Can a CUBE router terminate SIP with CM 4.1(3)
I have a customer that is running CM 4.1. Their carrier would like to do SIP trunks to the remote sites. Is a VGW running CUBE capable of terminating SIP with CM 4.1? How does the CM side of the VGW look, like an H323 or MGCP GW?
Mike.
3 ACCEPTED SOLUTIONS
Re: Can a CUBE router terminate SIP with CM 4.1(3)
already addressed with the PDI case you opened
java
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Mike,
All you need to understand is that SIP and H323 are open standards. CUBE supports SIP and H323 and can connect (theoretically) any two SIP and H323 endpoints that are also in specification.
Some of the things you may need to take in consideration is that CCM 4.x SIP trunks require an MTP, but outside of some of the CCM restrictions you should not have any problems. That is not to say, that CCM does not have SIP problems. But it wouldn't be a CUBE issue. Since CCM 4.x is a fairly close to the point where we introduced SIP, I would be cautious about SIP use in those versions. Everything should work, but there may be some minor issues that are fixed into CUCM 5/6/7.
hth,
nick
You're thinking of something different. I think SIP CME may have required authentication, but certainly not CUBE.
hth,
nick
java
java
Hi Mike,
hth,
nick
One last question, guys, if I may.....I had heard that an earlier version of CUBE had REQUIRED SIP authentication. The carrier does not support/require authentication. Can anyone confirm whether not doing SIP authentication with CUBE might be an issue?
THANKS!
Mike.
hth,
nick
It definitely helps. Thanks Nick.
Thank you, too, JaVa for the input on the PDI ticket. I feel much more confident about this project outcome, now.
Mike.
161
