Community Member
Can dial local number in Germany but not Cell?
Does anyone know of a reason why a user can call a home/business phone from the US to Germany but not a cell phone in Germany (Just get a busy tone).
Digit Collection Timeout has been extended with no luck.
Dial Pattern is set to 9011T with no luck.
Have even removed all dial patterns and added a user defined 9[0-9]T with no luck...
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Can dial local number in Germany but not Cell?
Try setting sending-complete ?
Your call may be just correct and turn out to be a telco routing issue. Rare, but may happen.
So let's see the trace first.
Community Member
Can you post a debug isdn q931 and a debug voice dialpeer inout of a failed call.
Community Member
Will do tomorrow as I am not in the server room.
FYI,
I tried to call two separate cell phones in Germany with same results.
Local numbers are 13 digits and cell phones are 12...my head hurts trying to figure this out..
But let's see the trace first.
Silver
Do you use the 9@ NANP as this will be more explicit from the 9011T pattern- maybe the 9@ for Germany is fixed for 12 digits.Create an exact route pattern for the Germany Mobile and test again so you bypass any other route - what does the q931 show?
Community Member
Hi All,
I hope I am doing this correctly.
Here is the q931
Called Party Number i = 0x91, '0114917278xxxxx'
Plan:ISDN, Type:International
012406: Sep 30 16:45:21.838: ISDN Se0/2/0:23 Q931: RX <- STATUS pd = 8 callref = 0x818E
Cause i = 0x80E3A1 - Information element not implemented
Call State i = 0x01
012407: Sep 30 16:45:21.938: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x818E
Cause i = 0x809C - Invalid number format (incomplete number)
That's not correct:
Known problem, router is incorrectly setting pan/type when it sees 011
Configure
int s0/2/0:23
isdn map address . plan unknown type unknown
Community Member
Please forgive my ignorance..
I am not running any routers.
I have 2 switches and then the Pix.
Could you please clarify?
Never-mind, I believe you are talking about the router coming in then going to the PBX.? I think.. ;)
Yes, the voice gateway is actually a router.-
Community Member
Problem Solved!
Thank you very much!
237
