can anyone explain to me line by line , Thanks
Setting Parameters
show voice port 2/0:0
Type of voice port is cas
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 8 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 250 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Station name None, Station number None
  • IP Telephony
Hall of Fame Super Gold
Re: can anyone explain to me line by line , Thanks
For any command output, check the reference manual.
each one is self explanatery
which one u have doubt...
better to look i runniing config voice port conf
Probalbly my question should read , what is the set up recommandation as we a have a voice delay to the work station , I also do have spaning tree configured w/ 4 switches , so I am trying to see where the delay is
Thanks again
work station ? please clarify.
147
