Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Calls Statistics
Hello.
How can I view inbound calls statistics in CM 4.1?
Thanks in advance.
Daniele
Re: Calls Statistics
not sure what you want to see, you can try RTMT for that
also CAR tool
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi, thanks for your reply.
I need to have a complete report with ALL calls, inbound or outbound.
For example:
12/08/2008 15:34 number 1234 calls number 0123456 duration 5 minutes
OK, answer is still the same
use CAR
java
java
110
