You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Calls in queue drop when first call is answered
 When all agents are busy and there are multiple calls in queue, at the point a call gets routed to an agent and answered from queue, the other calls in queue hear the disconnect prompt.
This is CME 9.1 on  Version 15.0(1r)M16
application
 service queue flash:app-b-acd-2.1.2.3.tcl
  param queue-len 30
  param aa-hunt1 7426701
  param queue-manager-debugs 1
  param number-of-hunt-grps 1
 service KCC flash:app-b-acd-aa-2.1.2.3.tcl
  paramspace english index 1
  param handoff-string KCC
  paramspace english language en
  param call-retry-timer 15
  param service-name queue
  param drop-through-option 1
  param second-greeting-time 60
  paramspace english location flash:
  param drop-through-prompt _TYFC.au
  param send-account true
  param max-time-vm-retry 3
  param voice-mail 1426900
  param max-time-call-retry 1400
  param aa-pilot 7427701
Thanks in advance.
HHe
  • IP Telephony
Everyone's tags (1)
Are you sure you don't mean
Are you sure you don't mean CCX, not CME? Agents are normally associated with Contact Center and queues are designed to route the calls properly. Sounds like a set step would be wrong in the script.
Yes, this is CME using the
Yes, this is CME using the TCL script to allow for some queuing and aa functionality.
Try this , see if that helps.
Try this , see if that helps...
param queue-len number
Router(config-app-param)# param queue-len 15
Sets the maximum number of calls allowed in each ephone hunt group's call queue used by Cisco Unified CME B-ACD.
number—Number of calls that can be waiting in the call queue for each ephone hunt group. The range is from 1 to 30. The default is 10.
CME 9.1 needs the versions of
CME 9.1 needs the versions of the TCL script listed below in order to avoid the weird queueing issues.
app-b-acd-3.0.0.2.tcl
app-b-acd-aa-3.0.0.2.tcl
74
