Community Member
CAM Table Export
Is there a utility that can connect to my Cisco switches and pull the CAM table in a format that is useful (i.e. in a format I can get into Excel)? I need to cross-reference some phones with the switch port they are connected to.
1 REPLY
Silver
Re:CAM Table Export
I don't know of an automagic utility but if you have web access enabled you can fetch CDP neighbor data via http directly from the phones. Excel can grab data from an url and then you can parse it.
Sent from Cisco Technical Support Android App
106
