Community Member
calls not forwarding to CUE
I am unable to call cue through GK.When the call forward to CUE it gives me fast busy tone. If i call from PSTN the calls are forwarding to cue & things are perfect.
The call through GK is using G.729codec.
I have configured Transcoder as well but still im getting fast busy tone.
Below is my config.
sccp local GigabitEthernet0/0.100
sccp ccm 10.1.1.254 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register sc-xcode
associate profile 1 register sc-conf
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
telephony-service
sdspfarm units 3
sdspfarm tag 1 sc-conf
sdspfarm tag 2 sc-xcode
conference hardware
dial-peer voice 8 voip <----------CUE Dial-Peer
destination-pattern 7777
session protocol sipv2
session target ipv4:11.0.0.1
dtmf-relay sip-notify
codec g711ulaw
no vad
show sccp
SC#sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0.100
        IPv4 Address: 10.1.1.254
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.1.1.254, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 1
                Trustpoint: N/A
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.1.1.254, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 24, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Transcoding Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Profile Identifier: 2
Reported Max Streams: 4, Reported Max OOS Streams: 0
SC#
Thats perhaps because your CUE dial-peer mentions the communication protocol be SIP but GK speaks H.323.
May be you can create another dial-peer ( without SIP ), which GK could use ?
Lemme know how it goes.
GP.
Community Member
Re: calls not forwarding to CUE
Hi Gapande,
Thanks for ur time & reply. I have fixed this issue.
The problem was i didnt configure transcoder session under
telephony-service.
Once i enable, it worked perfectly.
Anis
gapande
notreply@jivesoft To
ware.com> Anis Ahmed/Bahrain/GBM/NBR@IBMGMSR
cc
02/04/2012 22:26
Subject
- Re: calls not
Please respond to forwarding to CUE
"cisco-support@sg
aur.hosted.jiveso
ftware.com"
aur.hosted.jiveso
ftware.com>
Community Member
Hi gajanan,
Thanks for your reply.
i sorted it out. It was because for transcoder session was not configured under telephony-service.
472
