can 2801 act as a PBX system?
Hi allz,
Im a little bit confused. I have 4 analog lines from PSTN so i have 4 different number. I was using PBX system before.
I have 2801 V router with 4 FXO ports and 2 FXS ports.
I configured it. All outgoing calls works fine.. But the problem comes with incoming calls.
When I call one of the number from PSTN, I cant call the same number.
All I wanna do is my customers may call one number.
thanks in advanced.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: can 2801 act as a PBX system?
No special configuration.
When calling the pilot number, the calls will use other lines when the first is busy.
Once you receive the first call, try calling the pilot number again. If the call does not arrive to a different line, there is a problem with telco.
If you want to see which lines are ringing, do "term mon" and "debug vpm signal".
Ask your telco to hunt-group the lines. They will give you a pilot number and you will receive calls on that one using all the lines. They can also use one of your existing numbers.
Its already done. It was working with PBX, but when i decided to put Cisco 2801V instead of PBX, it doesnt work anymore. Im not sure what special configuration should i do?
I defined voice-ports and dial-peers.
116
