Can anybody answer my question
rajuchandu87
Q.What dial plan element changes the dialed digits?
Q: What dial plan element is used to match dialed digits for routing?
Vipul Jindal
raju,
can you be more specific....if you can give an example that will be easy us to help you!!
thanks,
Vipul Jindal
Jonathan Schulenberg
A translation pattern changes the dialed digits and performs a new route attempt. It is also possible to perform calling/called transformations which modify the number after routing has already been decided.
A route pattern chooses the off-net path.
These sound like test questions. I hope you're not cheating.
