can Callmanager 4.1.3 be ported across to a Virtual Machine
Does Cisco support VM implementataions of Callmanager 4.1.3 or 5.1
Our server guy is porting all our appplication servers across to VM and wondered if we could do the same for Callmanager
1 ACCEPTED SOLUTION
Re: can Callmanager 4.1.3 be ported across to a Virtual Machine
if you mean for a live environment, NOT SUPPORTED.
we only have one option and is for lab, from this good post from Rob
IP Telephony: VoIP lab - what PC spec to build call manager 6
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc2511a
you may use it for internal testing, lab purposes, self-training, and that sort of things but install one for live environments is ABSOLUTELY NOT SUPPORTED
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
106
