Calls through E1 not working
we are configuring a new voice gateway - 2811.
The vg will act as a CCME with E1 connectivity. I am using a VWIC2-1MFT-G703 for E1 connectivity.
E1 controller is up, but when I make a call it gives busy tone. Pls help check whether the config is OK.
The following is the config,
voice translation-rule 1
rule 1 /^0/ //
voice translation-rule 10
rule 1 /^21/ //
voice translation-profile EnviaNumeroCompleto
translate calling 10
voice translation-profile tira0
translate called 1
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-15 type r2-digital r2-compelled ani
cas-custom 1
country brazil use-defaults
metering
category 2
answer-signal group-b 1
interface Loopback0
ip address 115.31.255.201 255.255.255.255
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description -SRV-
encapsulation dot1Q 1 native
ip address 192.168.101.1 255.255.255.192
interface FastEthernet0/0.2
description -- User --
encapsulation dot1Q 2
ip address 192.168.101.65 255.255.255.192
interface FastEthernet0/0.3
description --Voice--
encapsulation dot1Q 3
ip address 192.168.101.129 255.255.255.192
interface Service-Engine0/0
ip unnumbered FastEthernet0/0.1
service-module ip address 192.168.101.5 255.255.255.192
service-module ip default-gateway 192.168.101.1
interface FastEthernet0/1
description -Telefonica 00HQPROSA00201--
ip address 115.31.250.106 255.255.255.252
duplex full
speed 100
no cdp enable
interface Serial0/1/0
description --00HQPROSA00201--
no ip address
clock rate 2000000
voice-port 0/0/0:1
translation-profile outgoing EnviaNumeroCompleto
dial-peer voice 5 pots
translation-profile outgoing tira0
destination-pattern 0T
port 0/0/0:1
forward-digits all
dial-peer voice 1 pots
destination-pattern .
direct-inward-dial
dial-peer voice 503 voip
destination-pattern 6603
session target ipv4:192.168.140.97
dtmf-relay h245-alphanumeric
codec g729r8 bytes 30
telephony-service
no auto-reg-ephone
max-ephones 42
max-dn 42
ip source-address 192.168.101.129 port 2000
auto assign 1 to 20
calling-number initiator
timeouts interdigit 3
timeouts busy 20
system message PROSAFE RIO
url services http://192.168.101.5/voiceview/common/login.do
url authentication http://192.168.101.5/voiceview/authentication/authenticate.do
time-zone 17
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 2130436... extension-length 4
voicemail 2999
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
web admin system name admin password password
web admin customer name prosafe password prosafe
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 8...
transfer-pattern 6...
transfer-pattern 1...
transfer-pattern .T
transfer-pattern 09T
transfer-pattern 08T
transfer-pattern 07T
transfer-pattern 02T
secondary-dialtone 0
after-hours block pattern 1 0 7-24
create cnf-files version-stamp 7960 Feb 06 2009 17:15:40
1 REPLY
Hall of Fame Super Gold
Re: Calls through E1 not working
Ola',
Begin checking "show controllers E1".
In that regard you nedd "network-clock-participate" and "network-clock-select", check that you have them.
If still problem take "debug vpm signal" with "term mon".
Unrelated to all this, note the -G703 part is wasted money for voice connections, it's necessary only with unframed data circuits.
122
