Can CUCM Auth Code be chaged periodically by end users ?
Hi Everyone.
can anyone tell know if is there any way that end users can change their auth code for making long distance call periodically? As far as I know it is a CUCM feature not a phone/user specific features hence it cannot be changed by the users themselves. And even if it changed from CUCM Auth Code configuration tab then it will reflect for all users. Please correct me if my understanding is wrong on this.
  • IP Telephony
Everyone's tags (7)
Blue
I believe you are talking about Forced Authorization Code. Yes it is CUCM router pattern feature and Forced Authorization Code has to be changed manaully and will have to be reflected to all the user.
Ronak patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
VIP Super Bronze
Natively, no there is not. If you wanted to write a custom web app that provided it's own authentication of users and tracked the mapping between a FAC and each user, you could then issue an AXL API into CUCM to remove the old code and add a new one.
Please remember to rate helpful responses and identify helpful or
HI Jonathan,
Thanks for your update. Can you please share any doc or link where it discuss about the AXL API application for wirting custom web app?
Arnab-
You can start reading here
Cisco Unified Communications Manager  (CallManager)
Programming Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
456
