Campus Faxing
I have a 2600 with a PRI terminated and on a second 2600 on the campus I want to send a fax to the FXS port. What is the proper methodoloy for this? I wanted to translate and send to a dial peer but don't see how to a second router.
Thanks for any guidance.
Re: Campus Faxing
So you have PRI--GW1---(??? protocol ???)--GW2--FXS--FAX
You could use H323 as your protocol, and do something simple like:
GW1:
dial-peer voice 1 pots
port 0/0:23
direct-inward-dial
incoming called-number .
destination-pattern .T
dial-peer voice 2 voip
description fax to number 5551234
destination-pattern 5551234
session target ipv4:2.2.2.2
codec g711ulaw
modem passthrough nse codec g711ulaw
no vad
GW2:
dial-peer voice 1 voip
session target ipv4:1.1.1.1
codec g711ulaw
no vad
dial-peer voice 2 pots
port 0/0/0
desination-pattern 5551234
description FXS to fax machine
hth,
nick
Re: Campus Faxing
Thank you for your help.
That makes a lot of sense and I put it in.
The call now gets to the second router, but does not terminate on the FXS card.
The debug voice dialpeer inout shows the call coming in at the . but matching that dp not the one pointing at the FXS port.
Any idea?
Re: Campus Faxing
You should change the destination pattern on your FXS port pots dial peer, or change the way you're dialing from the other site. It's hard to tell you without details.
-nick
Re: Campus Faxing
Is this enough?
I'm ready to try destination-pattern 548. since exact match doesn't.
voice-class codec 1
no vad
dial-peer voice 21 pots
description for test on port 0/1/1
destination-pattern 5486
port 0/1/1
forward-digits 0
FS-Voice-RT02#
*Feb 20 17:00:20.799: //-1/6990207680A9/DPM/dpAssociateIncomingPeerCore:
Calling Number=8005551212, Called Number=5486, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
FS-Voice-RT02#
Re: Campus Faxing
You would need to post the part that has the --cisco-dest:
(it's a big block of debugs in debug voip ccapi inout)
It's very possible that you're not getting exactly 4 digits - try configuring the destination-pattern as the 10 digit number or however the other gateway is receiving it from the PSTN.
-nick
Re: Campus Faxing
First I have to thank you for the help.
I'm going nuts and don't see what is wrong.
I think I have all of the information in here. xxxxxxx is me taking actual numbers out. 7053 is my cell phone, 5486 is the destination fax. To me it looks like it never matches to the destination.
voice class codec 1
codec preference 1 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 2
interface BVI1
description To FS-Core-SW01
ip address 10.18.150.5 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.18.150.5
voice-port 0/1/1
description FXS-port for fax test
station-id name Fanshack test
station-id number xxxxxxx5486
caller-id enable type 1
dial-peer voice 3 voip
voice-class codec 1
incoming called-number 54..
no vad
port 0/1/1
forward-digits 0
FS-Voice-RT01#debug voip ccapi inout
voip ccapi inout debugging is on
FS-Davie-Voice-RT01#
*Feb 24 15:06:02.969: //-1/1AC6D4BC8161/CCAPI/cc_api_create_cc_entry_common:
Interface=0x46E8850C, Call Id=22,
Call Info=9546957053(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=5486(TON=Unknown, NPI=Unknown),
FinalDestinationFlag=TRUE, Incoming Dial-peer=3
*Feb 24 15:06:02.969: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Feb 24 15:06:02.969: :cc_get_feature_vsa malloc success
*Feb 24 15:06:02.969: cc_get_feature_vsa count is 1
*Feb 24 15:06:02.969: :FEATURE_VSA attributes are: feature_name:0,fearture_time:1181895768,feature_id:22
*Feb 24 15:06:02.985: //22/1AC6D4BC8161/CCAPI/cc_api_delete_cc_entry:
Interface=0x46E8850C, Disposition=0x0, Tag=0x0, Call Id=22
*Feb 24 15:06:02.985: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Feb 24 15:06:02.985: :cc_free_feature_vsa freeing 46724C50
*Feb 24 15:06:02.985: vsacount in free is 0
FS-Voice-RT01#
FS-Voice-RT01#no debug voip ccapi inout
voip ccapi inout debugging is off
FS-Voice-RT01#
FS-Voice-RT01#Debug voice dialpeer inout
voip dialpeer inout debugging is on
FS-Voice-RT01#
*Feb 24 15:10:08.494: //-1/AD1EAEAC8162/DPM/dpAssociateIncomingPeerCore:
Calling Number=xxxxxxx7053, Called Number=5486, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=3
Calling Number=9546957053, Called Number=5486, Voice-Interface=0x0,
FS-Voice-RT01#
Re: Campus Faxing
Looks like it should match the outgoing dial peer.
What does 'show dial-peer voice summary' show for the outgoing dial peer?
-nick
Re: Campus Faxing
The show dp v sum is UP UP.
I've rearranged the dial-peer order, I've changed the dp in different trys.
The call comes in on the voip dial-peer and will not go to the FXS.
I can call fxs port to fxs port, so the destination dp works. The voip dp is not searching the dp list from the top after the call comes in.
This is a new fxs card that I installed.
The station to station tells me it is ok.
What next?
Thank you again for your help.
Re: Campus Faxing
The ccapi debugs you sent weren't complete. Either something is causing that problem also, or it just wasn't the full debugs.
It sounds like there is some other configuration playing a part here.
-nick
Re: Campus Faxing
This was a site router with CME and CUE configured at one time. With consolidation, it is currently a router on a stick used for overhead paging through an FXO (works) and the FXS that was just added for a fax machine. I've removed the sccp and shutdown all the unused interfaces and the service-engine/0. There is some more I could remove, but all shutdown. What bothers me is the debug voice dialpeer inout showing that the call comes in on the right voip dp but never goes to the dp pots with the destination coded on it. I've rearranged the order of the dial peers so that the exact match pots is prior to the dial peer voip. I thought once the call came in on a dial peer, a linear search of dial peers from the top occured to determine if the call was destined for somewhere else. That search is not happening or is happening incorrectly.
Thank you again for you help.
Phil
Re: Campus Faxing
Hi Phil,
Try this:
dial-peer voice 3
shut
Since the destination-pattern is 54.. it is overlapping with the other dial peer.
If you were to add:
voice service voip
allow h323 to h323
You would probably see this call routing out that way.
hth,
nick
149
