Community Member
Can E1 Fiber optic line replace E1 copper line in a VOIP setup
My customer are going to move site to a new location. Existing E1 lines are copper cables, then want to procure new E1 lines that are fiber optic.
There are 2 voice gateway and 1 FOIP router. Site has  Publisher, 2 subscriber, Unity, LOGGER, PG, IPIVR.
Please suggest if the New fiber optic E1 can replace existing Copper E1 line. Can it affect existing VOIP and FOIP setup?
Hall of Fame Super Silver
Re: Can E1 Fiber optic line replace E1 copper line in a VOIP set
I have not heard of ISDN E1 delivered over fiber, would the fiber connection be handed to Rj48 so that it can be connected to the GW? Did you check with the provider that this is doable?
Chris
Community Member
Hi Chris,
In case if providers hand the connection to RJ48 and connect to voice gateway, will there be any effect on the Cisco VOIP and FOIP setup?
No, if they can deliver you handoff you require on the gateway it does not matter what the physical medium to traverse the voip traffic would be.
HTH,
Chris
160
