:35.441: cc_api_get_xcode_stream : 4702
1427832: Feb 19 13:26:35.441: //64826/2CF543B48525/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:8BEB1FF8
1427833: Feb 19 13:26:35.441: //64826/2CF543B48525/CCAPI/cc_api_bridge_drop_done:
1427834: Feb 19 13:26:35.441: //64825/2CF543B48525/CCAPI/cc_generic_bridge_done:
1427835: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427836: Feb 19 13:26:35.445: :cc_get_feature_vsa malloc success
1427837: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427838: Feb 19 13:26:35.445: cc_get_feature_vsa count is 8
1427839: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427840: Feb 19 13:26:35.445: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330076128,feature_id:42080
1427841: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427842: Feb 19 13:26:35.445: feature_vsa is 8AE22C98,featname is 0
1427843: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427844: Feb 19 13:26:35.445: :cc_get_feature_vsa malloc success
1427845: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427846: Feb 19 13:26:35.445: cc_get_feature_vsa count is 9
1427847: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427848: Feb 19 13:26:35.445: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330080160,feature_id:42081
1427849: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427850: Feb 19 13:26:35.445: : Generating new featurevsa,inserting it
1427851: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427852: Feb 19 13:26:35.445: feature call forward featname is 4
1427853: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427854: Feb 19 13:26:35.445: feature_vsa is 8AE21B18,featname is 0
1427855: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427856: Feb 19 13:26:35.445: :cc_get_feature_vsa malloc success
1427857: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427858: Feb 19 13:26:35.445: cc_get_feature_vsa count is 10
1427859: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427860: Feb 19 13:26:35.445: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330074784,feature_id:42082
1427861: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427862: Feb 19 13:26:35.445: : Generating new featurevsa,inserting it
1427863: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427864: Feb 19 13:26:35.445: feature call forward featname is 4
1427865: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427866: Feb 19 13:26:35.445: :cc_free_feature_vsa freeing 8AE223D8
1427867: Feb 19 13:26:35.445: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427868: Feb 19 13:26:35.445: vsacount in free is 9
1427869: Feb 19 13:26:35.449: //64827/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x800, Params=0x894D0F90, Call Id=64827
1427870: Feb 19 13:26:35.449: //64827/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
1427871: Feb 19 13:26:35.449: //64826/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "ATNETPLUS INC." <sip:<Outside_Caller>@10.250.0.5>;tag=D74BFD18-12D4
Date: Wed, 19 Feb 2014 18:26:35 GMT
CSeq: 1 BYE
P-RTP-Stat: PS=487,OS=73864,PR=346,OR=55042,PL=0,JI=0,LA=0,DU=9
Content-Length: 0
1427872: Feb 19 13:26:35.449: //-1/2CF543B48525/DPM/dpMatchPeersCore:
Calling Number=, Called Number=666, Peer Info Type=DIALPEER_INFO_SPEECH
1427873: Feb 19 13:26:35.449: //-1/2CF543B48525/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=666
1427874: Feb 19 13:26:35.449: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427875: Feb 19 13:26:35.449: //-1/2CF543B48525/DPM/dpMatchSafModulePlugin:
dialstring=666, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
1427876: Feb 19 13:26:35.449: //-1/2CF543B48525/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20032
1427877: Feb 19 13:26:35.449: //64825/2CF543B48525/CCAPI/ccSaveDialpeerTag:
1427878: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427879: Feb 19 13:26:35.449: :cc_get_feature_vsa malloc success
1427880: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427881: Feb 19 13:26:35.449: cc_get_feature_vsa count is 10
1427882: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
1427883: Feb 19 13:26:35.449: :FEATURE_VSA attributes are: feature_name:0,feature_time:2330076128,feature_id:42083
1427884: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427885: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427886: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427887: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427888: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
1427889: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427890: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427891: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427892: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427893: Feb 19 13:26:35.449: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1427894: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427895: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427896: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427897: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427898: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427899: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427900: Feb 19 13:26:35.453: : updating existing feature vsa
1427901: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427902: Feb 19 13:26:35.453: feature call forward featname is 4
1427903: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427904: Feb 19 13:26:35.453: :cc_free_feature_vsa freeing 8AE223D8
1427905: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427906: Feb 19 13:26:35.453: vsacount in free is 9
1427907: Feb 19 13:26:35.453: //64825/2CF543B48525/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
1427908: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427909: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427910: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427911: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427912: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427913: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427914: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427915: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427916: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427917: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427918: Feb 19 13:26:35.453: //64825/2CF543B48525/CCAPI/ccCallResume:
Call Id=64825
1427919: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=666, Called Number=, Voice-Interface=0x0,
1427920: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
1427921: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427922: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427923: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427924: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427925: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427926: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427927: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427928: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427929: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
1427930: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
1427931: Feb 19 13:26:35.453: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427932: Feb 19 13:26:35.453: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427933: Feb 19 13:26:35.453: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427934: Feb 19 13:26:35.453: //-1/2CF543B48525/DPM/dpMatchPeersCore:
1427935: Feb 19 13:26:35.457: //-1/2CF543B48525/DPM/dpMatchSafModulePlugin:
dialstring=666, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
1427936: Feb 19 13:26:35.457: //-1/2CF543B48525/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1427937: Feb 19 13:26:35.457: //-1/xxxxxxxxxxxx/CCAPI/cc_find_feature_vsa:
1427938: Feb 19 13:26:35.457: inside while in find feature_sa
1427939: Feb 19 13:26:35.457: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427940: Feb 19 13:26:35.457: feature_vsa is 8AE21E98,featname is 4
1427941: Feb 19 13:26:35.457: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427942: Feb 19 13:26:35.457: : updating existing feature vsa
1427943: Feb 19 13:26:35.457: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
1427944: Feb 19 13:26:35.457: feature call basic
1427945: Feb 19 13:26:35.457: //64826/2CF543B48525/CCAPI/ccCallFacility:
Call Id=64826
1427946: Feb 19 13:26:35.457: //64825/2CF543B48525/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
1427947: Feb 19 13:26:35.457: //64825/2CF543B48525/CCAPI/ccCallDisconnect:
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
1427948: Feb 19 13:26:35.457: //64826/2CF543B48525/CCAPI/ccCallDisconnect:
1427949: Feb 19 13:26:35.457: //64826/2CF543B48525/CCAPI/ccCallDisconnect:
1427950: Feb 19 13:26:35.457: //64828/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
Conference Id=0x2C71, Tag=0x0
1427951: Feb 19 13:26:35.457: //64828/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
1427952: Feb 19 13:26:35.457: //64827/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
1427953: Feb 19 13:26:35.457: //64828/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
1427954: Feb 19 13:26:35.461: //64826/2CF543B48525/SIP/Media/sipSPIDestroyRtpSession: stream:8BEB1FF8
1427955: Feb 19 13:26:35.461: //64826/2CF543B48525/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x87ACA068, Tag=0x0, Call Id=64826,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
1427956: Feb 19 13:26:35.461: //64826/2CF543B48525/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
1427957: Feb 19 13:26:35.461: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427958: Feb 19 13:26:35.461: :cc_free_feature_vsa freeing 8AE23398
1427959: Feb 19 13:26:35.461: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427960: Feb 19 13:26:35.461: vsacount in free is 8
1427961: Feb 19 13:26:35.461: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427962: Feb 19 13:26:35.461: vsacount in free is 7
1427963: Feb 19 13:26:35.461: //64825/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:<Outside_Caller>@10.250.0.5:5060;insideBWWEST=BWWESTSIG-rf3n4t35ac6b7;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.6.30:5060;branch=z9hG4bKC6CC131E
From: "MAGNUS INTL ."<sip:<affected Uc's number>@192.168.6.30;49358-001-0is=49358-001-0is-rqjp5mmr04nd9>;tag=D74BFF20-1692
To: "ATNETPLUS INC."<sip:<Outside_Caller>@10.250.0.5;user=phone;insideBWWEST=BWWESTSIG-4g59l1460sifa>;tag=1539219440-1392834385608-
Max-Forwards: 70
Timestamp: 1392834395
CSeq: 101 BYE
Reason: Q.850;cause=1
P-RTP-Stat: PS=461,OS=9220,PR=468,OR=8944,PL=0,JI=0,LA=0,DU=9
Content-Length: 0
1427964: Feb 19 13:26:35.461: //64827/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
1427965: Feb 19 13:26:35.461: //64827/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
1427966: Feb 19 13:26:35.461: //64827/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
1427967: Feb 19 13:26:35.461: //64829/xxxxxxxxxxxx/CCAPI/ccCallModify:
Nominator=0x800, Params=0x894D0F90, Call Id=64829
1427968: Feb 19 13:26:35.461: //64829/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
1427969: Feb 19 13:26:35.465: //64828/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
Conference Id=0x2C72, Tag=0x0
1427970: Feb 19 13:26:35.465: //64828/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
1427971: Feb 19 13:26:35.465: //64829/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
1427972: Feb 19 13:26:35.465: //64828/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
1427973: Feb 19 13:26:35.465: //64829/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
1427974: Feb 19 13:26:35.465: //64829/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
1427975: Feb 19 13:26:35.465: //64829/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
1427976: Feb 19 13:26:35.465: //64829/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x876F815C, Tag=0x0, Call Id=64829,
Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
1427977: Feb 19 13:26:35.465: //64829/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
1427978: Feb 19 13:26:35.465: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427979: Feb 19 13:26:35.465: :cc_free_feature_vsa freeing 8AE21BF8
1427980: Feb 19 13:26:35.465: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427981: Feb 19 13:26:35.465: vsacount in free is 6
1427982: Feb 19 13:26:35.469: //64827/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x876F815C, Tag=0x0, Call Id=64827,
1427983: Feb 19 13:26:35.469: //64827/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
1427984: Feb 19 13:26:35.469: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427985: Feb 19 13:26:35.469: :cc_free_feature_vsa freeing 8AE229F8
1427986: Feb 19 13:26:35.469: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427987: Feb 19 13:26:35.469: vsacount in free is 5
1427988: Feb 19 13:26:35.469: //64828/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
1427989: Feb 19 13:26:35.469: //64828/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
1427990: Feb 19 13:26:35.469: //64828/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x8758CA38, Tag=0x0, Call Id=64828,
1427991: Feb 19 13:26:35.469: //64828/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
1427992: Feb 19 13:26:35.469: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427993: Feb 19 13:26:35.469: :cc_free_feature_vsa freeing 8AE22758
1427994: Feb 19 13:26:35.469: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1427995: Feb 19 13:26:35.469: vsacount in free is 4
1427996: Feb 19 13:26:35.513: //64825/2CF543B48525/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
1427997: Feb 19 13:26:35.513: //64825/2CF543B48525/SIP/Media/sipSPIDestroyRtpSession: stream:8B6D50DC
1427998: Feb 19 13:26:35.513: //64825/2CF543B48525/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x87ACA068, Tag=0x0, Call Id=64825,
1427999: Feb 19 13:26:35.513: //64825/2CF543B48525/CCAPI/cc_api_call_disconnect_done:
1428000: Feb 19 13:26:35.513: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1428001: Feb 19 13:26:35.513: :cc_free_feature_vsa freeing 8AE21E98
1428002: Feb 19 13:26:35.513: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1428003: Feb 19 13:26:35.513: vsacount in free is 3
1428004: Feb 19 13:26:35.513: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
1428005: Feb 19 13:26:35.513: vsacount in free is 2
02-19-2014 04:51 PM
Based on the debugs, when the call comes in, G729 is negotiated as the codec. Then later in the debug there is an invite to x398, but this time G711 is neogiated.
Looks like your codecs dont match, which is why you are hearing silence.
I would change ALL your voip dial-peers to be codec g711u only.
This will most likely resolve your issue.
02-20-2014 12:34 PM
Thank you for the suggestion. This also looks like a good option. How would I go about changing the dial-peers codec? Unfortunately most of my experience with these things are with CCA. I can handle CLI changes though, I'm just not sure what to change.
02-20-2014 12:39 PM
To make a dial-peer use G711...
dial-peer voice 101 voip
codec g711ulaw
If you want to post your config, I could show you the exact commands.
Doing this should negate the requirement for a transcoder.
02-20-2014 01:21 PM
Ok, so it looks like calls are coming in on G711alaw and going to Voicemail on G711ulaw.
If your SIP provider will do G711u, then I would modify the incoming voip dial-peers to specify G711u instead of codec class 1 by doing this
dial-peer voice 2100 voip
codec g711ulaw
dial-peer voice 1000 voip
no voice-class codec 1
codec g711ulaw
dial-peer voice 3008 voip
codec g711ulaw
dial-peer voice 3009 voip
codec g711ulaw
dial-peer voice 3002 voip
codec g711ulaw
dial-peer voice 3003 voip
codec g711ulaw
dial-peer voice 3004 voip
codec g711ulaw
dial-peer voice 3000 voip
codec g711ulaw
This will change all incoming voice calls to G711ulaw.
Just in case it has an unforseen consequence, dont save the config to memory until you're sure it is working. A simple reboot will bring it back to normal.
02-20-2014 01:00 PM
Thank you for your assistance. Here is the config.
Building configuration...
Current configuration : 51574 bytes
! Last configuration change at 12:49:43 EST Thu Feb 20 2014 by phoneadmin
! NVRAM config last updated at 15:37:49 EST Wed Feb 19 2014 by phoneadmin
version 15.1
parser config cache interface
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service internal
service compress-config
service sequence-numbers
hostname
boot-start-marker
boot system flash:/uc500-advipservicesk9-mz.151-4.M6
boot-end-marker
no logging queue-limit
no logging rate-limit
no logging console
no logging monitor
enable secret 4
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-3672272695
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3672272695
revocation-check none
rsakeypair TP-self-signed-3672272695
crypto pki certificate chain TP-self-signed-3672272695
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33363732 32373236 3935301E 170D3133 30383038 31373239
35375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 36373232
37323639 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A74B 11F91459 D2C5527D 633353DC 5AE27821 5B9B8C89 B3B878F1 5CD80BD2
8BA56FC8 83FBBFA6 8A32C2FF D44C7384 A21BBFE9 F708447E 6C590B80 DA904A6A
61BA47DB 3AAE52BE 82E70C49 778E4C6C 344D8FD0 2B7F9917 9E23C419 22BE1E48
2B6A6A4A 4F8742D0 14D6054D F8C68108 440A1536 0361D165 EBD16E82 4D6F08AC
5EB30203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 147F96A8 34B859E3 152B7599 551E44D0 0A2CDD2B C1301D06
03551D0E 04160414 7F96A834 B859E315 2B759955 1E44D00A 2CDD2BC1 300D0609
2A864886 F70D0101 05050003 8181000E D5141E00 3E2A8EC9 58450950 B12283E2
506BE684 BE93F6B1 2AECA8EF 13E58A61 562C8FB0 9FF45BB4 AB3D8F08 C0D4598E
415E11E4 1EDBB126 E2B1D59D D52DF36B DB6B6007 A638CA04 9CA5DDD4 8789EFAF
B0DF3E22 E5DBF9C9 C5937809 C30CB200 8096DD2A 993810A4 4980B95B 89C97347
BDDE17E4 9C8F8B11 D4B5B207 E43DE1
quit
dot11 syslog
ip source-route
ip traffic-export profile vmaudio mode capture
bidirectional
incoming access-list 150
outgoing access-list 150
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp excluded-address 192.168.6.1 192.168.6.39
ip dhcp excluded-address 192.168.6.241 192.168.6.255
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip name-server 8.8.8.8
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic timeout 300
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
sip
registrar server expires max 3600 min 3600
no update-callerid
sip-profiles 1000
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g729r8
voice class h323 1
call start fast
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.1.1 port 5060
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
timezone 12
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 1
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 2
voice translation-rule 4
rule 1 /
voice translation-rule 6
rule 1 /
voice translation-rule 7
rule 1 /
voice translation-rule 8
rule 1 /
voice translation-rule 12
rule 1 /
rule 2 /
rule 3 /
rule 4 /
rule 5 /
rule 6 /
rule 7 /
rule 8 /
rule 9 /
voice translation-rule 13
rule 1 /
rule 2 /
rule 3 /
rule 4 /
rule 5 /
rule 6 /
rule 7 /
rule 8 /
rule 9 /
voice translation-rule 410
rule 1 /^9\(.*\)/ /\1/
rule 15 /^...$/ /
voice translation-rule 411
rule 1 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
rule 1 /^ABCD91900......./ //
rule 2 /^ABCD91976......./ //
rule 15 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
rule 1 /335/ /
rule 14 /^6\(..\)$/ /
rule 15 /^...$/ /
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 1113
rule 1 /^82\(...\)/ /\1/
voice translation-rule 1114
rule 1 /\(^...$\)/ /82\1/
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^5/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile
translate calling 3265
translate called 8
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile Hardy_Main-OP_Called_4
translate called 4
voice translation-profile Magnus_Main-OP_Called_7
translate called 7
voice translation-profile NewDID-AA_Called_12
translate called 12
voice translation-profile NewDID-AA_Called_13
translate called 13
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
translate called 422
voice translation-profile Test-OP_Called_6
translate called 6
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile multisiteInbound
translate called 1113
voice translation-profile multisiteOutbound
translate calling 1114
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
fax interface-type fax-mail
license udi pid UC560-FXO-K9 sn FGL1723110S
archive
log config
logging enable
logging size 600
hidekeys
process-max-time 150
ip tftp source-interface Vlan90
class-map match-any media
match dscp ef
class-map match-any signaling
match dscp cs3
match dscp af31
policy-map queue
class signaling
bandwidth percent 5
class media
priority percent 50
class class-default
fair-queue
policy-map shape
class class-default
shape average 2000000
service-policy queue
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key 2276waN$$QQ address 0.0.0.0 0.0.0.0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map multisite 1 ipsec-isakmp
description
set peer
set transform-set ESP-3DES-SHA
match address 106
qos pre-classify
interface Loopback0
description $FW_INSIDE$
ip address 51.51.51.51 255.255.255.0
ip access-group 102 in
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/0
description $FW_OUTSIDE$
bandwidth 2000
ip address
ip access-group 109 in
ip nat outside
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
service-policy output shape
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group$FW_INSIDE$
ip unnumbered Vlan90
ip access-group 101 in
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport mode trunk
switchport voice vlan 100
no ip address
macro description cisco-switch
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
macro description cisco-desktop
spanning-tree portfast
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
no ip address
interface Virtual-Template1
ip unnumbered Loopback0
ip access-group 103 in
ip nat inside
interface Virtual-Template200 type serial
no ip address
interface Vlan1
ip address 192.168.6.30 255.255.255.0
ip access-group 104 in
ip nat inside
ip traffic-export apply vmaudio size 1000000
h323-gateway voip bind srcaddr 192.168.6.30
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip access-group 108 in
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 107 in
ip nat inside
ip local pool SDM_WEBVPN_POOL_1 172.23.0.100 172.23.0.120
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 64.199.142.153
ip route 10.1.10.1 255.255.255.255 Vlan90
ip route 10.250.0.0 255.255.255.0 192.168.6.220
access-list 1 permit 192.168.6.30
access-list 1 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 1 remark SDM_ACL Category=1
access-list 1 permit 192.168.9.30
access-list 1 permit 192.168.6.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 1 permit 172.23.0.0 0.0.0.255
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 10.250.0.5
access-list 2 deny any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 101 remark SDM_ACL Category=1
access-list 101 remark Auto generated by SDM for NTP (123) 129.6.15.30
access-list 101 permit udp host 129.6.15.30 eq ntp any eq ntp
access-list 101 deny ip 51.51.51.0 0.0.0.255 any
access-list 101 deny ip 192.168.6.0 0.0.0.255 any
access-list 101 deny ip 10.1.1.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 102 remark SDM_ACL Category=1
access-list 102 remark Auto generated by SDM for NTP (123) 129.6.15.30
access-list 102 permit udp host 129.6.15.30 eq ntp host 51.51.51.51 eq ntp
access-list 102 deny ip 10.1.10.0 0.0.0.3 any
access-list 102 deny ip 192.168.6.0 0.0.0.255 any
access-list 102 deny ip 10.1.1.0 0.0.0.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 103 remark SDM_ACL Category=1
access-list 103 remark Auto generated by SDM for NTP (123) 129.6.15.30
access-list 103 permit udp host 129.6.15.30 eq ntp any eq ntp
access-list 103 deny ip 10.1.10.0 0.0.0.3 any
access-list 103 deny ip 192.168.6.0 0.0.0.255 any
access-list 103 deny ip 10.1.1.0 0.0.0.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_10##
access-list 104 remark SDM_ACL Category=1
access-list 104 remark Auto generated by SDM for NTP (123) 129.6.15.30
access-list 104 permit udp host 129.6.15.30 eq ntp host 192.168.6.30 eq ntp
access-list 104 deny ip 51.51.51.0 0.0.0.255 any
access-list 104 deny ip 10.1.10.0 0.0.0.3 any
access-list 104 deny ip 10.1.1.0 0.0.0.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 permit ip any any
access-list 105 remark SDM_ACL Category=2
access-list 105 deny ip any host 172.23.0.100
access-list 105 deny ip any host 172.23.0.101
access-list 105 deny ip any host 172.23.0.102
access-list 105 deny ip any host 172.23.0.103
access-list 105 deny ip any host 172.23.0.104
access-list 105 deny ip any host 172.23.0.105
access-list 105 deny ip any host 172.23.0.106
access-list 105 deny ip any host 172.23.0.107
access-list 105 deny ip any host 172.23.0.108
access-list 105 deny ip any host 172.23.0.109
access-list 105 deny ip any host 172.23.0.110
access-list 105 deny ip any host 172.23.0.111
access-list 105 deny ip any host 172.23.0.112
access-list 105 deny ip any host 172.23.0.113
access-list 105 deny ip any host 172.23.0.114
access-list 105 deny ip any host 172.23.0.115
access-list 105 deny ip any host 172.23.0.116
access-list 105 deny ip any host 172.23.0.117
access-list 105 deny ip any host 172.23.0.118
access-list 105 deny ip any host 172.23.0.119
access-list 105 deny ip any host 172.23.0.120
access-list 105 deny ip 192.168.6.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 105 permit ip 10.1.10.0 0.0.0.3 any
access-list 105 permit ip 192.168.6.0 0.0.0.255 any
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip 172.23.0.0 0.0.0.255 any
access-list 106 remark CryptoACL for Magnus_Chagrin
access-list 106 remark SDM_ACL Category=4
access-list 106 permit ip 192.168.6.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 107 remark auto generated by SDM firewall configuration##NO_ACES_12##
access-list 107 remark SDM_ACL Category=1
access-list 107 remark Auto generated by SDM for NTP (123) 129.6.15.30
access-list 107 permit udp host 129.6.15.30 eq ntp host 10.1.1.1 eq ntp
access-list 107 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 107 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 107 deny ip 51.51.51.0 0.0.0.255 any
access-list 107 deny ip 10.1.10.0 0.0.0.3 any
access-list 107 deny ip 192.168.6.0 0.0.0.255 any
access-list 107 deny ip host 255.255.255.255 any
access-list 107 deny ip 127.0.0.0 0.255.255.255 any
access-list 107 permit ip any any
access-list 108 remark auto generated by SDM firewall configuration##NO_ACES_11##
access-list 108 remark SDM_ACL Category=1
access-list 108 remark Auto generated by SDM for NTP (123) 129.6.15.30
access-list 108 permit udp host 129.6.15.30 eq ntp host 10.1.10.2 eq ntp
access-list 108 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 108 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 108 deny ip 51.51.51.0 0.0.0.255 any
access-list 108 deny ip 192.168.6.0 0.0.0.255 any
access-list 108 deny ip 10.1.1.0 0.0.0.255 any
access-list 108 deny ip host 255.255.255.255 any
access-list 108 deny ip 127.0.0.0 0.255.255.255 any
access-list 108 permit ip any any
access-list 109 remark auto generated by SDM firewall configuration##NO_ACES_30##
access-list 109 remark SDM_ACL Category=1
access-list 109 permit tcp any host
access-list 109 remark Auto generated by SDM for NTP (123) 129.6.15.30
access-list 109 permit udp host 129.6.15.30 eq ntp host
access-list 109 permit ahp host
access-list 109 permit esp host
access-list 109 permit ip 192.168.9.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 109 deny ip 51.51.51.0 0.0.0.255 any
access-list 109 deny ip 10.1.10.0 0.0.0.3 any
access-list 109 deny ip 192.168.6.0 0.0.0.255 any
access-list 109 deny ip 10.1.1.0 0.0.0.255 any
access-list 109 permit udp host 8.8.8.8 eq domain any
access-list 109 permit icmp any host
access-list 109 permit udp host 10.250.0.5 eq 5060 any
access-list 109 permit udp host 10.250.0.5 any eq 5060
access-list 109 permit udp host 192.168.6.30 eq 5060 any
access-list 109 permit udp host 192.168.6.30 any eq 5060
access-list 109 permit udp host 192.168.9.30 eq 5060 any
access-list 109 permit udp host 192.168.9.30 any eq 5060
access-list 109 permit udp any any range 16384 32767
access-list 109 deny ip 10.0.0.0 0.255.255.255 any
access-list 109 deny ip 172.16.0.0 0.15.255.255 any
access-list 109 deny ip 192.168.0.0 0.0.255.255 any
access-list 109 deny ip 127.0.0.0 0.255.255.255 any
access-list 109 deny ip host 255.255.255.255 any
access-list 109 deny ip host 0.0.0.0 any
access-list 109 deny ip any any log
access-list 150 permit ip any any
route-map SDM_RMAP_1 permit 1
match ip address 105
snmp-server community public RO
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/phones/50x-30x/spa50x-30x-7-5-2c.bin alias spa50x-30x-7-5-2c.bin
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/Desktops/320x212x12/List.xml alias Desktops/320x212x12/List.xml
tftp-server flash:/Desktops/320x212x12/List.xml.BAK alias Desktops/320x212x12/List.xml.BAK
tftp-server flash:/Desktops/320x212x16/List.xml alias Desktops/320x212x16/List.xml
tftp-server flash:/Desktops/320x212x16/List.xml.BAK alias Desktops/320x212x16/List.xml.BAK
tftp-server flash:/Desktops/320x216x16/List.xml alias Desktops/320x216x16/List.xml
tftp-server flash:/Desktops/320x216x16/List.xml.BAK alias Desktops/320x216x16/List.xml.BAK
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:/bacdprompts/app-b-acd-3.0.0.2.tcl alias app-b-acd-3.0.0.2.tcl
tftp-server flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl alias app-b-acd-aa-3.0.0.2.tcl
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/ringtones/RingList.xml.BAK alias RingList.xml.BAK
tftp-server flash:/ringtones/DistinctiveRingList.xml.BAK alias DistinctiveRingList.xml.BAK
tftp-server flash:/phones/7937/apps37sccp.1-4-4-0.bin alias apps37sccp.1-4-4-0.bin
radius-server attribute 31 send nas-port-detail
control-plane
voice-port 0/0/0
station-id number 401
caller-id enable
voice-port 0/0/1
station-id number 402
caller-id enable
voice-port 0/0/2
station-id number 403
caller-id enable
voice-port 0/0/3
station-id number 404
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 399
description Configured by CCA 4 FXO-0/1/0-OP
caller-id enable
voice-port 0/1/1
description Configured by CCA 4 FXO-0/1/1-OP
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-OP
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-OP
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Vlan90
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register mtpe4d3f137e2c0
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk Windstream Registered
codec g729r8
codec g711ulaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 402
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 403
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 404
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description ôcatch all dial peer for BRI/PRIö
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-7-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-7-Digit*7-Digit Local**
preference 5
destination-pattern 9[2-9]......
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*North American-7-Digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-7-Digit*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-7-Digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-7-Digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91855.......
forward-digits all
no sip-register
corlist incoming call-internal
description **CCA*INTERSITE inbound call to Magnus_Painesville
translation-profile incoming multisiteInbound
incoming called-number 82...
voice-class h323 1
dtmf-relay rtp-nte
fax protocol cisco
no vad
dial-peer voice 2101 voip
description **CCA*INTERSITE outbound calls to Magnus_Chagrin
translation-profile outgoing multisiteOutbound
destination-pattern 81...
session target ipv4:192.168.9.30
voice-class h323 1
dtmf-relay rtp-nte
fax protocol cisco
no vad
dial-peer voice 1020 voip
translation-profile outgoing PSTN_Outgoing
preference 1
session target sip-server
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
ip qos dscp ef signaling
no vad
dial-peer voice 1021 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1022 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1023 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1024 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1025 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1026 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1027 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1028 voip
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1029 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1030 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
permission term
description ** Incoming call from SIP trunk (Windstream Registered) **
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk (Windstream Registered) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls for PSTN from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound Calls for MWI from CUE **
b2bua
incoming called-number A80T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1009 voip
description ** Passthrough Inbound Calls for Internal Extensions from CUE **
b2bua
incoming called-number ^...$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 398
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
description NewDID-AA
translation-profile incoming NewDID-AA_Called_12
voice-class codec 1
dtmf-relay rtp-nte
no vad
translation-profile incoming NewDID-AA_Called_13
[0-8]
voice-class codec 1
dtmf-relay rtp-nte
no vad
description Test-OP
translation-profile incoming Test-OP_Called_6
voice-class codec 1
dtmf-relay rtp-nte
no vad
description Magnus_Main-OP
translation-profile incoming Magnus_Main-OP_Called_7
voice-class codec 1
dtmf-relay rtp-nte
no vad
description
-AA_Called_8
voice-class codec 1
dtmf-relay rtp-nte
no vad
description Hardy_Main-OP
translation-profile incoming Hardy_Main-OP_Called_4
voice-class codec 1
dtmf-relay rtp-nte
no vad
no dial-peer outbound status-check pots
sip-ua
credentials username
password 7 realm 10.250.0.5
keepalive target ipv4:10.250.0.5:5060
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive active 100
registrar ipv4:10.250.0.5:5060 expires 3600
sip-server ipv4:10.250.0.5:5060
host-registrar
g729-annexb override
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 10
sdspfarm tag 2 mtpe4d3f137e2c0
video
fxo hook-flash
max-ephones 138
max-dn 600
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message Magnus
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
load 7937 apps37sccp.1-4-4-0
load 521G-524G cp524g-8-1-17
load 501G spa50x-30x-7-5-2c
load 502G spa50x-30x-7-5-2c
load 504G spa50x-30x-7-5-2c
load 508G spa50x-30x-7-5-2c
load 509G spa50x-30x-7-5-2c
load 301 spa50x-30x-7-5-2c
load 303 spa50x-30x-7-5-2c
time-zone 12
keepalive 30 auxiliary 4
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$VIfo$Hp2xqJTkH3ygjUdOSbfWh1
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 5... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 571
number 666 no-reg both
description *** CCA Floating Extension ***
name Test VM
ephone-dn 572
number 230 no-reg both
name
ephone-dn 573
number 225 no-reg both
call-forward all 81225
ephone-dn 574 dual-line
number 259 no-reg both
label Ext. 259
description
name
ephone-dn 575 dual-line
number 241 no-reg both
label Ext. 241
description
name
call-forward busy 399
call-forward noan 399 timeout 20
ephone-dn 576 dual-line
number 236 no-reg both
label Ext. 236
description
name
ephone-dn 577 dual-line
number 611 no-reg both
label Hydro Control
description Ext. 611
name Hydro Control
ephone-dn 578 dual-line
number 621 no-reg both
label
description Ext. 621
name
ephone-dn 579
number 235 no-reg both
name
call-forward all 915635948013
ephone-dn 580
number 240 no-reg both
name
call-forward all 914405524581
ephone-dn 581 dual-line
number 620 no-reg both
label
description Ext. 620
name
ephone-dn 582
number 207 no-reg both
name
call-forward all 81207
ephone-dn 583 dual-line
number 601 no-reg both
label
description Ext. 601
name
ephone-dn 584
number 221 no-reg both
name
call-forward all 81221
ephone-dn 585
number 202 no-reg both
name
call-forward all 81202
ephone-dn 586
number 237 no-reg both
name
call-forward all 81237
ephone-dn 587
number 227 no-reg both
name
call-forward all 81227
ephone-dn 588
number 223 no-reg both
name
call-forward all 81223
ephone-dn 589
number 224 no-reg both
name
call-forward all 81224
ephone-dn 590
number 4402105319
description SIP Main Number registration
preference 10
ephone-dn 591 dual-line
number 606 no-reg primary
label
description Ext. 606
name
ephone-dn 592 dual-line
number 605 no-reg primary
label
description Ext. 605
name
ephone-dn 593 dual-line
number 615 no-reg primary
label
description Ext. 615
name
ephone-dn 594 dual-line
number 617 no-reg primary
label
description Ext. 617
name
ephone-dn 595 dual-line
number 335 no-reg primary
label
description Ext. 335
name
ephone-dn 596 dual-line
number 604 no-reg primary
label
description Ext. 604
name
ephone-dn 597 dual-line
number 608 no-reg both
label
description Est. 608
name Tom Burlinski
ephone-dn 598
number 5... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn 599
number A801... no-reg primary
mwi off
ephone-dn 600
number A800... no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address A44C.119E.4F13
ephone-template 16
max-calls-per-button 2
username
type 509G
button 1:597
ephone 2
mac-address A44C.119E.4F4E
ephone-template 16
username
type 509G
button 1:596
ephone 3
mac-address A44C.119E.4F4C
ephone-template 16
username
type 509G
button 1:595
ephone 4
mac-address A44C.119E.4F44
ephone-template 16
username
type 509G
button 1:594
ephone 5
mac-address A44C.119E.4EFB
ephone-template 16
username
type 509G
button 1:583
ephone 6
mac-address A44C.119E.4F08
ephone-template 16
username
type 509G
button 1:592
ephone 7
mac-address A44C.119E.4F1D
ephone-template 16
username
type 509G
button 1:591
ephone 8
mac-address A44C.119E.4F45
ephone-template 16
username
type 509G
button 1:593
ephone 9
mac-address 0004.F2F5.6CC4
ephone-template 16
username
type 7937
button 1:581
ephone 10
mac-address A44C.119E.4EFE
ephone-template 16
username
type 509G
button 1:578
ephone 11
mac-address A44C.119E.4F3C
ephone-template 16
username
type 509G
button 1:577
ephone 12
mac-address B0FA.EB2E.C63A
ephone-template 16
username
type 525G2
button 1:576
ephone 13
mac-address 30F7.0D5F.0460
ephone-template 16
username
type 525G2
button 1:575
ephone 14
mac-address B0FA.EB2E.F0B2
ephone-template 16
username
type 525G2
button 1:574
alias exec cca_voice_mode PBX
alias exec clid-SIP ;14:00-99
banner login ^CCisco Configuration Assistant. Version: 3.2 (3). Tue Dec 10 10:56:46 EST 2013^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
speed 115200
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
ntp server 129.6.15.30 prefer
event manager session cli username "pingerID"
event manager applet vpn-pinger
event timer watchdog time 120 maxrun 100
action 1.0 cli command "enable"
action 2_Magnus_ cli command "ping ip 192.168.9.30 source Vlan1 repeat 2 timeout 5"
webvpn gateway SDM_WEBVPN_GATEWAY_1
ip address
ssl trustpoint TP-self-signed-3672272695
inservice
webvpn install svc flash:/webvpn/anyconnect-dart-win-2.5.6005-k9.pkg sequence 1
webvpn context SDM_WEBVPN_CONTEXT_1
secondary-color white
title-color #CCCC66
text-color black
ssl authenticate verify all
policy group SDM_WEBVPN_POLICY_1
functions svc-enabled
svc address-pool "SDM_WEBVPN_POOL_1" netmask 255.255.0.0
svc dns-server primary 8.8.8.8
svc dns-server secondary 4.2.2.2
virtual-template 1
default-group-policy SDM_WEBVPN_POLICY_1
aaa authentication list sdm_vpn_xauth_ml_1
max-users 20
inservice
end
02-19-2014 08:23 PM
Configure a transcoding. It should work.
Rate the post accordingly.
Kevin
Sent from Cisco Technical Support Android App
02-20-2014 09:47 AM
Thank you for the suggestions. I will have time to work on this tomorrow.
Is this a pretty good description of how to configure a transcoding, Kevin?
http://ccnp-v.blogspot.com/2011/11/uc500-series-transcoding.html
02-20-2014 10:45 PM
Hi jared,
exact same steps as in the link you posted:
sccp local Loopback0
sccp ccm x.x.x.x identifier 1 version 4.0<<<<<<<<<<<(IP-ADD of CME)
sccp
sccp ccm group 1
associate profile 2 register xcodeprof
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions x
no shut
telephony-service
sdspfarm units 2
sdspfarm transcode sessions x
sdspfarm tag 2 xcodeprof
Kevin
02-21-2014 07:55 AM
Thank you for the info Kevin. I am just trying to understand this for my benifit (and anyone else who reads this). This is what is in my config currently (no changes have been made yet).
sccp local Vlan90
sccp
sccp ccm group 1
codec g729r8
codec g711ulaw
codec g729ar8
codec g729abr8
maximum sessions 10
telephony-service
sdspfarm units 5
The only real differences I se are that the register is set to "mtpe4d3f137e2c0" (instead of xcodrprof), and the SCCP is set to VLAN90 instead of Loopback0. Could this be vausing me some greif? That "mtpe4d3f137e2c0". looks a bit goofy.
