can callmanager BARS support callmanager 5.1
robert.sebie
Can callmanager Backup And Restore System support callmanager version 5.1? How to backup callmanager 5.1?
smalkeric
Level 6
Level 6
For Cisco CallManager 3.3 or later, you need to use the supported Cisco BARS utility. If you use an earlier version of Cisco CallManager, use the Cisco IP Telephony Applications Backup Utility (3.5). On Cisco CallManager 5.0 and later, the BARS utility is replaced by the Disaster Recovery System.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/5_0_4/drsag504.html
