CAN A SINGLE CISCO ROUTER CAN ACCOMADATE 32 FXO PORTS
Hi can anybody help me on BOM
Customer has existing nortel network need to migrate to cisco cme setup
they have 9 PRI lines
and 32 analog lines
so i need to know which router i can use to support 32 fxo ports
whats the maximum fxo port avalaiable card in cisco we have
Breeze Joseph Kuriakose Sr Network Engineer
Everyone's tags (7)
2811, 2851, 3825, 3845 Support 36-56 FXO ports but as they are end of sale, following routers can be procured from ISR G2 range.
2951, 3925, 3945, 3925E, 3945E support from 40-64 FXO ports in single router.
Checkout their individual data sheets for further details ( part code etc ).
Pls rate the post if it helps.
GP.
Re: CAN A SINGLE CISCO ROUTER CAN ACCOMADATE 32 FXO PORTS
Thanks Gajanan ,
Just wanted to ask you one more think like if i use 3900 ISR router
Which FXO module should i use to accommodate this 32 FXO ports, and how many ports that single module support ( Can you Specify the part no. if you don't mind )
Also i can install the CME on this router right.
DSP Calculator can give you a good hint of which module/card to use to achieve required capacity with given router model. http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
3945E can have 60 FXO ports with following card combinations on the chassis.
GP.
Hi Breeze,
Try this link
http://www.cisco.com/en/US/prod/collateral/modules/ps2617/prod_qas0900aecd8016c487_ps5855_Products_Q_and_A_Item.html
I have use it with 28xx and 38xx.Please see this is available with 29 and 39
Hall of Fame Super Gold
It is not a good idea to fit so many FXO circuits in a router. It comes out very costly and complicated. Have these converted to PRI by telco.
2316
