Calls to local mobile number rings twice then disconnects
Vibha Verma
I have the scenario as CUCM --> CiscoRouter -->SIP provider
Both the links are SIP trunks.
And the Cisco IP phones connected at site of Cisco router are registered with CUCM on HQ site.
User at router side tries to call local mobile no., it rings twice and then disconnects.
Please see the debug output below when 27300 extension no., attempts to call 0173000186, which is a local cell no.
From: "Kabir,  Jahangir Ferdous" <sip:9604027200@192.168.235.130>;tag=BE333EA4-22A1
To: <sip:173000186@202.126.120.100>
Date: Wed, 30 Jul 2014 08:51:27 GMT
Call-ID: 86CF5AA7-16FD11E4-9B26F03A-1687399D@192.168.235.130
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2940633216-0000065536-0000106572-0100666122
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M4
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1406710287
Contact: <sip:9604027200@192.168.235.130:5060>
Call-Info: <sip:192.168.235.130:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Session-Expires:  1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 200
v=0
o=CiscoSystemsSIP-GW-UserAgent 1080 8418 IN IP4 192.168.235.130
s=SIP Call
c=IN IP4 192.168.235.130
t=0 0
m=audio 24318 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
Jul 30 08:51:27.227: //14823/AF4680800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.11.0.6:5060;branch=z9hG4bK17a07b3c989f1d
From: "Kabir,  Jahangir Ferdous" <sip:27300@10.11.0.6>;tag=2348906~1bd52299-e061-4134-a4fb-6928663c0290-43137496
To: <sip:0173000186@10.10.32.5>
Call-ID: af468080-3d81b20e-10a825-6000b0a@10.11.0.6
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-15.2.4.M4
Content-Length: 0
Jul 30 08:51:27.227: //14824/AF4680800001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Via: SIP/2.0/UDP 192.168.235.130:5060;branch=z9hG4bK397F1D73
Content-Length: 0
Jul 30 08:51:27.235: //14824/AF4680800001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
CSeq: 101 INVITE
To: <sip:173000186@202.126.120.100>;tag=1451199649317
Contact: <sip:202.126.120.100:5060;transport=udp>
Content-Length: 209
v=0
o=- 146324521 9649301 IN IP4 202.126.120.100
s=VoipSIP
c=IN IP4 202.126.120.100
t=0 0
m=audio 6196 RTP/AVP 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
Jul 30 08:51:27.239: //14823/AF4680800001/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:0173000186@10.10.32.5>;tag=BE333EB4-1EFB
CSeq: 101 INVITE
Remote-Party-ID: <sip:173000186@10.10.32.5>;party=called;screen=yes;privacy=off
Contact: <sip:0173000186@10.10.32.5:5060;transport=tcp>
Call-Info: <sip:10.10.32.5:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Supported: sdp-anat
Content-Length: 185
v=0
o=CiscoSystemsSIP-GW-UserAgent 4056 9884 IN IP4 10.10.32.5
s=SIP Call
c=IN IP4 10.10.32.5
t=0 0
m=audio 24314 RTP/AVP 0
c=IN IP4 10.10.32.5
a=ptime:20
Jul 30 08:52:03.338: //14824/AF4680800001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 503 Service Unavailable
CSeq: 101 INVITE
Content-Length: 0
Sent:
ACK sip:173000186@202.126.120.100:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul 30 08:52:06.462: //14823/AF4680800001/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 INVITE
Remote-Party-ID: <sip:173000186@10.10.32.5>;party=called;screen=no;privacy=off
Supported: sdp-anat
Content-Length: 185
v=0
s=SIP Call
c=IN IP4 10.10.32.5
t=0 0
c=IN IP4 10.10.32.5
a=ptime:20
Jul 30 08:52:06.466: //14823/AF4680800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Session-Expires:  1800;refresher=uac
Supported: timer
Content-Length: 185
v=0
s=SIP Call
c=IN IP4 10.10.32.5
t=0 0
c=IN IP4 10.10.32.5
a=ptime:20
Jul 30 08:52:06.966: //14823/AF4680800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 185
v=0
s=SIP Call
c=IN IP4 10.10.32.5
t=0 0
c=IN IP4 10.10.32.5
a=ptime:20
Jul 30 08:52:07.202: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0173000186@10.10.32.5:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.11.0.6:5060;branch=z9hG4bK17a096318b475
Date: Wed, 30 Jul 2014 08:51:26 GMT
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: presence, kpml
Content-Length: 0
Jul 30 08:52:07.914: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Thanks in advance for any relevant info on this.
7 Replies 7
Ayodeji Okanlawon
You will need to speak to your ITSP. Because they are sending you a 503 service unavailable
Received:
CSeq: 101 INVITE
Content-Length: 0
Please rate all useful posts
yes. as Ayodeji Okanlawon told ask provider.
ask provider can you make call called number 173000186 and calling number  9604027200 ?
hi
Please see my latest reply above and suggest.
what provoder told you?
what is calling number and what is called number?
are thise numbers correct ? or not ?called number 173000186 and calling number  9604027200 ?
if not you need translation rules
Hey
Thanks for the valuable input.
BUt ITSP is saying it is not understanding the number received by it.
Please see below 2 other outputs of debug
debug ccsip calls
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.235.130
Source IP Port    (Media): 24784
Destn  IP Address (Media): 202.126.120.100
Destn  IP Port    (Media): 8058
Orig Destn IP Address:Port (Media): [ - ]:0
Jul 31 08:47:04.052: //15089/13347C000001/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
Jul 31 08:47:05.225: //15088/13347C000001/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0xB425890
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 27300
Called Number            : 01674880038
Source IP Address (Sig  ): 10.10.32.5
Destn SIP Req Addr:Port  : 10.11.0.6:5060
Destn SIP Resp Addr:Port : 10.11.0.6:34681
Destination Name         : 10.11.0.6
Jul 31 08:47:05.225: //15088/13347C000001/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Negotiated Dtmf-relay    : 8
Source IP Address (Media): 10.10.32.5
Source IP Port    (Media): 24780
Destn  IP Address (Media): 10.11.0.6
Destn  IP Port    (Media): 26054
Jul 31 08:51:17.488: //15091/C99861000001/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 9604027200
Called Number            : 1713000186
Source IP Address (Sig  ): 192.168.235.130
Destn SIP Req Addr:Port  : 202.126.120.100:5060
Destn SIP Resp Addr:Port : 202.126.120.100:5060
Destination Name         : 202.126.120.100
Jul 31 08:51:17.488: //15091/C99861000001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 24820
Destn  IP Port    (Media): 8228
Jul 31 08:51:17.880: //15090/C99861000001/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0xB437758
Called Number            : 01713000186
Jul 31 08:51:17.880: //15090/C99861000001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 24782
Destn  IP Port    (Media): 26064
Jul 31 08:56:50.148: //15091/C99861000001/SIP/Call/sipSPICallInfo:
Jul 31 08:56:50.148: //15091/C99861000001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Jul 31 08:56:50.152: //15091/C99861000001/SIP/Call/sipSPICallInfo:
Jul 31 08:56:51.336: //15090/C99861000001/SIP/Call/sipSPICallInfo:
Jul 31 08:56:51.336: //15090/C99861000001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Jul 31 09:02:59.214: //15093/762712800001/SIP/Call/sipSPICallInfo:
Called Number            : 8833003
Jul 31 09:02:59.214: //15093/762712800001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 24778
Destn  IP Port    (Media): 6428
Disconnect Cause (SIP)   : 404
Jul 31 09:03:02.998: //15092/762712800001/SIP/Call/sipSPICallInfo:
Calling Number           : 27304
Called Number            : 968833003
Destn SIP Resp Addr:Port : 10.11.0.6:38268
Jul 31 09:03:02.998: //15092/762712800001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 24818
Destn  IP Port    (Media): 26092
Jul 31 09:03:11.987: //15092/762712800001/SIP/Call/sipSPICallInfo:
Jul 31 09:03:11.987: //15092/762712800001/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
debug ccsip events
Jul 31 09:37:39.138: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Jul 31 09:37:40.310: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Jul 31 09:39:28.232: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Jul 31 09:39:28.232: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:16FD366C
Jul 31 09:39:28.232: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE
Refresher:none, Min-SE Value:1800, flags:2001
Jul 31 09:39:28.232: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Jul 31 09:39:28.232: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:16FD18DC
Jul 31 09:39:28.232: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Jul 31 09:39:28.232: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Jul 31 09:39:28.236: //15117/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Jul 31 09:39:28.236: //15117/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:16FD09BC
Jul 31 09:39:28.236: //15117/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE
Jul 31 09:39:28.236: //15117/8EE5F7000001/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
Jul 31 09:39:28.248: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
Jul 31 09:39:28.248: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROGRESS
Jul 31 09:39:28.252: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Jul 31 09:39:28.252: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:183, container:16FDA1AC
Jul 31 09:39:28.252: //15116/8EE5F7000001/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
Jul 31 09:39:30.508: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
Jul 31 09:39:30.508: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Jul 31 09:39:30.508: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:16FD508C
Jul 31 09:39:30.508: //15116/8EE5F7000001/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Jul 31 09:39:35.209: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Jul 31 09:39:35.209: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Jul 31 09:39:35.209: //15116/8EE5F7000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:487, container:16FD2384
Jul 31 09:39:35.213: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_GEN_SERVICE
Jul 31 09:39:35.605: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Jul 31 09:41:04.113: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Jul 31 09:41:04.113: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:16FD8BAC
Jul 31 09:41:04.113: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE
Jul 31 09:41:04.117: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Jul 31 09:41:04.117: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:16FD857C
Jul 31 09:41:04.117: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Jul 31 09:41:04.117: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Jul 31 09:41:04.117: //15119/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Jul 31 09:41:04.117: //15119/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:16FDA1AC
Jul 31 09:41:04.117: //15119/C81E67000001/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE
Jul 31 09:41:04.117: //15119/C81E67000001/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
Jul 31 09:41:04.133: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
Jul 31 09:41:04.133: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROGRESS
Jul 31 09:41:04.133: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Jul 31 09:41:04.133: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:183, container:16FD6CBC
Jul 31 09:41:04.133: //15118/C81E67000001/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
Jul 31 09:41:08.981: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
Jul 31 09:41:08.981: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Jul 31 09:41:08.981: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:16FD09BC
Jul 31 09:41:08.981: //15118/C81E67000001/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Jul 31 09:41:22.507: //15119/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Jul 31 09:41:22.507: //15119/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:16FCC604
Jul 31 09:41:22.507: //15119/C81E67000001/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none,
Min-SE Value:1800, flags:140
Jul 31 09:41:22.507: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_GEN_SERVICE
Jul 31 09:41:22.507: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
Jul 31 09:41:22.511: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Jul 31 09:41:22.511: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:16FD366C
Jul 31 09:41:22.511: //15118/C81E67000001/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none,
Jul 31 09:41:22.511: //15118/C81E67000001/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
Jul 31 09:41:22.899: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_GEN_SERVICE
Jul 31 09:43:18.709: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Jul 31 09:43:18.709: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Thanks again.
Your ITSP doesnt understand this number 9604027200...Is this number a valid DDI number provided by your ITSP?
Vibha Verma
Hello everyone.
I was constantly getting the debug message as Disconnect cause CC 16
and disconnect cause SIP 467 or 200.
But In the end when i reloaded the router and just reset the device pool, it worked.
