Community Member
calls via isdn pri disconnect after 5 min
I have CCM 4.2, protocol used is H323. calls to the PSTN are dropped after 5minutes, from the IP phone side, but the PSTN site the call stay connected.
Bronze
Re: calls via isdn pri disconnect after 5 min
Do you have the h323-gateway voip bind srcaddr "ip-address" on your ethernet interfaces. Could you provide the details fo the debug and the runnign config on the gateway? Can you post "debug isdn q921" and "debug isdn q931" for a call?
Community Member
hi,
please find the attached debug result and running config.
I am using h323, h323-gateway voip bind srcaddr is already in the ethernet interface.
appreciate your cooperation.
174
