01-02-2012 12:32 AM - edited 03-16-2019 08:46 AM
Hi can anybody help me on BOM
Customer has existing nortel network need to migrate to cisco cme setup
they have 9 PRI lines
and 32 analog lines
so i need to know which router i can use to support 32 fxo ports
whats the maximum fxo port avalaiable card in cisco we have
01-02-2012 12:53 AM
2811, 2851, 3825, 3845 Support 36-56 FXO ports but as they are end of sale, following routers can be procured from ISR G2 range.
2951, 3925, 3945, 3925E, 3945E support from 40-64 FXO ports in single router.
Checkout their individual data sheets for further details ( part code etc ).
Pls rate the post if it helps.
GP.
01-02-2012 01:32 AM
Thanks Gajanan ,
Just wanted to ask you one more think like if i use 3900 ISR router
Which FXO module should i use to accommodate this 32 FXO ports, and how many ports that single module support ( Can you Specify the part no. if you don't mind )
Also i can install the CME on this router right.
01-02-2012 02:02 AM
DSP Calculator can give you a good hint of which module/card to use to achieve required capacity with given router model. http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
3945E can have 60 FXO ports with following card combinations on the chassis.
GP.
01-02-2012 01:39 AM
Hi Breeze,
Try this link
I have use it with 28xx and 38xx.Please see this is available with 29 and 39
05-09-2013 07:17 PM
Here I found the response!
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c45_556315.pdf
Sergio
05-10-2013 02:02 PM
It is not a good idea to fit so many FXO circuits in a router. It comes out very costly and complicated. Have these converted to PRI by telco.
