Can cisco 2651XM can support more than 1 conferencing?
tomchan
Can cisco 2651XM can support more than 1 conferencing? Is it hardware limitation or just IOS support? thanks
bwilmoth
Level 5
Level 5
First of all, the IOS in your gateway needs to support a feature called "Enhanced Conferencing and Transcoding", which was introduced in IOS version 12.3(8)T. The router must be equipped with one or more network modules or voice DSP modules to provide DSP resources for conferencing, transcoding, and hardware MTP services:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/vvfax_c/callc_c/ccm_c/intcnf2.htm#wp1034467
