Community Member
Calls go straight to vm
for 1 user IB calls go straight to v/m. OB is fine.
Any help is appreciated.
ccm 4.1.3
unity 4.2.1
Re: Calls go straight to vm
check the transfer settings for that users subscriber to have it set to ring the subscriber's phone
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
did that already...
rc
what's the call flow?
javalenc
java
Community Member
how do you check?
Community Member
We can check that with traces enabled, or by u telling us how is the call.
Meaning: Call comes from the pstn, hitting and mgcp, h323 gateway, going to CCM (version) then phone "A" should ring and instead goes to VM.
or when hitting a callhandler from unity and dial by extension goes directly to VM.
That's how you tell the call flow, so as JAVALENC said, What's the call flow?
Community Member
1. From my desk I call his extension. call goes to vm.
2. calls from PSTN hit h323 GW, then ccm 4.1.3, should ring at x6543, but directly to vm
Randall
you might have replication issues, try setting and unsetting CFA on that DN
javalenc
java
Community Member
Can you please restart the DBL layer monitor service on all your servers and see if that helps.
Also checked if the phone does not have the callforward all to VM.
vhilario
323
