Can CUCM7 auto disconnect a call after a set time?
I have CUCM 7.1.2 using a H.323 gateway, Using an E&M card to communicate to the paging system.
People are calling the number Paging, then not hanging up. Due to this, I would like to set a time limit for the call, then have it disconnect. Right now, it never hangs up.
Everyone's tags (2)
There's only one timer for that in CUCM and it's global, it will affect ALL calls.
So, you need to look into TCL scripts for that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
We are Cisco Developer Solution Partner and we have developed an application "Call Disconnect" that disconnects a running call on selected phones after a specific call duration.
Different call durations can be assigned to every group of users
Regar
264
