Community Member
calls getting disconnected when going over E1 PRI QSIG to Avaya PBX
I am implememnting the integration of call manager 6.1 to Avaya Definity G3R PBX.After the configuration when a call is placed from Avaya to Cisco it goes through but when a call is placed from cisco to avaya i get this message.
*Jul 10 08:01:49.503: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9FAA06800100820100A112020100020100800A4964726973204D757361
Calling Party Number i = 0x0081, '6357'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '326'
*Jul 10 08:01:49.543: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8001
Cause i = 0x81D8 - Incompatible destination
indly help sort out this problem because it is having a serious (critical )delay in business
Community Member
Re: calls getting disconnected when going over E1 PRI QSIG to Av
Can anybody help. plssss
Community Member
try this:
isdn switch-type primary-dms100
isdn protocol-emulate network
isdn incoming-voice voice
isdn T306 60000
isdn bind-l3 ccm-manager
you may need to change the pri protocol if avaya doesn't support dms100, the configuration above is for Nortel, i had same issue and this config fixed it.
Community Member
it is still the same reorder tone.cant call the avaya
Community Member
What device terminate ISDN on other side from Avaya?
If it is some cisco device check your pots dial-peer configuration, and try "no digit-strip".
Andrew
721
