Calls getting drop on PRI flapping
Dear friends,
I am facing prbolem with the calls drop intermitently,  below mention is the debug output
Dec  3 15:48:35.279 IST: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x0087 callID = 0x803F switch = primary-net5 interface = User
Dec  3 15:48:35.279 IST: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0087
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '6605514'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '09819640411'
Dec  3 15:48:35.415 IST: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8087
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Dec  3 15:48:36.627 IST: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8087
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Dec  3 15:48:40.979 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to down (AIS detected)
Dec  3 15:48:40.979 IST: ISDN Se0/1/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Dec  3 15:48:40.979 IST: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Dec  3 15:48:41.215 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:48:41.979 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to up
Dec  3 15:48:44.463 IST: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8087
Dec  3 15:48:44.463 IST: ISDN Se0/1/0:15 **ERROR**: L3_BadPeerMsg: event 0x7 cr 0x87 callid 0x0
Dec  3 15:48:44.463 IST: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0087
        Cause i = 0x80D1 - Invalid call reference value
Dec  3 15:48:48.499 IST: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/1/0
Dec  3 15:48:59.807 IST: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 6605514
Dec  3 15:48:59.807 IST: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x0088 callID = 0x8040 switch = primary-net5 interface = User
Dec  3 15:48:59.807 IST: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0088
Dec  3 15:49:47.214 IST: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 6605514
Dec  3 15:49:47.214 IST: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x0080 callID = 0x8041 switch = primary-net5 interface = User
Dec  3 15:49:47.214 IST: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0080
                Standard = CCITT
Dec  3 15:49:47.346 IST: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8080
Dec  3 15:49:48.518 IST: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8080
Dec  3 15:49:52.506 IST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/1/0
Dec  3 15:49:52.506 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Dec  3 15:49:56.054 IST: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8080
Dec  3 15:49:56.058 IST: ISDN Se0/1/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0080
Dec  3 15:50:03.006 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Dec  3 15:50:05.266 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:50:15.514 IST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/1/0
Dec  3 15:50:15.514 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Dec  3 15:50:26.014 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Dec  3 15:50:28.274 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:50:38.521 IST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/1/0
Dec  3 15:50:38.521 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Dec  3 15:50:40.977 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to down (AIS detected)
Dec  3 15:50:40.977 IST: ISDN Se0/1/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Dec  3 15:50:40.977 IST: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Dec  3 15:50:41.977 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to up
Dec  3 15:50:43.977 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to down (AIS detected)
Dec  3 15:50:43.977 IST: ISDN Se0/1/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Dec  3 15:50:43.977 IST: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Dec  3 15:50:44.977 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to up
Dec  3 15:50:55.273 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Dec  3 15:50:57.533 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:51:00.289 IST: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 6605514
Dec  3 15:51:00.289 IST: ISDN Se0/1/0:15 Q931: Sending SETUP  callref = 0x0081 callID = 0x8042 switch = primary-net5 interface = User
Dec  3 15:51:00.289 IST: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0081
                Standard = CCITT
Dec  3 15:51:00.421 IST: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8081
        Cause i = 0x82AC - Requested circuit/channel not available
Dec  3 15:51:01.533 IST: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/1/0
E003010101CRR#
Dec  3 15:51:58.324 IST: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8083
Dec  3 15:51:58.324 IST: ISDN Se0/1/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0083
Dec  3 15:52:47.976 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to down (AIS detected)
Dec  3 15:52:47.976 IST: ISDN Se0/1/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Dec  3 15:52:47.976 IST: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Dec  3 15:52:48.064 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:52:48.976 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to up
Dec  3 15:52:55.348 IST: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/1/0
Dec  3 15:53:24.347 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:53:34.595 IST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/1/0
Dec  3 15:53:34.595 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Dec  3 15:53:45.095 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Dec  3 15:53:47.355 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:53:48.975 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to down (AIS detected)
Dec  3 15:53:48.975 IST: ISDN Se0/1/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Dec  3 15:53:48.975 IST: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Dec  3 15:53:49.975 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to up
Dec  3 15:53:57.603 IST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/1/0
Dec  3 15:53:57.603 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Dec  3 15:54:08.102 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Dec  3 15:54:10.362 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:54:20.610 IST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/1/0
Dec  3 15:54:20.610 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Dec  3 15:54:31.110 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Dec  3 15:54:33.370 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:54:43.618 IST: %MARS_NETCLK-3-HOLDOVER_TRANS: Holdover timer exceeded for Controller E1 0/1/0
Dec  3 15:54:43.618 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 1 to priority 10
Dec  3 15:54:50.974 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to down (AIS detected)
Dec  3 15:54:50.974 IST: ISDN Se0/1/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Dec  3 15:54:50.974 IST: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Dec  3 15:54:52.974 IST: %LINK-3-UPDOWN: Interface Serial0/1/0:15, changed state to down
Dec  3 15:54:52.974 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to up
Dec  3 15:54:54.974 IST: %LINK-3-UPDOWN: Interface Serial0/1/0:15, changed state to up
Dec  3 15:55:03.370 IST: %MARS_NETCLK-3-CLK_TRANS: Network clock source transitioned from priority 10 to priority 1
Dec  3 15:55:48.349 IST: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8083
        Cause i = 0x8290 - Normal call clearing
Dec  3 15:55:48.349 IST: ISDN Se0/1/0:15 **ERROR**: L3_BadPeerMsg: event 0x45 cr 0x83 callid 0x0
Dec  3 15:55:48.349 IST: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0083
Dec  3 15:55:52.973 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to down (AIS detected)
Dec  3 15:55:52.973 IST: ISDN Se0/1/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Dec  3 15:55:52.973 IST: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Dec  3 15:55:53.129 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/1/0
Dec  3 15:55:53.973 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to up
Dec  3 15:56:00.469 IST: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/1/
Seems something its up with your E1
Do you have any other e1 besides 0/1/0? is is giving you the same problem? This could also be related to your WIC card.
Have you check with the telco?
'Sh isdn statu'
Please Kudos/rate if this help!
"Dec  3 15:48:40.979 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/1/0, changed state to down (AIS detected)"
is a dead give a away, Alarm Interrupted Seconds.
(show controller e1 will give you the counters in relation to Slips, Frame errors and or AIS.  clear counters on your e1 controller and you should see these increase.
Book it out with your telco
Please remember to rate useful posts, by clicking on the stars below.
1036
