08-09-2014 04:44 AM - edited 03-16-2019 11:41 PM
I have Cisco 2911 connected as Gateway to Call Manager via MPLS
Call Manager :- Ho
Gateway :- Remote
Call Manager and Gateway Connected via MPLS Network
Problem
1)Extensio to Extension Calls Working
2)But remote suers are not able to make any PSTN Calls
3)Created Router pattern, CSS ,aprtations
4)DNA shows ROUTER THIS PATTERN but still no Calls hittig Gateway and Outgoing /incoming calls not working
Please help asap
08-09-2014 07:39 AM
what happens when call is made from outside to this E1-PRI?
any logs on GW come or not ?
try doing debug isdn q931
regds,
aman
08-09-2014 07:48 AM
hello
besides Aman , can you confirm when you try to dial a RP it match correctly or it matches other RP, please check from your IP Phone , what did you see?.
please rate all useful information
08-09-2014 08:00 AM
i did DNA it was coming perfectly fine, i do not get any thing on debug isdn q931
i tired DNA with Local and STD both show right CSS and Route pattern
i dial 0 get the dial tone n then i get fast busy tone wen i disl the number
08-09-2014 10:02 PM
Can you attach "show log" from router, just want to make sure that calls are hitting to gateway or not.
Suresh
08-13-2014 05:25 AM
08-13-2014 10:16 AM
Pull CallManager traces as well as "debug mgcp packet", "debug voice ccapi inout", and "debug isdn q931" from gateway. Turn on "service sequence-numbers" on the gateway.
09-14-2014 06:46 AM
Hi Guyzz
Sorry for late reply the issue is resolved below PRE DOT potion in Route Pattern there was 1 more 0 by mistakenly put so call was not going out now it resolved
Thanks you all for your support
09-14-2014 07:04 AM
thanks for update[+5]
[+5] to Kamal/Suresh(2) /Brian for participation.
regds,
aman
08-09-2014 08:25 AM
check CSS and partition for the phone from which u are making outgoing.
08-09-2014 07:40 AM
08-09-2014 10:38 AM
could you please collect the CCM traces for a test call and include the calling# and called number?
08-09-2014 07:24 AM
Thanks for update ,
1-can you check that your VG under CUCM has correct CSS which include partitions under your existing Route patterns ?.
2-Can you share one of your Route pattern?.
3- Did you apply mgcp bind commands?
4-Ok , if VG is registered . Can you check that VG is registered with the correct IP address ?.
08-09-2014 07:06 AM
Can u please provide expanded snapshot of any route pattern ?
regds,
aman
08-09-2014 06:51 AM
There are only Route Pattern no route list
no output of :debug voice ccapi inout
I am attachig the sh runn
08-11-2014 05:07 AM
Off Topic: I think you are not supposed to dial from a HO phone to remote gateway via MPLS. TRAI violation.
