Calls go right to Unity VM
hi,
I have a user who calls go right into vm after a dial by extension through AA.
I am running ccm 4.1.3 and unity 4.2.1
Randall
1 ACCEPTED SOLUTION
Re: Calls go right to Unity VM
check under the subscriber transfer options that you have it set to "yes, ring subscriber extension" and not send directly to VM
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
javalenc
java
Yes!
That was it!
Thanks for the assistance.
Randall
90
