Can Cisco & Avaya work on splitting PRI?
Please advice, if Cisco & Avaya can work on splitting PRI.
Any help is much appreciated.
Everyone's tags (1)
1 REPLY
Super Bronze
It depends what you mean by 'splitting PRI' - can you elaborate?
Modern Cisco & Avaya systems are capable of integrating over IP or TDM, so you can deliver a single PRI to either system as and route calls on to the other system over a SIP/H323 or PRI connection if that is what you are asking.
It may also be possible to configure a H323 gateway to split calls out directly to each system.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
228
