07-07-2014 11:30 AM - edited 03-16-2019 11:20 PM
I have a need to know when a line has been forwarded to another line. Is there a record of this in CM or can I be alerted when this event occurs? Thank you.
07-07-2014 12:05 PM
It's only shown in the CUCM traces, AFAIK there's no way to get an alert of this.
07-07-2014 12:40 PM
Not an alert but you can pull down the callforwarddynamic table contents: https://supportforums.cisco.com/discussion/11629006/report-call-forward-all-cucm-715
You could automate this and check for changes to then push an alert via a script.
07-10-2014 06:28 AM
When you're planning to develope a script eg you should take a look at the AXL notifications (CUCM 10.x+)
https://developer.cisco.com/site/collaboration/management/axl/learn/how-to/add-cnf-to-application.gsp
07-10-2014 07:01 AM
Very cool, didn't know about that new feature.
07-11-2014 04:09 AM
Just tested a bit with this new feature with CUCM 10.0.1.10000-24.
Unfortunately changing cfa doesn't log a change. changing eg description does log a change in this version.
You could still use AXL to frequently send a getLine request and check the cfa setting.
