Community Member
can callmanager BARS support callmanager 5.1
Hi everybody,
I am just wondering whether callmanager BARS support callmanager 5.1. When I try to install BARS in the voice mail server, there is an error message that You must use cisco approved hardware to install BARS. But the voice mail server is an Cisco server. So what is cisco approved server?
1 REPLY
Hall of Fame Super Red
Re: can callmanager BARS support callmanager 5.1
Hi Robert,
In CCM 5.x and above this is now called "Disaster Recovery System" pretty cool! So you don't need to install the BARS Utility. Here is a look at the related info;
The Disaster Recovery System (DRS), which can be invoked from Cisco Unified CallManager 6.0 Administration, provides full data backup and restore capabilities for all servers in a Cisco Unified CallManager cluster. The Disaster Recovery System allows you to perform regularly scheduled automatic or user-invoked data backups. DRS supports only one backup schedule.
The Cisco Disaster Recovery System performs a cluster-level backup, which means that it collects backups for all servers in a Cisco Unified CallManager cluster to a central location and archives the backup data to physical storage device.
When performing a system data restoration, you can choose which nodes in the cluster you want to restore.
The Disaster Recovery System includes the following capabilities:
A user interface for performing backup and restore tasks.
A distributed system architecture for performing backup and restore functions.
Scheduled backups.
Archive backups to a physical tape drive or remote sftp server.
The Disaster Recovery System contains two key functions, Master Agent (MA) and Local Agent (LA). The Master Agent coordinates backup and restore activity with all the Local Agents.
The system automatically activates both the Master Agent and the Local Agent on all nodes in the cluster.
From this excellent doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/6_1_2/DRS_CUCM/drsag612.html
For these new CCM Versions BARS is no longer used :)
Hope this helps!
Rob
532
