Calls from Sip Trunk to UC540 and then to CUE returned ** Service Unavailable**
Hi to all
i have something strange here and i need your assistance
Call Flow:
Sip trunk-->UC540--> CUE
When calls coming to UC540 from outside and then going to cue then we send back service unavailable.I made a translation and i sent directly the incoming calls to CUE
The same behavior is also if i send the calls to dummy number and then from there set forward all to voice mail.
Incoming voicemail is working fine
Incoming calls to phones also ok
Uc540: 8.6
CUE: 8.6.5
A number: 99999999
B number: 22777777
Voice Mail Number:111
Attached is the trace
i see that we hit the correct dial peers .
I have enable only trancoder since MTP is not register ( don't know why , but i don't think also that is necessary..
voice service voip
 ip address trusted list
  ipv4 172.16.80.0 255.255.255.0
  ipv4 172.16.81.0 255.255.255.0
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 supplementary-service media-renegotiate
 sip
  no update-callerid
dial-peer voice 1000 voip
 description **SIP TRUNK**
 translation-profile incoming SIP-INCOMING
 translation-profile outgoing SIP-OUTGOING
 destination-pattern 9T
 modem passthrough nse codec g711alaw
 session protocol sipv2
 session target sip-server
 incoming called-number .T
 voice-class codec 2
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 fax-relay ecm disable
 no fax-relay sg3-to-g3
 fax rate 9600
 fax protocol pass-through g711alaw
 no vad
dial-peer voice 2001 voip
 description ** cue voicemail pilot number **
 destination-pattern 111
 b2bua
 session target ipv4:10.1.10.1
 incoming called-number 111
 no voice-class sip outbound-proxy
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Hi Chrysostomos,Please set
Hi Chrysostomos,
Please set the allow connection under voip service to allow the call to move from one sip leg to other.
Voice service voip
allow connections sip to sip
Second as you are using b2bua on dial-peer then its important to configure media source ip , so that it modify the media ip/port and act as media flow-through mode.
on global mode...
voice service voip
sip
bind media source interface ......
bind media control interface .......
or configure it on dial-peer (recommended)
dial-peer voice xxxx voip
voice-class sip bind control source-interface ........
voice-class sip bind media source-interface .......
Collect the debug if it fails again.
Manish
Hi  Problem solved It was a
Problem solved
It was a BUG to the IOS of UC540
Changed the ios fixed the problem
Hi Interface
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet0/0.10         192.168.0.10    YES DHCP   up                    up   ----> For internet
FastEthernet0/0.20         10.151.5.130    YES NVRAM  up                    up  ------> For sip trunk
In0/0                      10.1.10.2       YES unset  up                    up    --------> default gw for cue
Vlan1                      unassigned      YES unset  up                    up
Vlan100                    unassigned      YES unset  up                    up
Vlan200                    unassigned      YES unset  up                    down
Vlan300                    unassigned      YES unset  up                    down
NVI0                       10.1.10.2       YES unset  up                    up
BVI1                       192.168.20.1    YES NVRAM  up                    up
BVI100                     10.1.1.1        YES NVRAM  up                    up   ---------> ip for cme
Loopback0                  10.1.10.2       YES NVRAM  up                    up   ------> default gw for cue
 b2bua
 voice-class sip bind control source-interface BVI100
 voice-class sip bind media source-interface BVI100
 codec g711ulaw
 no vad
interface FastEthernet0/0.10
 description **FOR INTERNET**
 encapsulation dot1Q 10
 ip address dhcp
 ip access-group 105 in
 ip nat outside
 ip inspect SDM_LOW out
 ip virtual-reassembly in
interface FastEthernet0/0.20
 description **FOR SIP TRUNK WITH ISP**
 encapsulation dot1Q 20
 ip address 10.151.5.130 255.255.255.240
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ping 10.1.10.1 source bvi100
Sending 5, 100-byte ICMP Echos to 10.1.10.1, timeout is 2 seconds:
Packet sent with a source address of 10.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
I have bind the interface of cme ( 10.1.1.1) but the call fails again
Anything to advice?
Hi,Which all codecs that
Which all codecs that voice-class codec 2 contains ?
The intial INVITE has little wired SDP parameters , it does not contains audio media attribute like this..
a=rtpmap:8 PCMA/8000
Nevertheless this attribute is not a mandatory parameters of SDP.
As only single media is offered from the initial INVITE i.e. G711alaw and you know CUE only supports ulaw , so you need transcoders to convert alaw to ulaw.
What is the trancoder status and how it is configured ?
Manish
Hi Thank you for the response
Thank you for the response again
Yes i have a trancoder enable and is registered successfully
voice class codec 2
codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729br8
 codec preference 4 g729r8
sccp local bvi100
sccp ccm 10.1.1.1 identifier 1 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate profile 1 register transcode
dspfarm profile 1 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 codec g729br8
 maximum sessions 8
 associate application SCCP
telephony-service
 sdspfarm units 1
 sdspfarm tag 1 transcode
show dspfarm all
Dspfarm Profile Configuration
 Profile ID = 1, Service = TRANSCODING, Resource ID = 1
 Profile Description :
 Profile Service Mode : Non Secure
 Profile Admin State : UP
 Profile Operation State : ACTIVE
 Application : SCCP   Status : ASSOCIATED
 Resource Provider : FLEX_DSPRM   Status : UP
 Number of Resource Configured : 8
 Number of Resource Available : 8
 Codec Configuration: num_of_codecs:6
 Codec : g729br8, Maximum Packetization Period : 60
 Codec : g729r8, Maximum Packetization Period : 60
 Codec : g711ulaw, Maximum Packetization Period : 30
 Codec : g711alaw, Maximum Packetization Period : 30
 Codec : g729ar8, Maximum Packetization Period : 60
 Codec : g729abr8, Maximum Packetization Period : 60
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    1   28.3.10  UP     N/A  FREE  xcode   1      -         -         -
0    2   28.3.10  UP     N/A  FREE  xcode   1      -         -         -
0    3   28.3.10  UP     N/A  FREE  xcode   1      -         -         -
Hi,Under telephony service
Under telephony service you only have that much configuration ? I mean that you have to configure dummy DN and ephone under telephony service and also interface binding like this..
telephony service
max-dn 1
max-ephone 1
ip source-address 10.1.1.1 port 2000
ephone-dn  1
number xxxx
ephone 1
mac zzz.zzz.zzz
button 1:1
Then create cnf under telephony service..
And also add
sdpfarm transcode session 8 under telephony service.
Do a "no sccp" and then "sccp" and then test a call , if fails again send trace and "show sccp" logs.
Manish
Hi My friend i have done
My friend i have done thousands of UC implementations :) Yes its there all the appropriates configs.Just i upload here only the related with this issue
All the config is correct
Its seems that the trancoding is not working at all
May is a bug of the current software/IOS  dont know
Current IOS:
boot system flash:/uc500-advipservicesk9-mz.151-4.M7
If trancoders are showing
If trancoders are showing active in "show sccp" and configuration are correct , then it might be an IOS bug and you need to look at bug toolkit.
I will give a last try if you give me "debug ccsip all" only for a failing call to look at sip stack level trace.
Manish
186
