Calls not hitting gateway
  I have Cisco 2911 connected as Gateway to Call Manager via MPLS
Call Manager :- Ho
Gateway :- Remote
Call Manager and Gateway Connected via MPLS Network
Problem
1)Extensio to Extension Calls Working
2)But remote suers are not able to make any PSTN Calls
3)Created Router pattern, CSS ,aprtations
4)DNA shows ROUTER THIS PATTERN but still no Calls hittig Gateway and Outgoing /incoming calls not working
 Please help asap
what type of GW is it? SIP? H
what type of GW is it? SIP? H.323? MGCP?
What is the IOS version?
what is the PSTN connectivity? T1/E1 PRI? FXO? SIP?
Route pattern is associated with Route List or directly with Gateway?
if you enable "debug voice ccapi inout" on the gateway, do you get to see the logs when making the test calls?
if so, could you please attach that file here with running config of the GW?
//Suresh Please rate all the useful posts.
VIP Purple
I n addition to what Suresh
I n addition to what Suresh has asked, was this working setup or stopped suddenly?
what is the CUCM version ?
regds,
aman
HI Aman/Suresh CUCM:10
HI Aman/Suresh
CUCM:10.X
Gateway:-MGCP
PRI
New Setup
I will attach debug shortly
VIP Purple
Is PRI UP and GW registered
Is PRI UP and GW registered to CUCM?
can u also share output of  show isdn status and show controller E1?
regds,
aman
PRI UP controller line code:-
PRI UP
controller line code:- HDB3
primary net 5
Also attached route pattern
1)LOCAL LANDLINE/MOBILE VADODRA
2)\STD LANDLINE/MOBILE VADODRA
3)ISD LANDLINE/MOBILE VADODRA
HiCan you share : "sh ccm
Can you share : "sh ccm-manager"  from your gateway ?.And take screenshot from your gateway configuration from your CUCM?.
please rate all useful ifnormation
CCM manager screensohti have
i have taken remote so the other system bit slow
signifcant digit:- 4
CSS:-ISD Vadodra
Hello Sorry , i am unable to
Hello
Sorry , i am unable to see anything.Can you chech the name under sh ccm-manger from the router , same name of your router on CUCM?. as the below example:-
sh ccm-manager
R1.cisco.com
on CUCM - Device-gateway-R1.cisco.com. The both names should be same .
Also , on Cisco Voice gateway try to do the below:-
router(config)#no mgcp
router(config)#mgcp
please rate all useful information
Hi Islam names are same so
Hi Islam
names are same so its geristered with Call Manager
I did mgcp ad no mgcp but no go
VIP Purple
If all configs and
If all configs and registration are fine, can u try restarting Call Manager service ?
regds,
aman
HI Aman/IslamRoute pattern
HI Aman/Islam
Route pattern/show running i have attached before
i have mgcp bind commands also there and reloaded the gateway
VIP Purple
Under Route pattern , in
Under Route pattern , in Discard digits what have u selected?
hello1- What did you hear
hello
1- What did you hear when you dial external call , busy tone , or what?.
2- Did you check the ip address of your VG on CUCM , matches same ip of your interface which is used on bind commands ?.For example
interface vlan 302
ip address 10.1.1.254 255.255.255.0
mgcp bind media source-interface vlan302
mgcp bind control source-interface vlan302
On CUCM-Gateway - the ip address should be 10.1.1.254 . if you did not find it same , you have to disbale bind commands  and enable bind commands again .
3-Can you confirm that you use correct CSS under VG configuration?.
4-Can you share one of route pattern configuration , you have on discard digits "predot"?.
Yes its VLAN 100 and the VLAN
Yes its VLAN 100 and the VLAN 100 ip address is shown with registrtion
CSS::- CSS-ISD- VADODRA
VIP Purple
what happens when call is
what happens when call is made from outside to this E1-PRI?
any logs on GW come or not ?
try doing debug  isdn q931
regds,
aman
hellobesides Aman , can you
hello
besides Aman , can you confirm when you try to dial a RP it match correctly or it matches other RP, please check from your IP Phone , what did you see?.
i did DNA it was coming
i did DNA it was coming perfectly fine, i do not get any thing on debug isdn q931
i tired DNA with Local and STD both show right CSS and Route pattern
i dial 0 get the dial tone n then i get fast busy tone wen i disl the number
VIP Gold
Can you attach "show log"
Can you attach "show log" from router, just want to make sure that calls are hitting to gateway or not.
Suresh
Hiplease find the logs
Pull CallManager traces as
Pull CallManager traces as well as "debug mgcp packet", "debug voice ccapi inout", and "debug isdn q931" from gateway.  Turn on "service sequence-numbers" on the gateway.
Hi GuyzzSorry for late reply
Hi Guyzz
Sorry for late reply the issue is resolved below PRE DOT potion in Route Pattern there was 1 more 0 by mistakenly put so call was not going out now it resolved
Thanks you all for your support
VIP Purple
thanks for update.[+5] to
thanks for update[+5]
[+5] to Kamal/Suresh(2) /Brian for participation.
regds,
aman
VIP Purple
check CSS and partition for
check CSS and partition for the phone from which u are making outgoing.
Please find the attachement
my boardline # 0265(code) and actul # 33XXXXX
Hi could you please collect
could you please collect the CCM traces for a test call and include the calling# and called number?
HiThanks for update ,1-can
Thanks for update ,
1-can you check that your VG under CUCM has correct CSS which include partitions under your existing Route patterns ?.
2-Can you share one of your Route pattern?.
3- Did you apply mgcp bind commands?
4-Ok , if VG is registered . Can you check that VG is registered with the correct IP address   ?.
VIP Purple
Can u please provide expanded
Can u please provide expanded snapshot of any route pattern ?
regds,
aman
Hi,There are only Route
There are only Route Pattern no route list
no output of :debug voice ccapi inout
I am attachig the sh runn
Off Topic: I think you are
Off Topic: I think you are not supposed to dial from a HO phone to remote gateway via MPLS. TRAI violation.
725
