Calls not comming Voice gateway -GFI Fax Server Problem
Hello Everyone,
I want to configure voice gateway for ip ower fax and i did provide dial peer below
When i called  3132515 number its told to me Called Failed,
Fax server IP: 192.168.0.18
PRI DID (For Fax) 3132515- 16
ip address trusted list
  ipv4 192.168.20.200
  ipv4 192.168.20.201
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
license udi pid CISCO2921/K9 sn FGL153011ZA
hw-module pvdm 0/0
username cisco privilege 15 password 7 0107070052060108736C561023
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
description ### TT PRI ###
controller E1 0/0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.20.203 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn timer T310 60000
isdn overlap-receiving
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
ip default-gateway 192.168.20.253
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip route 0.0.0.0 0.0.0.0 192.168.20.253
control-plane
voice-port 0/0/0:15
no echo-cancel enable
cptone TR
timeouts interdigit 5
bearer-cap Speech
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager redundant-host 192.168.20.200
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.20.200 192.168.20.201
ccm-manager config
mgcp
mgcp call-agent 192.168.20.201 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp profile default
dial-peer voice 120 voip
incoming called-number .T
codec g711ulaw
dial-peer voice 130 pots
destination-pattern 05.........
port 0/0/0:15
prefix 05
dial-peer voice 800 voip
destination-pattern 3132515
session protocol sipv2
session target ipv4:192.168.20.200
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 1 pots
direct-inward-dial
port 0/0/0:15
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
logging synchronous
login local
transport input all
scheduler allocate 20000 1000
461
